2000 V6 Stang
GT Hood Scoop with no grille?
ok so i bought an aftermarket GT style hood scoop for my v6 but it is open in the front, with no honeycomb grille. i've heard that without the grille air will fly up under the scoop, possibly causing it to fly off. it has one bolt on each side, and two in the back holding it on i think. could it really fly off at high speeds? i've only been up to like 60 since putting it on. so do i need to reinforce it somehow? and is there anyway to make a gt scoop grille fit on it? i really don't want the scoop to fly into my windshield going down the highway
2001 Mustang GT
9.30 @ 77mph-1/8th mile 2.2 60'
![]() iTrader: 3 reviews
I've heard of it happening. Try searching it on here I there's threads about it
01 GT. 5spd , 03-04 cobra clutch, on its 2nd 4.6l motor 2nd tr3650 too,JLT CAI,UPR o/r x, magnapack catback, predator tuned, H&R ss 10.5" bullitts w/ nt555r DR's
I'm doing it wrong
04 Grand Cherokee
If you bolt it down then it wont fly off. But regardless it will cause extra drag at highway speeds. Doesn't really matter though, even if it did have the insert I would still bolt it to the hood.
Formerly known as Demon_54 "I feel the same way about disco as I do about herpes." - Hunter S. Thompson
2000 Mustang 3.8
ehh w/e the mostly stock time is
strap going around the hood to hold it on?
![]() Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK How to paint your rims: http://www.moddedmustangs.com/forums...ml#post3931042 |
#5 | |
1 Wheel Peel
2000 Mustang 393w
2001 Mustang GT Vert
If it is bolted on you will be fine. Some people put a rod in where the honeycomb insert goes. Put something in the middle to avoid it from flexing if you want the added security
![]() 2000 393w Swapped Vert 2001 GT Vert 2002 Six Banger |
I'm doing it wrong
04 Grand Cherokee
Of course even with the insert it causes drag, just less than it would without it. But it really doesn't matter, never would be able to feel the difference.
Skar Gone
1998 Mustang V6
17.27@76.66
Cut a Hole in the Middle of your hood and make it functional for Cool air, And Viola.
![]() 1998 5 Speed, CAI, Exhaust, Rear Seat Delete. |
#8 | |
03 DSG GT
12.82@111.23mph
My honeycomb is drilled out and the hood was cut out
2003 DSG GT AUTOMATIC - 12.82 1/4 @ 111.23 mph ![]()
2001 Mustang GT
Just get a shaker
Dancing Naked In The Rain
That's a very expensive project compared to the $100-200 you'd spend on a GT hood scoop. Plus the CDC shaker looks like complete shit so the only route I would take would be a Mach 1 hood with the Mach 1 shaker setup. And that ain't cheap.
2002 v6
too slow
Arent the scoops bolted onto the hood from the factory.
![]() Sig by Tricep |
MM's Official Lucifer
They don't come on six's from the factory unless you get an package upgrade, i.e. Pony Package or the old Python kit.
I'd look for an insert if it were me. I doubt it'd break free from the bolts but that scoop filling with air at speeds will cause drag, and IMO doesn't look very good.
2000 V6 Stang
true.. i think it would look better with the insert, and i dont really want any extra drag. now i need to find a honeycomb insert, and see if it will work on this aftermarket scoop..
#15 | |
99% of people that do this regret it...you know where you coil pack is...know where the water during a rain falls on with a functional scoop...wanna guess how much dirtier an engine bay gets when everything can get onto it while driving. the only reason shaker kits work is because they route the air to the box and have water channels
#16 | ||
Run ur car, not ur mouth.
2003 Sonic Blue 4.6L
03 DSG GT
12.82@111.23mph
Wanna guess how much water actually makes it through the grill and into the engine bay? Ill give ya a hint...
Not much unless parked on an incline
Threads Similar to: GT Hood Scoop with no grille?
| How to convert Normal Hood Scoop to Functional Hood Scoop | Nameless | 2005 - 2010 | 20 | June 8th, 2011 12:36 PM |
| Wana remove the black incerts in my side scoop and hood scoop? | jrfan4life | Visual | 21 | February 16th, 2009 09:20 AM |
| Made my own hood scoop grille #2!! | amphibrecon | 99-04 | 14 | April 29th, 2007 05:23 PM |
| Made my own hood scoop grille!! | amphibrecon | 99-04 | 5 | April 28th, 2007 05:07 PM |
