horse power question (formula)
Old November 3rd, 2011, 02:28 PM   #1
6ixer's Avatar
2000 mustang v6
14.6@99.68
6ixer is on a distinguished road
As random as this may be anyone have a relative formula for hp calculation my text books is retarted is says horse power is equal to the diameter off the bore (inches). Squared mulltiplied by the number of cylandars then divide tht by 2.5...I think its supposed to be allthat but multiplied by 2.5 or the equation is wrong all together cuz I've seen one with pie (the math symbol pie) and diamiter is also involved ...
Anyone lol
Ported heads, comp cams cam, AM CAI, posi'd rear with 3.73 gears, flowmaster exhaust
Fixed clutch!!!!!
"My mustang likes a good ol' fashion bowl of rice....especially fried"
Old November 3rd, 2011, 03:09 PM   #2
Formerly 01silversixer
SlowSix's Avatar
2001 V6
15.47@89.57
SlowSix has a spectacular aura aboutSlowSix has a spectacular aura aboutSlowSix has a spectacular aura about
horsepower is a derivative of torque and rpm I believe...
Build Thread
Old November 3rd, 2011, 03:40 PM   #3
6ixer's Avatar
2000 mustang v6
14.6@99.68
Yeahh I found out tht there's somthing like ..
Torque plus rpm
Divide by
5225 or 5525 idk the last part
Fixed clutch!!!!!
Old November 3rd, 2011, 03:41 PM   #4
I'm doing it wrong
Rich J's Avatar
04 Grand Cherokee
Rich J is just really niceRich J is just really niceRich J is just really niceRich J is just really nice
I don't know it exactly, it involves your torque, and 5250 (the max torque rpm before hp takes over the powerband)
Formerly known as Demon_54
"I feel the same way about disco as I do about herpes." - Hunter S. Thompson
Old November 3rd, 2011, 03:44 PM   #5
6ixer's Avatar
2000 mustang v6
14.6@99.68
But isn't there a "base hp" for an engine at rest...as in dle cuz if you take the above formula the end hp is like 43.9 but tht ddoesnt state any rpms
Fixed clutch!!!!!
Old November 3rd, 2011, 03:45 PM   #6
6ixer's Avatar
2000 mustang v6
14.6@99.68
but what I'm looking for is the formula based on stroke bored pie and number of cly..
Fixed clutch!!!!!
Old November 3rd, 2011, 03:48 PM   #7
6ixer's Avatar
2000 mustang v6
14.6@99.68
5250 just how happens to be where the redline is on OUR car buut is tht number based on every car or just the red line of anycar and I'm looking at it based on numbers on paper no rpms or anything
Fixed clutch!!!!!
Old November 3rd, 2011, 04:04 PM   #8
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to all
Horsepower=torque*rpm/5252
Hi, You can call me Kyle
Random ESG fact: Had a prochamber on his v6 before it was popular.
WTB: v6 BBK valve covers
Old November 3rd, 2011, 04:20 PM   #9
Tang Stang's Avatar
Tang Stang is just really niceTang Stang is just really niceTang Stang is just really niceTang Stang is just really nice
6ixer, there is no set formula deriving horsepower from displacement.
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Old November 3rd, 2011, 05:31 PM   #10
6ixer's Avatar
2000 mustang v6
14.6@99.68
Well I know how to find displacment/ci
Pie times radius squared times the stroke times the number of cyl
But wat I'm saying is if you taqke the vary first post I have if you take our 3.8 engine (bore and stroke) and u use the very first thing I posted and u multiply 2.5 not divide the end hp is 227.3 now according to what I read tht might be true if you take off ALL the drive belt items....alt/ac/steering pump ect ect...but again u need all them and tht 227would be at the crank of corse.just like the 190 is
Fixed clutch!!!!!
Old November 3rd, 2011, 05:33 PM   #11
6ixer's Avatar
2000 mustang v6
14.6@99.68
@ tang I'm not looking to get hp from displacemnt I'm just trying to see if there's away to take the bore and stroke and number of cyl and find relative hp
Fixed clutch!!!!!
Old November 3rd, 2011, 06:04 PM   #12
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
Same thing, lol
But to answer your question...
You could do something like: (Displacement/2 * rpm) * efficiency factor = power.
Efficiency factor being the percentage of energy you get from each gallon of gas that's actually turned into kinetic energy (instead of wasted as heat), and will be different for each engine.
But really, the formula is just
Horsepower = (torque * rpm)/5252
where torque is measured in foot-pounds.
And yes, it's *always* 5252. To answer the next question, "why don't dyno charts always cross at 5200 rpm, then?", the answer is because of correction factors. Dyno charts are almost never the raw data, they're adjusted to a "standard" temperature/altitude. That moves the curves around and changes where they cross.
