m112 adapter
Old November 8th, 2011, 07:36 AM   #1
bluestang1724's Avatar
03 cobra, 95 gt, 00 v6
bluestang1724 is an unknown quantity at this point
m112 adapter
well i was lookin around and found a m112 adapter on super six motorsports and was curious as to what engine mods would have to be done to support a supercharger on a sixxer? i know what other mods id need as far as fuel system and rear end and stuff like that, im just asking about the MOTOR. thanks guys/girls
i have a 03 cobra and eventually i want to upgrade to a whipple so ill already have the m112 laying around and thought maybe i could put it to good use.
2003 Redfire Cobra, 6-spd
1995 Laser Red GT 5-spd
2000 Atlantic Blue Metallic V6 5-spd
Old November 8th, 2011, 09:17 AM   #2
2000stallion's Avatar
2000 Mustang
slow@slow
2000stallion will become famous soon enough2000stallion will become famous soon enough
wouldnt really need to do anything to the motor unless you want it cammed. But id say bolt on the m112 and get it tuned..
For Sale:
99-04 smoked tail light covers
Old November 8th, 2011, 10:20 AM   #3
so the motor will hold the power? even all the stock internals? this is a IF idea. if i get bored and wana build the v6 after the cobra is done
Old November 8th, 2011, 10:46 AM   #4
mustangmike!'s Avatar
2004,1994,1967
14.37 @ 96
mustangmike! is a jewel in the roughmustangmike! is a jewel in the roughmustangmike! is a jewel in the rough
depends
How much PSI you plan on running ?
227whp N/A V6
Now w/ 8th Mile 8s !
How To Jmod Your Late Model 4R70W
Old November 8th, 2011, 11:20 AM   #5
Formerly 01silversixer
SlowSix's Avatar
2001 V6
15.47@89.57
SlowSix has a spectacular aura aboutSlowSix has a spectacular aura aboutSlowSix has a spectacular aura about
stock internals are good to about 350 rwhp from what everyone else has said
Build Thread
Old November 8th, 2011, 11:55 AM   #6
2001 v6 premium
xtreme 2 will become famous soon enough
Send a message via AIM to xtreme 2 Send a message via MSN to xtreme 2 Send a message via Yahoo to xtreme 2
agreed. With supporting fuel mods (Lightning MAF, 39# injectors, upgraded fuel pump), this will give you ~300 hp. Add exhaust and a cam and you can see ~340.
Screw it, coming to play with the big boys...
5.4L Vortech COMING SOON!
Old November 8th, 2011, 12:02 PM   #7
SlowSix's Avatar
2001 V6
15.47@89.57
buddy of mine made 330ish I believe on 11 lbs. Stock cam. Longtubes and o/r h pipe.
Had a JLT cai and some kind of upgraded TB on the m112.
He is running meth though.
Build Thread
Old November 8th, 2011, 12:04 PM   #8
ill prolly b runnin ~8ish psi.
its a beautiful car as u can see its the blue one in my avitar. and id like to have supercharged n just mess around in it. itll b nice to have a quick little v6.
Old November 8th, 2011, 12:06 PM   #9
yea ive also heard since u cant run a intercooler with it itll b nothing but hot air. my buddy has a meth kit sitting around from his gto so maybe ill ask to have that.
Old November 8th, 2011, 12:30 PM   #10
2004,1994,1967
14.37 @ 96
im curious as to why you "cant" run an intercooler with these ? Never looked much into all that stuff so excuse me if I look like a fucktard here, but couldn't you just extend the intake tubing to a cooler ?
Sounds "to easy" to be true so im sure their is a perfectly good reason that If I knew more about FI it would be common sense... oh well
But also, 8psi on stock heads/intakes, or on ported heads/intakes ? makes a difference :p
Ohh and idk if you've looked much into this swap or not, but it requires a hood mod or new hood
Mysteed Performance: Making the Impossible, Possible.
