2001 v6
swap question
Guys my dads friend has this 5.0 motor that he will sell for 500 with the trans they have 80xxx miles nd i have a 8.8 rear in my garage waiting to be put on but wuld that be a stupid swap into my 01 v6? Nd if not wat else wuld i need for a swap? Any input guys thanks
your most likely at least going to need a new ECU, fuel system adjustments maybe, and some other things. i could only think of those two. haha.
2001 v6
But do u think its a good swap? I love the 5.0 lol
1 Wheel Peel
2000 Mustang 393w
2001 Mustang GT Vert
I'm putting a 351w into my 2000 "Sixxer" as we speak. It's essentially the same motor design.
Is it worth it? Yes, if money isn't an issue for you. Stock for stock it wont perform any better until you throw mods at it. My swap will be push 15 grand easy(But also not a stock motor) Parts needed. -All Electricals -K member -Driveshaft from a 94-95 -Driveshaft spacer if it is a pre 1994 transmission -Transmission mount. -Throttle cable -Clutch Cable -K Member(I ordered a tubular one for 425) -Bunch of other odds and ends What year motor and trans is it?
![]() 2000 393w Swapped Vert 2001 GT Vert 2002 Six Banger |
2001 v6
Thanks alot im gonna buy that motor nd get these pieces together nd do it after the winter lol but y da driveshaft from the 95 mustang?
2001 v6
You should post some pics of ur build nd goodluck with it
2001 v6
Nd its from a 91 mustang
1 Wheel Peel
2000 Mustang 393w
Okay these are your main issues to work on.
The shifter will sit about 5/8 inches forward so it will not align perfect in the shifter hole. There are two ways to address this. -Buy a 94-95 Bellhousing and input shaft -Cut the shifter hole bigger and run a tri-ax shifter to move the shifter towards you a little. Option B comes with a couple more drawbacks. Your transmission crossmember will not align perfect. You can modify it to work. The driveshaft will need a driveshaft spacer since the trans is 5/8 inch towards the front. You will need a driveshafter spacer from Steeda. I am buying a pre 94 trans as you are. I opted for going with the 94-95 input shaft and bellhousing. Either way you should be okay.
1 Wheel Peel
2000 Mustang 393w
The above statement is assuming your are putting a manual in.
Also if you are an auto swapping to a manual, you need a clutch pedal assembly
Threads Similar to: swap question
| quick question. fuel rail question on mark viii swap | Speedy1221 | 99-04 | 7 | October 12th, 2011 11:02 PM |
| ECU swap question | black02 | 99-04 | 1 | July 23rd, 2011 03:52 AM |
| 3.8 to 5.0 swap question | the84dream | 5.0 Mustangs | 3 | September 14th, 2010 10:28 PM |
| Another 5 lug swap question | black88 | 5.0 Mustangs | 4 | October 15th, 2008 03:41 PM |
| Question... 2.3 to 5.0 swap.... | BlueOval | 5.0 Mustangs | 9 | July 29th, 2007 10:06 PM |
