questions
Old November 16th, 2011, 01:42 AM   #1
6ixer's Avatar
2000 mustang v6
14.6@99.68
6ixer is on a distinguished road
questions
(For those who have seen me post in the gt section(s) I'm stuck with a v6 for anotherr two years.. :/ )
1. I talked to the transmission's teacher at my college and he said my car/gears/rear end area is whining is due to pinion depth, and not because of the brand. How do you detemrn what is the right depth. Americanmuscle's install guide for the gt (was using tht guide for gt as refernce to work on the 6) did not say anything.
Who do I fix the depth
2. Sence I will be with my six threw my college days ,and I still have my cam stuff that I was thinking about selling them for $ to put toward my gt which I will no longer be needing to save for. So bottom line is I'm going to cam my car and IFFFF I got with the 4.2 do I need to change anything with the ecu/computer/harness or sence there the same block everything is fine I can just build the 4.2 and ""drop it right in"" and reconect everything no problem??
Or what do I need to know about switching to the 4.2
Its not comfirmed but its belived that I have a cracket head and if thts the case ima say the f with it and by a 4.2 long block
3. Sotck hood vs stock hood with hood scoop from am...what the take on tht/opinons
4. Lowing the car......? How many inches is...good/safe with out bottoming out?
Ported heads, comp cams cam, AM CAI, posi'd rear with 3.73 gears, flowmaster exhaust
Fixed clutch!!!!!
"My mustang likes a good ol' fashion bowl of rice....especially fried"
Old November 16th, 2011, 01:48 AM   #2
mustangmike!'s Avatar
2004,1994,1967
14.37 @ 96
mustangmike! is a jewel in the roughmustangmike! is a jewel in the roughmustangmike! is a jewel in the rough
go read my cam thread for 4.2 info. Or search it. Plenty of threads that clearly spell that process out.
227whp N/A V6
Now w/ 8th Mile 8s !
How To Jmod Your Late Model 4R70W
Old November 16th, 2011, 02:08 AM   #3
6ixer's Avatar
2000 mustang v6
14.6@99.68
...just tell me if I need to mod my computer/ecu or anything technically for the 4.2.
Fixed clutch!!!!!
Old November 16th, 2011, 02:23 AM   #4
Not Banned
southfour!'s Avatar
2000 Mustang V6
2000 Silverado 1500
southfour! is a glorious beacon of lightsouthfour! is a glorious beacon of lightsouthfour! is a glorious beacon of lightsouthfour! is a glorious beacon of lightsouthfour! is a glorious beacon of lightsouthfour! is a glorious beacon of light
Send a message via AIM to southfour! Send a message via MSN to southfour!
you will not have to mod the computer in any way
you will however need a tune to get the best performance
for example my H/C/I car dyno'd at 178 rwhp with no tune which isnt a hole lot over stock
H/C/I V6
BMC Member: 12521
Old November 16th, 2011, 02:33 AM   #5
6ixer's Avatar
2000 mustang v6
14.6@99.68
Thank you sir that's what I wanted to hear...so just drop tht 4.2 in and re connect everything and send her off to a dyno tune then?....
Why did urs not make more it should run very shity if no tunee...and I've seen several cammed v6 mustangs put mid 230s down at the wheels
Fixed clutch!!!!!
Old November 16th, 2011, 02:38 AM   #6
Not Banned
southfour!'s Avatar
2000 Mustang V6
2000 Silverado 1500
its running on the stock tune and running rich, it will be tuned in a month or so once its turbo'd. I didnt want to pay to tune it twice in less than 6 months
H/C/I V6
BMC Member: 12521
Old November 16th, 2011, 09:35 AM   #7
2001 v6 premium
xtreme 2 will become famous soon enough
Send a message via AIM to xtreme 2 Send a message via MSN to xtreme 2 Send a message via Yahoo to xtreme 2
already stated, but build it, drop it in, and tune it.
If you get the 4.2L, you will still need the Mustang intake manifold and the Mustang oil pan to be able to close the hood and fit the factory crossmember...
Screw it, coming to play with the big boys...
5.4L Vortech COMING SOON!
Old November 16th, 2011, 02:48 PM   #8
6ixer's Avatar
2000 mustang v6
14.6@99.68
Well id be getting a remanufactured 4.2 long block all I need is the mustangs upper/lower intake and the accary stuff like atl and a/c and water pump and then I can drop it in..I was gunna get it and use the stangs lower and use a windstar upper and drop it in
Fixed clutch!!!!!
