It's official: Mustang is in the Stable
Old November 11th, 2011, 10:47 AM   #1
dGrabber's Avatar
'00 Mustang V6
Slow but looks nice :p
dGrabber is on a distinguished road
So, was driving and my car kept overheating and such a horrible sound was produced somewhere under the hood. Had a loud rattle/clapping sound every time I stepped on the throttle. I do have a misfire, it's been happening ever since the misfire began. But, it's gotten worse and I've finally deemed it as unbearable and undriveable.
So, would a misfire really cause all of that? What could it be?
Also, since it'll be down, I want to work on it performance wise. What are some good suggestions for suspension and the engine?
I'm thinking of a Windstar upper intake, but what are some good struts, springs, and control arms?
Any and all help is appreciated!
Build Thread
Parts For Sale
Mods: 01 Cobra Bumper, GT Rear Bumper, Reverse Glow Gauges, Smoked Headlights, Smoked Fogs, Windstar Upper Intake, 8.8 Rear End, Drilled & Slotted front brakes, to be cont'd...
Old November 11th, 2011, 12:13 PM   #2
Dancing Naked In The Rain
mcqueen's Avatar
Rattling makes me think detonation. Detonation is most often caused by having your timing too advanced for the octane of fuel that you're running. Is your car tuned?
As for the misfire, that is directly related to air, fuel, or spark. Is your MAF working properly (possibly dirty?)? Spark plugs all gapped properly? Coil pack firing all cylinders? Spark plug wires all conducting? Fuel injectors clean and spraying properly? When was the fuel filter last changed?
My Hubpages
Hey.. r u really a tranny??
Old November 11th, 2011, 12:37 PM   #3
dGrabber's Avatar
'00 Mustang V6
Detonation is correct! Something in my mind thought it had something to do with the timing. I'm gonna tear it down and get to work on it. I have plugs to change em, the intake seems clean and fine. I am not tuned and will make sure of this once I get to it.
BTW, I haven't had it long, but I'm sure the fuel filter hasn't been changed.
Build Thread
Parts For Sale
Old November 11th, 2011, 12:58 PM   #4
mcqueen's Avatar
You can fill up with some 91 or 93 octane fuel and see if the detonation goes away. If so, your timing is either too advanced for whatever you were running or you might have gotten some bad gas. And a fuel filter is an easy change. $8 part, $10 tool. I've got a write-up for it here: How To Change Your 94-04 Mustang Fuel Filter
My Hubpages
Old November 11th, 2011, 04:50 PM   #5
dGrabber's Avatar
'00 Mustang V6
Awesome! I'll give it a shot!
Build Thread
Parts For Sale
Old November 13th, 2011, 01:45 AM   #6
Green_6er's Avatar
2000 Mustang 3.8
ehh w/e the mostly stock time is
Green_6er has a spectacular aura aboutGreen_6er has a spectacular aura aboutGreen_6er has a spectacular aura about
your fuel filter most likely hasn't been changed. Whenever i changed mine it still had the stock filter at around 133k.
Originally Posted by 6ER THEN I 8ER! View Post
If you don't scrape you did it wrong
Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK
How to paint your rims:
http://www.moddedmustangs.com/forums...ml#post3931042
Old November 13th, 2011, 11:15 PM   #7
dGrabber's Avatar
'00 Mustang V6
Spark Plugs changed so far.
Will get a new fuel filter ASAP.
Build Thread
Parts For Sale
Old November 15th, 2011, 11:49 AM   #8
dGrabber's Avatar
'00 Mustang V6
Fuel filter changed, Oil changed...
The issue persists. About the time the radiator fan kicks on, this clapping noise goes on somewhere in the engine which causes the car to overheat. Radiator components aren't the issue. I think my engine is bad or something.
Anyone can shed any light?
Build Thread
Parts For Sale
Old November 15th, 2011, 08:21 PM   #9
Jetflo's Avatar
2001 3.8L w/ 5spd
Jetflo will become famous soon enough
The radiator fan kicks on based on engine coolant temperature. If it overheats soon after, the overheating could be a stuck thermostat.
The clapping noise may be a separate issue. I'm a bit concerned you are looking at a head gasket. Can you confirm the following:
1. No water in the oil. Oil with water looks like foamy milk. You'd notice if this condition were present while doing an oil change.
2. No air in the coolant. With the radiator cap removed and the engine running (do this while engine is still cold), check to see if there is a breeze blowing out of the filler neck.
3. No oil in the coolant. If there is oil in the coolant you'll see a black oily "tub ring" in the overflow bottle just above the surface.
Please rule out the head gasket before proceeding. Coolant damages engine bearings quickly. The oil change was a good move. Confirming the head gaskets are good will allow you to rule this serious problem out.
I think your clanking sound could be valve related. Please take a section of tubing and hold one end to your ear like a stethoscope. Then hold the open end over the valve covers and see if you can pin point the source. Next, do the same thing along the oil pan.
Where is the sound the loudest using the stethoscope?
Thanks!
Are you absolutely certain you're not pregnant?
Old November 15th, 2011, 10:21 PM   #10
dGrabber's Avatar
'00 Mustang V6
Thanks!
1, 2, and 3 have been ruled out.
Build Thread
Parts For Sale
Old November 16th, 2011, 03:03 AM   #11
Jetflo's Avatar
2001 3.8L w/ 5spd
I saw your video and it seems loudest near the camshaft position sensor (a bit hard to tell). However, when mine went bad it caused a milder version of the problem you are seeing.
There are a lot of threads on "synchronizer". Here's an example:
Need to replace cam synchro. How much of a hurry should I be in?
Old November 17th, 2011, 11:06 AM   #12
dGrabber's Avatar
'00 Mustang V6
I got it to the fuel light coming on then got like 4 gallons of 91 octane fuel. So, I left it running in my garage, went in the house, came back out, and it was no longer running. Tried starting it a few times, it turns over, it pings, and it won't stay running for more than 2 seconds. So...???
But, it is throwing a code now.
P0171 System too lean.
Build Thread
Parts For Sale
Threads Similar to: It's official: Mustang is in the Stable
**Official V6 Modded Mustang Picture Thread** 6BangEr Pictures 200 August 23rd, 2011 07:27 PM
The official Darrell bought another Mustang thread 1slo5.0 The Clubhouse 21 June 30th, 2011 03:46 PM
Official Mustang Acronym Thread military_stang 99-04 21 June 23rd, 2011 01:41 PM
2011 Official Ford Mustang Calendar competition! membercalendars.com Modular Mustangs 8 December 8th, 2010 11:40 AM
Official: 2011 Mustang GT Debuts With 412-hp, 5.0-Liter V8 Administrator Modular Mustangs 15 January 5th, 2010 11:16 PM
