Run ur car, not ur mouth.
2003 Sonic Blue 4.6L
locking doors issue
it started a yearish ago, for awhile my doors locked and unlocked every single time, but then i started hitting unlock and the lock would stick, it moves, but it doesnt unlock, like its stuck, i have issues with both sides, but more the drivers side (but idk this also gets a ton more use)
has anyone had this problem + fixed? |
The soul stealing Ginger
I have the same exact problem but on my passenger side, i can only guess that its the door lock actuator but have not bothered to replace it yet, I have gotten so used to jumping in and leaning over the seat to pull the handle. I will probably replace it soon now that im thinking about it.
Door Lock Actuator | 2001 Ford Mustang 6 Cylinders 4 3.8L SFI | AutoZone.com http://www.oreillyauto.com/site/c/se...ang&vi=1372632 Advance auto seems to be the most expensive here, depending on what you need it looks like its between autozone and oreillys, if you have one of those near you, |
2001 v6 premium
my wife's TSX had this same problem. Replaced it and fixed the problem. Now the other side is going out...
But yea, if you press the key fob and only one door unlocks, it's the actuator. You can pull the door panel off and try cleaning the connectors, but chances are that the unit is bad...
![]() Screw it, coming to play with the big boys... 5.4L Vortech COMING SOON! |
No idea, fairly sure that is the problem since when it moves that means it does have the power going to it, i have looked at the inside and all my connections appear alright, if i replace my soon ill pm you if it worked or not, xtreme, REPS for that lower price find.
Threads Similar to: locking doors issue
| Locking gas cap | pear0119 | 2005 - 2010 | 2 | August 8th, 2011 02:59 PM |
| brakes locking up | wolfeman04 | V6 Mustangs | 13 | June 13th, 2011 03:40 PM |
| locking gas caps | xXJayManZXx17 | 99-04 | 13 | September 2nd, 2010 01:27 PM |
| Weird Locking Issue | Pickettup | Modular Mustangs | 0 | May 27th, 2010 02:22 PM |
| got locking gas cap... | DeMello | The Clubhouse | 51 | July 20th, 2008 10:47 PM |
