Cost of lowering
Old November 21st, 2011, 04:56 PM   #1
94stangsc's Avatar
94mustangsc
94stangsc is an unknown quantity at this point
Cost of lowering
I want to lower my car by cutting the springs.I dont have the tools and will have to pay a local garage to do it,providing i can find one that will do it.What can i expect to pay.And do i have to have c and c plates to have it aligned
3.8 sc engine,ported heads,cam520lift,75mm TB,60lb injectors,10%pulley,flowmasters,80mmMAF,
Old November 21st, 2011, 05:37 PM   #2
2000stallion's Avatar
2000 Mustang
slow@slow
2000stallion will become famous soon enough2000stallion will become famous soon enough
id be suprised if a shop did that for you. But it doesnt hurt to ask around..I wouldnt worry about c/c plates
For Sale:
99-04 smoked tail light covers
Old November 21st, 2011, 05:54 PM   #3
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
I can't imagine that any legit shop will cut springs, nor can I imagine that it'd be any cheaper than buying a set of lowering springs and a basic craftsman handtool set and doing it yourself.
Don't get me wrong, I'm one of the guys that doesn't have a problem with the idea of cutting springs, but the reason you cut springs is because it's cheap (or there's no lowering springs available)... paying someone else to do the labor defeats the entire point.
O o
/¯/______________________
\_\
Old November 21st, 2011, 06:04 PM   #4
PsnSnake_19's Avatar
2001 cobra
PsnSnake_19 will become famous soon enoughPsnSnake_19 will become famous soon enough
^ yea that's a good point, and you will do fine without cc plates, and you need to get it aligned if it really needs it, I haven't got mine aligned yet because I haven't felt no reason to, it drives the exact same but then again I have different springs then you do so Idk in your situation
SVT all day! Next mods: Mickey thompson street radials, new wheels, gears and tuner, then turboed by 2013
Old November 21st, 2011, 06:27 PM   #5
MM's Official Lucifer
goren813's Avatar
'00 3.8L & '05 4.6L
Rev hit it on the head. Even if a shop would (I doubt any legit places would, esp. over the table) it would probably be just as much as getting a set of new springs.
CC plates aren't really necessary until about 1.5" lower. I'm about 1.75" lower (measured at side skirt) and I couldn't imagine life without CC plates. Check craigslist/Ebay, you may find a decent set of used springs. The install is not difficult, you don't even need a spring compressor (they actually make the job more difficult).
Old November 21st, 2011, 09:40 PM   #6
[{4114 K-73}]
Reaper_88's Avatar
2000 Mustang V6 Manual
Reaper_88 will become famous soon enoughReaper_88 will become famous soon enough
Cast and camber plates arnt necessary but it be a good idea to get them otherwise u risk wearing down your tires a lot faster than you'd think. Again not necessary but good to have
Old November 21st, 2011, 09:46 PM   #7
Green_6er's Avatar
2000 Mustang 3.8
ehh w/e the mostly stock time is
Green_6er has a spectacular aura aboutGreen_6er has a spectacular aura aboutGreen_6er has a spectacular aura about
only if you can't get the alignment correct.
Originally Posted by 6ER THEN I 8ER! View Post
If you don't scrape you did it wrong
Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK
How to paint your rims:
http://www.moddedmustangs.com/forums...ml#post3931042
Old November 21st, 2011, 09:51 PM   #8
[{4114 K-73}]
Reaper_88's Avatar
Its just a safe measure, as I said not necessary but can help
Old November 21st, 2011, 10:09 PM   #9
ag11hockey's Avatar
1999 Mustang V6
ag11hockey is on a distinguished road
you do need an alignment after. the caster is usually fine but the camber is the main problem when lowering. if you cut 1.25 coils off the front and 1 off the back (which is the most common amount) you need to get camber bolts and an alignment otherwise you can kiss your tires goodbye. and all you need are a few wrenches, jack, jackstands, and a metal hack saw or die grinder/cutting wheel. improvise lol.
Old November 21st, 2011, 10:44 PM   #10
2001 cobra
Do I need an alignment even if my car drives exactly the same?
Old November 21st, 2011, 11:04 PM   #11
[{4114 K-73}]
Reaper_88's Avatar
Yes. Your toe is fine which is why your car won't pull, however you camber isn't which, if you keep riding like that, your tires will be gone in no time
Old November 21st, 2011, 11:06 PM   #12
buy an angle grinder for $25 from a hardware store and you've got the tools now to cut your springs...
Old November 21st, 2011, 11:08 PM   #13
2001 cobra
Ight cool man thanks and my rear tires go in my fender, should i get spacers for that?
Old November 21st, 2011, 11:12 PM   #14
since you're running mach one wheels and not cobra wheels you will if you want to have it sit flush....a 1.25" hubcentric would do the trick...worked on my GT
Old November 21st, 2011, 11:14 PM   #15
[{4114 K-73}]
Reaper_88's Avatar
Depends, aesthetically it gives ur cobra's the look of having fat rears ( I got spacers they look pretty bad ass) but if you are lowered I'd say you shouldn't cuz u risk ur tires rubbing ur fenders wen u go over a bump. Can always be fixed by rolling ur fenders
Old November 21st, 2011, 11:14 PM   #16
Skar Gone
Skargon's Avatar
1998 Mustang V6
17.27@76.66
Skargon will become famous soon enoughSkargon will become famous soon enough
After I get my car running right and get this clutch put in, Spacers in the rear are on the top of my list of Visuals..
1998 5 Speed, CAI, Exhaust, Rear Seat Delete.
Old November 21st, 2011, 11:14 PM   #17
you might not have enough power to spin your back wheels adding that much weight
Old November 21st, 2011, 11:22 PM   #18
[{4114 K-73}]
Reaper_88's Avatar
Haha my 1.5s were like 5 lbs a piece... Heavy little bastards
Old November 21st, 2011, 11:22 PM   #19
2001 cobra
Yea my friend had some like 3/8 inch spacer but when I saw them I figured I needed more so ill get the 1 inch ones, do they sell them at any local auto part store and they shoudnt be more then $20 right?
It's weird my front ones are perfect but my backs don't sit flush and the back I only cut 1 coil of so it still has a good amount before hitting or scraping anything I think
Old November 21st, 2011, 11:25 PM   #20
[{4114 K-73}]
Reaper_88's Avatar
If you have 9s in the back 1.25s will sit flush as 6ER said. I have 1.5s and my tires only slightly pass my fenders (rear fender flares are wider than the front that's why ur rears arnt flush)
Threads Similar to: Cost of lowering
What should it cost? Huck 2005 - 2010 21 August 19th, 2011 10:52 AM
How much will this cost? af00stang 99-04 29 November 6th, 2008 10:56 AM
Cost to get to 600? ModMustang97GT 5.0 Mustangs 22 October 27th, 2008 02:03 PM
How much will all this cost?/. MustanG_guy17 V6 Mustangs 22 November 20th, 2007 04:04 PM
I wonder how much it would cost.. energiesource 99-04 1 October 20th, 2006 05:23 AM
