Skar Gone
1998 Mustang V6
17.27@76.66
Spuddering Issues.. 3.8 V6
Welp, 1998 3.8L V6 with 101k Miles on her.
Spuddering a bit. Replaced Plugs and wires, A few months back, No problems; Ran great. Last week it started Spuddering while driving. Now it does it while Idling. I Pulled the Wires and Plugs, Checked them all, Re-Gapped them and cleaned it all up.. Put them back in. Done, No Biggie. Still, Spuddering. Tested Coil Pack, it wasnt putting out good power, So I replaced it. Still Spuddering... I always add Lucas when I fill up my gas. I always keep my oil at the right level, All Fluids Etc. Just added a CAI and exhaust a month before this started Happening, Probably not the reason.. I've checked for Vacuum; Its got good pressure.. Any Other Idea's? Probably going to my Mechanic on Monday.. Any Idea's would be great. ALSO: Spuddering is at its worst around 1500-2400 RPM 5Spd Manual
![]() 1998 5 Speed, CAI, Exhaust, Rear Seat Delete. |
2001 Mustang
Have not run official times
Maybe its your fuel filter clogging up. Just a thought. Happened to one of our cars I was like wtf then I pulled the fuel filter and tried to blow air through it and hardly anything went through. I changed it and our problem was solved.
2000 Mustang 3.8
ehh w/e the mostly stock time is
^ +1. i would change te filter and see where it stands from there.
![]() Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK How to paint your rims: http://www.moddedmustangs.com/forums...ml#post3931042 |
Skar Gone
1998 Mustang V6
17.27@76.66
Filter is Brand new. But I could always Pull/Check it anyways.. Good Thoughts.
2000 Mustang 3.8
are you sure it's spuddering and it isn't just your clutch slipping?
Skar Gone
1998 Mustang V6
17.27@76.66
The Spuddering is even at Idle in Neutral. Unfortunatly..
2001 v6 premium
if you had a tuner I would datalog. Surprising what it will tell you...
Sputtering (we aren't talking about potatoes with spuddering are we? LOL) is usually caused by too much air/not enough fuel. Do you have any exhaust leaks that could throw off your o2 sensors? Have you tried pulling them?
![]() Screw it, coming to play with the big boys... 5.4L Vortech COMING SOON! |
2001 v6 premium
I'd also clean the MAF with some dielectric cleaner... just to make sure it's not the issue.
Also, try unplugging the MAF while it's idling to put the system into open loop. Does this fix your idle issue?
Skar Gone
1998 Mustang V6
17.27@76.66
It doesnt do it at idle that I can see when the MAF is unplugged..
Dielectric cleaner in the morning FTW anyone? Lol
clean you iat sensor, and maf. i had an issue last year, and did the following. replace the fuel filter, cleaned the tps sensor maf sensor and the iat sensor too. its working great. while your there clean/ install a new air filter.
Skar Gone
1998 Mustang V6
17.27@76.66
IAT?
EDIT: Durp. OH, Idle Air Temperature Right? That is getting cleaned with MAF, Since I know its there.
Skar Gone
1998 Mustang V6
17.27@76.66
Cleaned them Both with MAF cleaner I just bought tonight to do so.
the MAF needed it BADLY.. The Silver wires were black.. Car runs better except for the Sputtering. It's even worse now. it HAS to be an injector Or Timing...
2004 v6 mustang
Vacum/header leak? It is getting colder and metals are condensing, would be more noticeable?
Skar Gone
1998 Mustang V6
17.27@76.66
Well, The past few days it has been a Mix of 40 Degrees all the way up to 70 and even nearly 80.
It does it the same no matter the temperature. ANYONE, Who has Editing skills.. Try to Point out where the Crank Position sensor would be on my car or explain it in detail? This is my last try before I hit my mechanic tomorrow..
Skar Gone
1998 Mustang V6
17.27@76.66
:U Yeah I noticed that but was too lazy to edit it a second time.
Lol
Threads Similar to: Spuddering Issues.. 3.8 V6
| What can cause high oil pressure & spuddering sound? | v6dave | V6 Mustangs | 8 | April 12th, 2011 10:32 AM |
| 00 gt spuddering | bubba32716 | 99-04 | 12 | July 20th, 2010 08:15 PM |
| Strange Spuddering Problem | free2.3 | 2.3 Mustangs | 10 | July 16th, 2010 03:29 AM |
| rough idle and spuddering | justin025 | 96-98 | 4 | February 18th, 2009 10:26 AM |
| spuddering when running | cuban5.0 | 5.0 Mustangs | 6 | March 8th, 2008 01:15 AM |
