'00 Mustang V6
Slow but looks nice :p
Issues
My car has recently been knocking, fluctuating idle, sputtering, and would tend to die if I'm at a stop light for a while. So, I took of the upper intake manifold and where the Cylinder 6 is, there was some extreme gunk build up in the manifolds.
So, cleaned it out with Carb Cleaner to the best of my ability and now there's no more knock, no more idle fluctuation, no more detonating, but it still sputters. When stopped and under 2k rpm, it sputters even during acceleration, but then I get a burst of acceleration and it stops sputtering. Something tells me this issue has to do with air flow. Could a clogged cat or exhaust component be what's causing this? Also, I've even replaced my EGR valve... Any help is appreciated!
![]() Build Thread Parts For Sale Mods: 01 Cobra Bumper, GT Rear Bumper, Reverse Glow Gauges, Smoked Headlights, Smoked Fogs, Windstar Upper Intake, 8.8 Rear End, Drilled & Slotted front brakes, to be cont'd... |
my GT had that issue...it turned out to be an upstream o2. couldn't hurt to pull yours then look at it. Not too expensive to replace either
The soul stealing Ginger
Mine had same issue as well, it didnt sputter all the time but pretty random. I had my CATS cut off and straight piped, now it does not do it, bogs down a little bit but pretty sure thats my tune up that i need to do....and.....my tune up....sorry losing all train of thought now because i keep staring at olivia Wild..
#4 | |
'00 Mustang V6
![]() @dgt, lol
'00 Mustang V6
To check, should I pull the O2 Sensors themselves, or just unplug the connectors?
both...check to make sure they are connected correctly as well
'00 Mustang V6
Disconnected the connectors, didn't have the time to pull out the sensors today. But, it ran like a charm disconnected. You, my friend, are a mustang genius!
REPS
the upstreams or downstreams?
'00 Mustang V6
I only pulled the 2 inside the bigger Cats.
'00 Mustang V6
It may also be the upstreams. Just def clears the air that it's my O2 sensors.
iPoopke Regular
2004 Mustang
Just out of curiosity, whens the last time you did your plugs/wires?
'00 Mustang V6
The car got a different motor early last year, since then, I've only put less than 20k miles on it.
So, that's not really necessary. Everything else is in good shape.
iPoopke Regular
2004 Mustang
Id still check/replace them. My car was having the same issues as yours. New plugs and wires resolved the problem. When id have my car in cruise control on the highway, it would run smooth, until i went up an incline. The small increase in engine rpms would make my car idle and chug like a son of a gun. Also, when in reverse, it felt like it wanted to stall horribly.
just replace the plugs OP...it's only gonna run you around $10 so why not
'00 Mustang V6
It's not the plugs...
I just scanned it, here's my codes: P0171 System too lean (bank 1) P0174 System too lean (bank 2) P0306 Cylinder 6 Misfire detected
#20 | |
![]() as for the first two..it's unusual to see both banks go out at the same time. I would look at all the vacuum lines first...it can sometimes explain this |
Threads Similar to: Issues
| 331 issues | 88Saleen | 5.0 Mustangs | 13 | May 26th, 2011 08:35 PM |
| First mod issues... | 02Roush | 99-04 | 4 | January 28th, 2010 08:13 PM |
| AC Issues... | 02MustangV6e9 | V6 Mustangs | 4 | February 23rd, 2009 07:37 PM |
| still having issues... | mustangsoldier | 5.0 Mustangs | 32 | February 16th, 2009 06:11 PM |
| Having Issues With My Car... | ChrisJ | 99-04 | 20 | August 24th, 2008 07:08 PM |
