Manually Locking TQ Converter
Old May 29th, 2007, 03:26 PM   #1
Juggalo_X's Avatar
2001 Mustang 232/CBR600
14+@Slow
Do you guys see any gains in installing a switch to manually lock the TQ converter (engage the converter lock solenoid manually) this will allow the transmission to upshift but wont down shift untill the TQ is unlocked (the switch is off and the pcm controls the solenoid) this should add a little mor power in the power band range because if the converter is locked you will not lose any power from fluid drive. Also a possibility of Marginally improved Fuel millage keeping it locked untill you come to a sopt then you must turn the switch and allow the pcm to re take control other wise you will stall when coming to a stop if the converter is locked (like not putting in your clutch in a manual) What you guys think?
Old May 29th, 2007, 04:19 PM   #2
Juggalo_X's Avatar
14+@Slow
common some one here has to know something about tranny's to back up my theory.
Old May 29th, 2007, 04:46 PM   #3
2000 V6
ByPopularDemand is on a distinguished road
Send a message via AIM to ByPopularDemand Send a message via MSN to ByPopularDemand
I wish I knew how that worked cause my auto sucks...from what I've seen a tq convertor on auto LS1's helps out a lot
2000 V6 vert
Mac LT headers, Mac O/R H-pipe, Mac CAI, ASP 25% underdrive pulley(r.i.p), SCT tune, 8.8 rear and 4.10 gears.
Old May 29th, 2007, 05:58 PM   #4
Juggalo_X's Avatar
14+@Slow
bump
Old May 29th, 2007, 08:47 PM   #5
Juggalo_X's Avatar
14+@Slow
bump for a good question
Threads Similar to: Manually Locking TQ Converter
i cant find a full-locking posi 94pacecarSVT 94-95 1 July 1st, 2007 03:54 AM
ECTED, electronic locking re-end review. czwalga00gt 99-04 2 June 25th, 2007 10:19 PM
stg.8 locking header bolts Invictus 99-04 1 June 18th, 2007 05:07 AM
trq converter EAT the hp ? mow 2005 - 2010 8 November 27th, 2006 07:08 PM
Vapor Locking? blackhd 5.0 Mustangs 1 October 4th, 2006 04:27 PM
