Army Strong
It's a standard ^_^
Tail Pipe Rattling
What do I do? Check the hangers? theyre all intact. What are my options to cure my problem, it effin annoying.
![]() To the windowssss(/-_-)/ To the wallllll \(-_-\) Check this thread out! http://www.moddedmustangs.com/forums...pics-here.html
The soul stealing Ginger
what kind of headers do you have? trust me it could be relevant.
1999 Mustang V6
might be the heat shields on the catalytic converters. check to see if those are loose.
iPoopke Regular
2004 Mustang
Also, do you have an aftermarket cold air intake?
Army Strong
It's a standard ^_^
Long tube. Also I indeed have a cai
My longtubes are touching my starter, vibrating against it causing a rattle that 3 shops identifyed as a broken exhaust hangar, then one pried it away from the starter and it stopped! then came back as the pipe moved back over.
iPoopke Regular
2004 Mustang
Just wanted to make sure it was for sure your exhaust, otherwise your CAI could be rattling too. I know mine was, the rubber bushings werent completely pushed into the body.
To let you know as well, when my longtubes rattle against the starter, the sound is thrown to the back so it sounds like its back there unless your up on it.
Army Strong
It's a standard ^_^
Pretty much when I'm in first and about 1500rpm I let of the clutch to stop that sound from happening
also check the over axle tubing next to the gas tanks...some shops put them too close to the tank and and lower rpms it causes it to tap the tank shield....i had that issue and had it fixed by a hanger readjustment
Threads Similar to: Tail Pipe Rattling
| gas from tail pipe | jman214 | 99-04 | 3 | September 19th, 2011 09:36 PM |
| tail pipe question? | starin | 96-98 | 4 | June 20th, 2010 07:27 PM |
| Put your tail pipe between your legs and..... | DarkCandy08GT | The Clubhouse | 157 | March 12th, 2009 12:32 PM |
| Tail pipe cleaning | Archy88 | Visual | 1 | August 28th, 2008 02:29 AM |
| x pipe rattling? | xalexg212x | 2005 - 2010 | 9 | June 24th, 2008 02:59 AM |
