MM's Database Error
dome light..
ok so i've noticed that my dome light staying on sometimes now since it is gettin hot, obviously this poses a problem..why is it doing this? if i ride and cool down things on the inside of the car it turns off but like today i went to the car after work and i saw that the light was on b4 i opened the door and it stayed on half way home then cut off. i remember someone saying somethin bout this a while back but i didnt see it on the search, help me out
![]() I'm trying to get rid of this stuff, feel free to make me an offer!: SCT Mass Air Flow Sensor $200 Tial Wastegate Springs $40 (10psi and 3.6psi) |
¡ʇsnq ɹo uʍop ǝpısdn
try getting a new bulb and see if that fixes things its like two bucks at the parts store
MM's Database Error
no its not the bulb i already know that...
has anyone had this problem b4??
nope i had a faulty plug in deali-o... the prongs that hold the bulb were weak... so i worked with them for a while... but nothing helped
#5 | |
it happened to me like 2 times I only put the ignition in on position then off(without turning on the engine) and never happen again try it maybe it will fix it. it fixed mine
MM's Database Error
i'll try but im not sure that'll fix it
#7 | |
ok but then.. thinking of it it may be a circuit or something that has to be ummm... I know what it may be but not sure with my old mirage my driver sensor got busted and my ligth was turn on all the time and also the open door signal
MM's Database Error
well i would say its a busted sensor but the only thing is, is this only happens when it gets really hot outside...
#9 | |
very strange wll in man i didn't notice if it happen cause the heat... well these days it been a hot weather and the thing happen to me on these day could it be also heat related wel idk.... u made me think of so many things lol
yeah mine does the same thing...i just got frustrated and took the bulb out...but when i was at circuit city they said sometines the alarm triggers it to stay on.
do u have an aftermarket alarm? |
Its obviously the Door jam switch that activates the light when the door is open guys. replace the switch its the humidity and just wear and tear that has caused its down fall.
MM's Database Error
how do i go about doing that?
#13 | |
MM's Database Error
well i dont think its that easy on a mustang, they dont have the little pin things , theres no visible sensor that i see in there. but might i remind u that this only happens when its hot outside. so that makes me think its not the sensor thing
#15 | |
MM's Database Error
again...how, i have no clue what it looks like on the stang, only thing that looks like is in between the door and the body is the hinges and the wire loom thing
#17 | |
MM's Database Error
great, where would that be and what does it look like
#19 | |
Ok dude remove the door panal and look at the latching mechanism its the only electrical connector on it thats the dome light/door ajar sensor. unplug it and remove it and then try cleaning it and then lube the latching system with super lube. then reinstall
Threads Similar to: dome light..
| light bulb in dome light | myeleanor | 2005 - 2010 | 7 | August 31st, 2007 03:34 PM |
| LED dome light | gooberhead320 | V6 Mustangs | 14 | July 12th, 2007 04:24 PM |
| Dome light? | dmachine22 | 99-04 | 5 | April 19th, 2007 08:53 AM |
| How you can change your dome light color. (light on roof) | SonicStang | Visual | 25 | March 23rd, 2007 12:39 PM |
| Dome Light | 97CobraSvt | 96-98 | 2 | October 19th, 2006 12:20 PM |
