C&L Intake pipe
Old November 1st, 2011, 11:07 PM   #1
kevinski72's Avatar
1996 Mustang 3.8
kevinski72 is on a distinguished road
Unhappy
C&L Intake pipe
I tried installing one of the c&l intakes from a 96-2001 gt on my stock 96 3.8. The bends and shape and everything fit great, could probably use a bigger throttle body though. At first I had the 30lb sample tube and the engine would sputter then cut off. Eventually got the 19 lb tube and it runs but not smoothly at all. Do I need a tune? Or could there be a leak somewhere? Or could there be another problem? Anyone ever try these intakes on their sixer?
Ever see a lion limber up before it takes down a gazelle?
Mods: ProChamber & Mac Flowpaths
8.8 rear w/ 3.55 gears
WTB Mac Tail Pipes PM ME
Old November 1st, 2011, 11:15 PM   #2
Do you have a mesh screen between the air filter and maf sensor?
Old November 1st, 2011, 11:18 PM   #3
kevinski72's Avatar
1996 Mustang 3.8
I do not, left it in the stock intake I think
Old November 1st, 2011, 11:18 PM   #4
kevinski72's Avatar
1996 Mustang 3.8
........ Don't tell me the sensor is no good now...
Old November 1st, 2011, 11:20 PM   #5
The sensor is fine...as long as you didnt break the metal threads that are in the maf....but that mesh is there for a reason...it evens out the air flow....
BTW...no tune needed...just put the mesh in and reflash the car
Old November 1st, 2011, 11:24 PM   #6
kevinski72's Avatar
1996 Mustang 3.8
Will try that tomorrow. Learned something new, thanks
Old November 1st, 2011, 11:35 PM   #7
Np hope it helps
Threads Similar to: C&L Intake pipe
new dyno numbers with x pipe intake! whitemach 2011+ 2 July 18th, 2011 11:12 PM
LT headers X-pipe OR Intake Manifold and Axle Backs luisdeli8 2005 - 2010 0 April 12th, 2011 11:56 AM
Centri intake pipe heat TotoGT06 2005 - 2010 3 October 17th, 2010 11:33 PM
P0171 Error after pi intake and o/r h pipe mazza89 96-98 17 March 11th, 2010 10:47 PM