227whp N/A V6
Old November 8th, 2011, 12:55 PM   #11
SlowSix's Avatar
2001 V6
15.47@89.57
to run an intercooler the blower would be about 6-7 inches high and you wouldn't be able to have a hood
Build Thread
Old November 8th, 2011, 01:59 PM   #12
Skar Gone
Skargon's Avatar
1998 Mustang V6
17.27@76.66
Skargon will become famous soon enoughSkargon will become famous soon enough
Huge Cowl FTW.
:B
Or cut a Hole in the hood. =D
1998 5 Speed, CAI, Exhaust, Rear Seat Delete.
Old November 8th, 2011, 02:36 PM   #13
2004,1994,1967
14.37 @ 96
or use turbo
227whp N/A V6
Old November 8th, 2011, 05:28 PM   #14
SlowSix's Avatar
2001 V6
15.47@89.57
Originally Posted by Skargon View Post
Huge Cowl FTW.
:B
...something like...THIS?!?!? for reference that charge pipe sits about 6-7 inches out of the hood or so. He cut a hood in what was originally probably a 4 inch cowl
the thing runs mid 8s...he is getting a new block and cranking the boost up even more
Build Thread
Old November 9th, 2011, 07:54 AM   #15
or use turbo
i dnt wana go turbo b/c id have the supercharger and cobra intake already sitting around. and thats like 90% of what id need.
Old November 9th, 2011, 08:43 AM   #16
2000 Mustang
slow@slow
not quite
heres the full parts list:
2003-2004 Cobra M112 Supercharger
2003-2004 Cobra plenum
2003-2004 Cobra throttle body
2003-2004 Cobra 39lb injectors
Cobra 90MM MAF With MAF Sensor
2003-2004 Cobra boost bypass
2003-2004 Cobra supercharger pulley
2003-2004 Cobra throttle and cruise control bracket
2003-2004 Cobra air intake tube
2003-2004 Cobra TPS sensor
2003-2004 Cobra M112 supercharger gasket- RTV sealant works best
2003-2004 Cobra plenum gasket
2003-2004 Cobra throttle body gasket
2003-2004 Cobra fuel injector O-rings
1999-2004 Mustang V6 upper intake gasket
M112 intake adaptor
PCV delete
2003-2004 EGR delete
IAT Sensor and Wiring
CNC MAF flange
310lph fuel pump (98-04 cars)
NGK TR7IX spark plugs
Gatorback belt #4061182 or 6PK3002(metric part number)
Air Filter With Filter Box
M112 EGR delete
12 bolts for adapter to V6 lower intake
12 washers for intake bolts
10 bolts for M112 to adapter
4 bolts for the plenum to the M112
4 bolts for the throttle body to the plenum
4 bolts for the MAF to CNC flange
2 bolts for IAC delete to plenum
2 bolts for IAC relocation
2 bolts for IAT relocation to M112
2 bolts for Cobra throttle cable bracket
2 clamps for air filter
Custom made pieces:
Tuning EGR delete
Coli pack bracket
Radiator hose
IAC relocation
IAC block off plate
Idler pulley setup
IAT relocation plate
IAT gasket
Shave off intercooler lip
Longer wiring for IAT relocation
For Sale:
Old November 9th, 2011, 11:57 PM   #17
walt1120's Avatar
04 Stang 1.0Gallon V6
14.45 @95.8
walt1120 has a spectacular aura aboutwalt1120 has a spectacular aura about
with a tune you can run 8psi all day long
2004 Bolt on & Cammed 3.9L V6
Threads Similar to: m112 adapter
m112 papemilio V6 Mustangs 2 June 2nd, 2010 08:06 PM
M112 on a 2V! Yes you Can!!!! ohcat68 99-04 14 May 2nd, 2008 09:16 AM
SSMS M112 Adapter+ M90? AJRight 2008 V6 Mustangs 14 January 21st, 2008 03:18 AM
