Air control valve 02 v6 stang
Old November 21st, 2011, 07:27 PM   #1
2002 v6 stang manual
Phoenix_23 is on a distinguished road
Question
Hi I was here last time asking bout the air control valve cuz my rpms kept stayin at 1 1/2 they told me to buy a new one I did but its still doing the same thing xan some one tell me y its still doing the same thing I got a new one from autozone
Old November 21st, 2011, 07:38 PM   #2
Green_6er's Avatar
2000 Mustang 3.8
ehh w/e the mostly stock time is
Green_6er has a spectacular aura aboutGreen_6er has a spectacular aura aboutGreen_6er has a spectacular aura about
what was on while it was doing this?
Originally Posted by 6ER THEN I 8ER! View Post
If you don't scrape you did it wrong
Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK
How to paint your rims:
http://www.moddedmustangs.com/forums...ml#post3931042
Old November 21st, 2011, 07:40 PM   #3
Nothing it was in neutral going 25 mph
Old November 21st, 2011, 09:22 PM   #4
00MustangGtPremium's Avatar
2000 Mustang Gt
no clue
00MustangGtPremium is on a distinguished road
How often does it do this and when?
Also it could be the idle screw. Inplug the IAC and see where the rpms are at. Then adjust if needed.
Just because your cars loud doesnt mean its fast
Old November 21st, 2011, 11:08 PM   #5
It does it all the time only when im driving & whats the idle screw wheres that at? Also whats iac mean ?
Old November 21st, 2011, 11:38 PM   #6
2000 Mustang Gt
no clue
The idle screw is the screw on the throttle body at stops it from closing all the way. What you need to do is unplug the connector at the iac and see what the rpms are. From there either turn the screw on the throttle body clockwise or counterclockwise to open (allow more air, raise rpms) or close (allow less air, lower rpms). The screw might be allowing the iac to open too much.
IAC is idle air control or idle air bypass.
Old November 22nd, 2011, 07:04 PM   #7
Like how while the cars on or what ?
Old November 22nd, 2011, 10:53 PM   #8
2000 Mustang Gt
no clue
yes while the car is idling
Old November 22nd, 2011, 10:55 PM   #9
Ok but what if at iddle it runs normal it does it only while the car is running not on iddle
Old November 22nd, 2011, 11:05 PM   #10
2000 Mustang Gt
no clue
When does it do it?
Old November 23rd, 2011, 05:10 PM   #11
While its in motion when its at iddle its normal today my rpms kept going up & down in neutral while in motion
Old November 24th, 2011, 06:32 PM   #12
2000 Mustang Gt
no clue
It sounds like a bad tps (Throttle position sensor). Its the black thing on the side of the throttle body. I found an article that will help you see the voltage at the tps and adjust it if needed
How To Adjust TPS
"Muscle Mustangs & Fast Fords"
April 1993
The throttle position sensor is one of those things that falls into the category of "computer stuff" that makes a big difference and is easy to deal with, but average people like us would never know about. Without the proper adjustment, the throttle position sensor (TPS) will give the computer a false reading as to the exact throttle opening. A false reading will limit wide open throttle performance (something we definitely don't want). A voltage reading must be taken using a digital volt/ohmmeter (DVOM) with the Key On/Engine Off and with the Key On/Engine Running. A Radio Shack DVOM, part No. 22-185A, works well for this job.
The TPS is located directly on top of the throttle body and is adjusted by loosening the two phillips mounting screws and swiveling the sensor until the highest reading is found. It may be necessary to elongate the holes with a small file to achieve the desired reading.
The spec range for Key On is from .88 to 1.0 volt; shoot for the .97 to .99 volt. With the engine running, the voltage should be no higher than 1.05 volts.
Incorrect Throttle Position Sensor (TPS) voltage will result in reduced performance. The best way to take a TPS voltage reading is by using two safety pins through the wires coming from the sensor. The positive lead is attached to the green wire, while the negative goes to the black wire. Always ground the meter through the sensor's black wire. This gives a direct, and more accurate ground into the computer.
Old November 24th, 2011, 07:00 PM   #13
Dam sound confusing...
Old November 24th, 2011, 07:13 PM   #14
2000 Mustang Gt
no clue
lol it could be for a beginner. As long as you read the directions thoroughly and know what everything is, it should be a piece of cake. You could also get a forum member in your area to help you
Old November 24th, 2011, 07:20 PM   #15
Do u know of any who know bout ths stiff that stays in phoenix,az
Old November 24th, 2011, 07:35 PM   #16
2000 Mustang Gt
no clue
I personally dont but either a mustang garage or a forum member in the area would be glad to help you out
Old November 24th, 2011, 08:38 PM   #17
Whta a mustang garage ?
Old November 24th, 2011, 08:51 PM   #18
2000 Mustang Gt
no clue
I mean a garage that specializes in mustangs. Im sure theres a few in Phoenix
Old November 25th, 2011, 12:26 PM   #19
Oh ok thanks
Old November 25th, 2011, 04:50 PM   #20
2000 Mustang Gt
no clue
sure thing bro. Thats why were here
Threads Similar to: Air control valve 02 v6 stang
idle air control valve jman214 99-04 8 August 14th, 2011 01:51 PM
Idle Air Control Valve 302stang 5.0 Mustangs 7 August 12th, 2010 02:36 AM
IAC control valve? Bam Bam Bigelow 5.0 Mustangs 2 July 4th, 2010 06:50 PM
Code P1443 Evaporative Emmision Control System Control Valve jagstang96 96-98 10 September 5th, 2006 07:26 PM
Purge Control Solenoid or Purge Control Valve fault kdevildog01 General Tech 3 July 17th, 2006 01:45 PM