Old November 16th, 2011, 04:22 PM   #9
1 Wheel Peel
GreenMustang00's Avatar
2000 Mustang 393w
2001 Mustang GT Vert
GreenMustang00 has a spectacular aura aboutGreenMustang00 has a spectacular aura aboutGreenMustang00 has a spectacular aura about
out?
Gears shouldn't whine because of the brand. Your teacher is correct. Ive seen rearends with tahoe, Ford Racing, Motive etc that didn't whine. It's just how meticulous you are when installing.
2000 393w Swapped Vert
2001 GT Vert
2002 Six Banger
Old November 16th, 2011, 04:35 PM   #10
2001 v6 premium
you will need the mustang oil pan as well.
Old November 16th, 2011, 04:38 PM   #11
2001 v6 premium
And since the 4.2L is internally balanced, you will either need the crank pulley from the F-150 or from an 01-04 Mustang.
I am not 100% sure, but something makes me think you will need an 01-04 Mustang Flywheel as well...
Old November 16th, 2011, 06:27 PM   #12
6ixer's Avatar
2000 mustang v6
14.6@99.68
Well the info on the engine says harmonically ballence.
I was gunna pull the 3.8 use parts from the 3.8 like the fly wheel...if I need and while the engine is pulled the clutch will be repplaced....and I'm gunna use the lower intake from the 3.8 put it on the 4.2 and windstaar it and cam it...
Fixed clutch!!!!!
Old November 16th, 2011, 11:27 PM   #13
2004,1994,1967
14.37 @ 96
your gonna spend 2000$ on a rebuilt 4.2 ? + shipping so closer to 2500 ?
Or last I looked its about that price.
Junkyard heaven, half the price for good shit I even spent a couple hundred extra to get even lower miles on my block (27k) still after shipping was 900$
227whp N/A V6
Old November 16th, 2011, 11:37 PM   #14
1 Wheel Peel
2000 Mustang 393w
2 grand i would buy a 4.3 stroker kit and be at the same spot in money spent. Lol
2001 GT Vert
2002 Six Banger
Old November 17th, 2011, 01:35 AM   #15
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to all
He is even crazier than you are~
Hi, You can call me Kyle
Random ESG fact: Had a prochamber on his v6 before it was popular.
WTB: v6 BBK valve covers
Old November 17th, 2011, 08:12 AM   #16
6ixer's Avatar
2000 mustang v6
14.6@99.68
Nope just 2250 I alrdy have an "out" for shipping
Fixed clutch!!!!!
Old November 17th, 2011, 08:53 AM   #17
2001 v6 premium
what year 4.2 are you planning to use? The one most people use are internally balanced like the 01-04 Mustangs.
Old November 17th, 2011, 07:23 PM   #18
6ixer's Avatar
2000 mustang v6
14.6@99.68
97/98 from an f150
Fixed clutch!!!!!
Old November 17th, 2011, 07:57 PM   #19
1 Wheel Peel
2000 Mustang 393w
So here is 2250 bucks better spent on the same motor
4.3 stroker kit 1800
4.2l oil pan 100
Balancing 300
Assembly is easy spleasy
You already have a decent cam. Gasket mach your heads and lower intake. Throw the windsor and 150 shot on that bitch.
Yes you can nickel and dime it to be a little more. But think about what really makes sense.
2001 GT Vert
2002 Six Banger
Old November 17th, 2011, 10:19 PM   #20
6ixer's Avatar
2000 mustang v6
14.6@99.68
The problem is my block is is some wat juunk some were the rust/or somthing is oxidizing and it s gettin in the collan system and its burning oil and coolant at the same time I was gunna get a refabed engine do heads and lower (port) deck the block and cam it all while its on anengine stand...and during the wkend pull and drop in and replace clutch when engine is out
Fixed clutch!!!!!
Threads Similar to: questions
Dual Fuel Pump Questions and Auto Trans Swap Questions.. Mustang46 99-04 9 October 12th, 2010 12:19 PM
A few questions... AMR91 V6 Mustangs 41 June 3rd, 2008 06:12 PM
Two questions.. whtpny The Clubhouse 13 May 29th, 2008 03:40 AM
Two Questions... matt0114 5.0 Mustangs 4 May 20th, 2008 12:00 AM
Questions about oil ItaliStang V6 Mustangs 10 March 26th, 2008 01:04 PM
