Upgrades worth the money?
Old November 20th, 2011, 03:32 PM   #1
xBones is on a distinguished road
Ok so im looking to do some upgrades to my 6, looking to spend 500$ what should i look into (perfrmance based, HP)
96 v6 Mustang
Spintech single exhaust
More upgrades soon!
Old November 20th, 2011, 03:44 PM   #2
mustangmike!'s Avatar
2004,1994,1967
14.37 @ 96
mustangmike! is a jewel in the roughmustangmike! is a jewel in the roughmustangmike! is a jewel in the rough
if your an auto go to VMP tunning and get a tuner.
or
Do a real dual exhaust w/ Hpipe or Prochamber and flowmaster 40s dumped at the rear axle.
227whp N/A V6
Now w/ 8th Mile 8s !
How To Jmod Your Late Model 4R70W
Old November 20th, 2011, 04:06 PM   #3
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
There's a whole sticky full of threads you'll find useful
Look Here Before Asking About Mods in particular.
All can be found in Useful V6 Links
O o
/¯/______________________
\_\
Old November 20th, 2011, 04:17 PM   #4
sorry bout that thanks but ive heard a good cam is better way to go?
96 v6 Mustang
More upgrades soon!
Old November 21st, 2011, 09:52 AM   #5
2001 v6 premium
xtreme 2 will become famous soon enough
Send a message via AIM to xtreme 2 Send a message via MSN to xtreme 2 Send a message via Yahoo to xtreme 2
if you want to stay NA spend $350 getting your heads ported and then spend $150 doing a valvetrain rebuild, $100 on pushrods, and $200 on a cam and you will be at 230 hp with your exhaust.
If you want to boost, spend $3500 on an m112 kit and you will be at 320hp before you know it.
Screw it, coming to play with the big boys...
5.4L Vortech COMING SOON!
Old November 21st, 2011, 03:27 PM   #6
2004,1994,1967
14.37 @ 96
:slap
227whp N/A V6
Old November 21st, 2011, 04:00 PM   #7
2001 v6 premium
LOL, just saying... $500 doesn't get much performance... I guess I'd say buy a used tuner and install gears?
Old November 21st, 2011, 09:08 PM   #8
[{4114 K-73}]
Reaper_88's Avatar
2000 Mustang V6 Manual
Reaper_88 will become famous soon enoughReaper_88 will become famous soon enough
Now you are on the right track. If u get gears get 3.73s if u have a manual or 4.10s if you have an auto. Oh and get a t-lock as well
Note: 500 will only net you a tuner and maybe the gears (tuners are wat 350-380? Gears are around 150. Intsalling those gears is gona range on average at least 400 I believe.
Old November 21st, 2011, 09:39 PM   #9
Jetflo's Avatar
2001 3.8L w/ 5spd
Jetflo will become famous soon enough
There are other options for $500:
1. DIY used GT dual exhaust and take car to professional dyno tuner
2. Under-drive pulley and tuner
3. Get lucky and find a 3.55:1 8.8" rear end from a Mach 1 on CL
4. Get in an accident and use the $500 deductible to buy a GT
I started modding with a similar budget of about $500 and picked option #2. You'll probably find this is just the start too!
Are you absolutely certain you're not pregnant?
Old November 21st, 2011, 09:46 PM   #10
[{4114 K-73}]
Reaper_88's Avatar
You can also get a Windstar kit from VAP Auto. Nets you 7 rwhp and 15 ft/lbs of torque I believe.
Old November 21st, 2011, 09:49 PM   #11
[{4114 K-73}]
Reaper_88's Avatar
Wait my bad didn't realize you had a single port, scratch that.
Old November 21st, 2011, 09:51 PM   #12
Green_6er's Avatar
2000 Mustang 3.8
ehh w/e the mostly stock time is
Green_6er has a spectacular aura aboutGreen_6er has a spectacular aura aboutGreen_6er has a spectacular aura about
split port swap if you can find one cheap enough?
Originally Posted by 6ER THEN I 8ER! View Post
If you don't scrape you did it wrong
Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK
How to paint your rims:
http://www.moddedmustangs.com/forums...ml#post3931042
Old November 21st, 2011, 09:59 PM   #13
[{4114 K-73}]
Reaper_88's Avatar
^^^ This, probably one of the best mods to do to a sn-95 short of a power adder. Just keep an eye out for a deal
Old November 21st, 2011, 10:29 PM   #14
2004,1994,1967
14.37 @ 96
You guys are putting out un realistic numbers ...
To do a cam swap, you buy a cam and springs/retainers, then you gotta get supplies. If done cheap and work yourself 700ish for the whole cam project. Then you honestly need a tune, which requires you have a tuner.
Gears are only make sense to buy if you get a tlok as well, in that cause your also oging to need a bearing kit if your smart, the new oil and additive, and labor.
The cost adds up more then you think when you start modding.
I will say again, with your limit of 500
Either just start saving money till you can do a bigger project and give yourself time to research or do 1 of two things that either one will spend most of the 500.
Buy a tuner from VMP (sorry and no offense, but seems to be A Lot of tuning problems from bama on these V6s)
or
Have exhaust shop fab you up something, once again, fowmaster 40s and either Hpipe or prochamber. (prochambers are a bit expensive so idk about doing that under 500)
Honestly on a single port V6, might as well save your money, exhaust for the enjoyment of sound is what I really would reccomend ... not gonna get far with out a blower or turbo on a single port ...
227whp N/A V6
Threads Similar to: Upgrades worth the money?
is this worth the money jrock 99-04 8 April 27th, 2010 04:27 PM
CAI/RAI worth the money? vita 4V / SVT 15 April 1st, 2010 05:37 PM
CAI Worth The Money? RAGEman 99-04 26 December 16th, 2007 09:30 PM
Is it worth the money? whtpny General Tech 12 March 11th, 2007 10:26 AM
Is this worth the money? 00SoSlow V6 Mustangs 4 August 4th, 2006 03:12 PM
