2002 v6 stang manual
Cleaning sensors ?
How do u clean the idle air control valve ? & can I clean it wit maf ?
![]() iTrader: 1 reviews
Yes, though some swear by brake cleaner and stuff to clean it just that extra bit. I cleaned mine two days ago, pretty simple and used CRC MAF cleaner. Works alot better now, very stable idle.
Two 8mm 5/16 bolts and make sure not to drop the gasket. http://www.muscularmustangs.com/iac.php |
Do do I spray it right on the sensor?
2001 Mustang 3.8
yes.. right on the sensor itself.. dont hold the can right on top of it.. but keep a good foot foot n a half between the can and the sensor.. the last thing you want to do is damage the sensor by trying to clean it.
2001 v6 premium
There is no sensor...
Douse the crap out of the springs in there. Keep spraying until the fluid drains out clear...
![]() Screw it, coming to play with the big boys... 5.4L Vortech COMING SOON! |
2001 Mustang 3.8
Da one link help but my rides engine a lil different
2001 v6 premium
That's not the Idle Air Control, that's the Throttle Position Sensor...
2001 Mustang 3.8
Yes.. but if that sensor is dirty, it can affect the idle just as much as a dirty throttle body itself.. also u shjould never sprey into the throttle body.. unless its off the car.. always spray onto a rag, then wipe!!
2001 v6 premium
who said anything about spraying into the throttle body?
Y not into the throtle body ?
2001 v6 premium
it won't do anything negative. If you spray too much it can saturate the heads, but it burns out after a few cranks. Nothing bad will happen.
Ku so I dnt have to remove it to clean it or would it be better ?
2001 v6 premium
Yes remove it. It's far enough back in the throttle body you can't get to the parts that need to be cleaned...
I cleaned it it worked but still stick a lil
2001 v6 premium
you got all the gunk off the spring?
What is it doing that makes you think it is sticking?
Threads Similar to: Cleaning sensors ?
| O2 sensors | jjwoody | 5.0 Mustangs | 0 | October 16th, 2010 03:18 AM |
| Cleaning Sensors Question | nHuman | 96-98 | 0 | September 27th, 2008 06:37 PM |
| o2 sensors help | tyzride | General Tech | 2 | August 19th, 2008 06:37 PM |
| Really Quick Question (Cleaning 02 Sensors) | Onemanzu | The Clubhouse | 2 | November 21st, 2007 11:01 PM |
| Cleaning O2 sensors | cobralini | 5.0 Mustangs | 4 | September 21st, 2006 08:13 PM |
