v6 audio question
Old November 28th, 2011, 10:46 PM   #1
Run ur car, not ur mouth.
SON1C's Avatar
2003 Sonic Blue 4.6L
SON1C is a glorious beacon of lightSON1C is a glorious beacon of lightSON1C is a glorious beacon of lightSON1C is a glorious beacon of lightSON1C is a glorious beacon of lightSON1C is a glorious beacon of light
v6 audio question
i want to revert my audio back to stock, so after uninstalling my other audio (which 4 speakers run to 4 channel amp is a part of) i want to reinstall stock head unit (i have it but no wires) or otherwise purchase a basic headunit and put that in and then run the speakers to that
can i buy a wiring harness and id be good to go with my stock unit?
238rwhp/263rwtq
Drew's Build Thread
Old November 28th, 2011, 11:44 PM   #2
eleanorGT's Avatar
2001 Mustang 3.8
eleanorGT will become famous soon enough
why in the hell would you want to revert back to stock?? JC
Old November 29th, 2011, 12:25 AM   #3
he's selling the car...so lets try to help the question at hand before starting new ones
@steed43...a standard wiring harness will do just fine. just make sure it has the proper hookup for the back of your oe headunit if that's what your going with....any autoparts or even walmart will carry it for around $10-12
Old November 29th, 2011, 09:34 AM   #4
SON1C's Avatar
thanks ^
238rwhp/263rwtq
Drew's Build Thread
Old November 29th, 2011, 07:27 PM   #5
1996 mustang
jrs187 is on a distinguished road
if you are putting your stock radio back in it you should not need a wire harness for it there should be an existing one there to plug into it. if it has been cut off call around to stereo stores and ask them if they can order you in a factory radio plug so you can hook it up or go to a junk yard and cut theres off
Old November 29th, 2011, 09:43 PM   #6
SON1C's Avatar
i cant just use the $10 harness from any autoparts store?
238rwhp/263rwtq
Drew's Build Thread
Old November 29th, 2011, 11:40 PM   #7
AndyG47's Avatar
2002 Mustang V6
Slow
AndyG47 will become famous soon enoughAndyG47 will become famous soon enough
^^ Depends on what you have left in the dash. is it the factory plug or was it hacked up in the previous install?
_
2003 F150 - 5.4L V8 4x4 - 109K hard miles & still going FORD Tough----2002 Mustang 3.8L V6 - Currently undergoing "I'm not 17 anymore" demoding
Originally Posted by OneShotOneKill View Post
this thread has more fail in the first 5 posts than all of the "what exhaust?" threads in the v6 section.
Old November 29th, 2011, 11:46 PM   #8
don't worry man...even a factory style harness is cheap if you need one...i picked one up form a cartronics when i needed to put my dads truck back to stock when the previous owner messed it up.
Old November 30th, 2011, 12:53 AM   #9
Green_6er's Avatar
2000 Mustang 3.8
ehh w/e the mostly stock time is
Green_6er has a spectacular aura aboutGreen_6er has a spectacular aura aboutGreen_6er has a spectacular aura about
if the stock plug was cut off then i would find one from a website and order it.
Originally Posted by 6ER THEN I 8ER! View Post
If you don't scrape you did it wrong
Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK
How to paint your rims:
http://www.moddedmustangs.com/forums...ml#post3931042
Old November 30th, 2011, 11:42 AM   #10
SON1C's Avatar
quick google search brought up one from crutchfield for 20?
238rwhp/263rwtq
Drew's Build Thread
Threads Similar to: v6 audio question
A question for you audio guys... Applehead281 The Clubhouse 4 December 14th, 2010 03:43 PM
Car audio question! Please Help! Mustang_Visuals_04 Audio/Video 3 August 27th, 2010 11:36 AM
audio question volpestang 99-04 2 July 26th, 2010 12:39 AM
amp & audio question mustanginky Audio/Video 8 September 9th, 2009 11:36 AM
audio question hotrod Audio/Video 3 August 17th, 2006 01:35 PM
