'00 Mustang V6
Slow but looks nice :p
In Need of Suggestions
So, my car has been throwing me ridiculous pinging issues. Thus, I've began tearing my engine down to inspect my cylinders if it's crazy carbon build up or simply shot.
Last thing I did today was remove the fuel rail. Plus, my injectors are clean but manifolds are gunky in a couple places. Nonetheless, since its getting torn down, what are some good mods for our motors? I have a windstar upper in my mind, but what else would be good for a decent V6?
![]() Build Thread Parts For Sale Mods: 01 Cobra Bumper, GT Rear Bumper, Reverse Glow Gauges, Smoked Headlights, Smoked Fogs, Windstar Upper Intake, 8.8 Rear End, Drilled & Slotted front brakes, to be cont'd... |
Formerly 01silversixer
2001 V6
15.47@89.57
Cam.
I might have a windstar for you if I buy the m112 setup my friend said he might be getting. |
#3 | |
'00 Mustang V6
What's a decent, but not crazy sounding cam? I've only really heard those crazy 218/226 duration w/ .5 lift. I'm debating if it will be worth it really for my stang.
[8MINUS2]
You tried swapping the coil pack before tearing down yes?
Depending how far down your going you could do H/C/I or you could just cam it.
#5 | |
'00 Mustang V6
Also, I didn't swap the coil pack, the pinging has been so bad that I want to make sure it hasn't damaged my engine. I'm set on the Windstar upper though, so H/C/I might be the best bet for me.. unless...
'00 Mustang V6
I see a cam in the near future!
'00 Mustang V6
Got this far...
![]() Question: Where are the engine block coolant drain plugs/bolts?
2001 v6 premium
No cam REQUIRES head work. some will require new valvesprings and pushrods, maybe that's what you meant?
![]() Screw it, coming to play with the big boys... 5.4L Vortech COMING SOON! |
#9 | |
'00 Mustang V6
14.37 @ 96
< Has a spare cam of the same spec you posted, and a PR length checker. This means you can buy, Ill tell you what springs/retainers to get for it, then you install stuff back together, measure what size PR's you need. Buy if needed. Install things.
Im sure if you dont want something that loud you should know that you need high flow cats/ O/R exhuast. On a stock exhuast w/ 4 cats even with a good cat back design, it will still be quiet becasue of the 4 cats.... damn those things. Good chance things mine run a bit ruff, might be fairly smooth. Never know, varies car to car, but you a email tune from VMP w/ a hand held tuner would be smart, Dyno tune even better.... |
MM's Official Lucifer
No need to drain coolant from block/engine. Drain what you can from the coolant hoses, even when you get down past the heads you won't be leaking anything, you'll be right above the runners where the coolant sits.
As far as what mods...it depends on how deep your wallet is.
#12 | |
'00 Mustang V6
I actually have a couple connections + a shop that hooks me up. So, the car will only see miner mods like H/C/I. Pocket ain't too deep and I won't spend too much time on it, but I'll possibly tackle the body and paint this coming spring. BTW, I was inspired by your vids on youtube.lol @goren Thanks man! What I needed to know! Reps
2001 V6
15.47@89.57
screw visual inspection ^ lol
'00 Mustang V6
2001 V6
15.47@89.57
I don't have cats and have a visual...oh well lol
'00 Mustang V6
Have you ever taken it in ever since the LT's and no cats?
#17 | |
2001 v6 premium
14.37 @ 96
Fake cats FTW -_-
'00 Mustang V6
'00 Mustang V6
Update:
![]() Lower Intake and Water Pump is off next. Then Headers, and heads. Hoping the Cylinders and Pistons are fine. Then, the fun begins!
Threads Similar to: In Need of Suggestions
| Need suggestions | mustang95 5.0 | V6 Mustangs | 12 | August 21st, 2009 10:54 AM |
| Suggestions on what to do | Bar2dabone | 5.0 Mustangs | 7 | August 5th, 2008 06:59 PM |
| cam suggestions | jam77 | 5.0 Mustangs | 24 | October 16th, 2007 09:32 PM |
| In need of some suggestions | Archy88 | General Tech | 29 | October 15th, 2007 09:58 AM |
| any suggestions | HMUSN | The Clubhouse | 24 | April 29th, 2007 06:08 PM |
