#21 |
14.37 @ 96
I meant dont add garbage to the new thread im trying to make a sticky. lol
Not this one. lol |
#22 |
50,000th MM Member
02 Mustang v6
idk
Just a quick thought before I start cutting my coils.
I have 16 inch wheels. Should I cut a fraction of an inch more?? |
#23 |
Skar Gone
1998 Mustang V6
17.27@76.66
No. Anything over 1.5 Inch and you might end up needing CC plates to get proper Alignment. =P
I MIGHT be mistaken though. as you can see, My Car still sits like a Pick Up Truck.
![]() 1998 5 Speed, CAI, Exhaust, Rear Seat Delete. |
#24 |
50,000th MM Member
02 Mustang v6
idk
Kool.
1.5 will have to do for now. Thanks |
#25 |
you'll be fine on 16's....that's what my old v6 use to rock on cut springs...
1.25 coils off the front and 1 coil off the back is my favorite setup |
#26 |
2001 cobra
^^ yes exactly! I cut a coil all around and I like how the back sits but I still want to cut another 1/4 coil off the front
![]() SVT all day! Next mods: Mickey thompson street radials, new wheels, gears and tuner, then turboed by 2013
#27 | |
Wax on, Wax off
![]() Black Bullitt Rims FT/FS Looking to Sell or Trade for Silver FR500s Looking to buy a lot of 99-04 Interior Pieces If you have any for sale, PM me |
#28 |
Formerly 01silversixer
2001 V6
15.47@89.57
are you bottoming them out?
#29 |
50,000th MM Member
02 Mustang v6
idk
I was going to start cutting my springs this week but be dad says ill just fuck up the way it rides because when you cut them you take away the part of the spring that allows them to sit flush
#30 | |
2000 GT 'vert
I cut mine about 1.5 years ago (i also installed new shocks and stuts). I cut them b/c I wanted to see how I would like the height in comparison to what the Eibach Pro-kit would do. To this day, the ride is still not bounces and nobody can even tell they are cut vs. new springs so the spring kit has always been a side project when it comes to other mods I'd like to do. Eventually I will replace the springs. Also, I had the car aligned after the install and am only SLIGHTLY out of chamber from spec. I will add that I also installed shorter struts / shocks from the fox body model. |
#31 | |
always..and i mean always...cut your springs so that they have the same end...this is one of the reasons some people fuck up on them....they don't cut them right |
#32 | |
50,000th MM Member
02 Mustang v6
idk
![]() but anyway, in this case, cutting straight through the spring should be fine or do i need to do any more adjustments after? just trying to make sure i dont have to digg into my eibach springs piggy bank faster then intended.
#33 | |
as for cutting it...i use a 4" angle grinder..no torch or anything like that...you don't want to heat them up. if your spring has a flat end before cutting..cut it so the end looks the same...if it's angled...then do the same finish. |
#34 | |
2000 GT 'vert
Threads Similar to: cut springs??
| Ford Racing P springs (1" drop) on stock struts/springs? | wrathchild | 2005 - 2010 | 5 | July 10th, 2011 05:11 PM |
| H&R SuperSport Springs or Steeda Ultralite Springs | CaptDeanSierra | 2005 - 2010 V6 | 4 | September 5th, 2010 12:07 PM |
| Summit springs Vs Ford C springs. Advice? | SlowNorth | 99-04 | 4 | May 3rd, 2010 01:44 PM |
| stock springs vs lowering springs in drag | TotoGT06 | 2005 - 2010 | 4 | April 14th, 2010 10:25 PM |