If you have a known engine and want to see what the power would be like for a similar but different displacing engine, you can just do the math. I.e. if you stroke out a 3.8L that currently makes 190hp out to a 4.1L, assuming that the two engines are of equal efficiency (190/3.8) = (x/4.1), so x = 205 (not a huge gain, all things considered)
O o
/¯/______________________
\_\
Old November 3rd, 2011, 06:32 PM   #13
Tang Stang's Avatar
A formula that uses bore, stroke, and number of cylinders to derive horsepower doesn't exist. Your "formula" doesn't account for efficiency, which is effected by things like cylinder head design, forced induction, camshaft profile, etc. You can have identical shortblocks (same bore, stroke, and number of cylinders) and have two wildly different levels of horsepower.
Old November 3rd, 2011, 06:43 PM   #14
JTs03v6's Avatar
2003 mustang
7.48x1.56=11.67
JTs03v6 has a spectacular aura aboutJTs03v6 has a spectacular aura aboutJTs03v6 has a spectacular aura about
What are you trying to accomplish with a formula?
New combo: Forged SC short Block,280cfm heads, Precision 6262 turbo, cx 31x12x3 fmic
http://photobucket.com/JTsTurboBuild
http://youtube.com/user/JTsStang
Old November 3rd, 2011, 06:55 PM   #15
6ixer's Avatar
2000 mustang v6
14.6@99.68
Thank you guys I. Thought there was one out there but again thanks again now to shift gears instead of creating another post ill ask her and I'm pretty sure its subjective but I'm disreguarding my cam build....I've finally come to a conclusion although I kinda alrdy did..tht..6ers r nice for dd and only good for modding if you have the $ and forced induction...so my question is
It temrs of the gts
94/95 5.0
99-04 gt....
"which is better"
To my understanding the 5.0 and 4.6 put out pretty close numbers in tq but the 4.6 I think makes more hp...but I also hear the 5.0 is under rated in factory specs for insurance rasons..
Go...
*ps I'm starting my saving acct mod and I'm about 25% done all gts go for 4.5-6k imat 1k now*
Proolly get a gt or a 4.6 dohc na cobra if % is right
Fixed clutch!!!!!
Old November 3rd, 2011, 08:30 PM   #16
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
I would say the 5.0 due to the fact that you can buy parts dirt cheap and its simpler to work on a push rod motor than the sohc.
Old November 3rd, 2011, 09:00 PM   #17
5.0 vs 2v 4.6 doesn't really have a best. 5.0 makes a little more torque, 4.6 revs a little higher and makes a little more horsepower (well, at least the PI motors do).
Do an H/C/I swap and they make near identical levels of power. Both like boost. Both have a "big brother" motor that swaps in relatively easy (351W/5.4L)
Only real advantage comes into play when you start chasing cubes; the pushrod motors take to it a lot better than mod motors do.
O o
\_\
Old November 3rd, 2011, 09:19 PM   #18
6ixer's Avatar
2000 mustang v6
14.6@99.68
So your saying in respect the 5.0 and the pi or 4.6 found in the 99-04 gts are pretty much the same power
well
5.0 <tq
4.6< hp
But there not much difference in power and you saidboth handle f/I well and h/c/I have the same out put
Advantage the 5.0 is a push rod so its easier to work on even tho the cam in the 5.0 is in the block but the cam in the 4.6 is over head in the heads...seems the other way
But like u said and after looking at the number the engines are relativly with in 15hp/tq of each other...so its just the preference is what the engine is in what car as in body style
Fixed clutch!!!!!
Old November 3rd, 2011, 10:05 PM   #19
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
well
5.0 <tq
4.6< hp
Yep take a 'noob' give him cams for a 5.0 and a 4.6 every possible tool and the internet I would be 70% chance he fucks it up for the 4.6 :p
Old November 4th, 2011, 12:06 AM   #20
6ixer's Avatar
2000 mustang v6
14.6@99.68
Well if all goes well ill have a gt by spring...most 94/95 gts are going for (approx and meadian value) of 3k and I got just under 1k and if *knock on wood* nothing big brakes on my car between now and then and I can afford the insurance...gt..in the rping....btw what's the stock gears in those bad boys cuz all I'm gunna do is keep stock mid pype swap mufflers andgear it
Fixed clutch!!!!!
Threads Similar to: horse power question (formula)
Horse Power Question? SCREAMPUFF87GT 5.0 Mustangs 4 July 12th, 2010 07:16 PM
Horse Power Question AJHXXXIII Autocross 3 May 14th, 2010 02:20 PM
More horse power Givethecash Modular Mustangs 8 March 10th, 2010 03:51 PM
Horse Power Help jitsbilly Modular Mustangs 15 September 1st, 2008 04:50 AM
How Much Horse power do you have? Nameless122 V6 Mustangs 136 August 24th, 2007 04:21 PM
