Drive shaft has some play, what is this?
Old December 10th, 2011, 03:56 PM   #1
WhiteShadow's Avatar
2001 Mustang V6
WhiteShadow will become famous soon enoughWhiteShadow will become famous soon enough
Send a message via AIM to WhiteShadow
Exclamation
So I've been thinking my U joints were going bad, but after thorough inspection They are perfectly fine. when i grab the drive shaft and try to move it, it moves a little back and forth. It seems as though the whole thing rotates, including the yoke into the transmission, not just the driveshaft inbetween u joints. anyone have an issue like this or know if this could be the cause of my clunk i get whenever i come to a stop and feels like a hard downshift but isnt the car shifting?
any help is appreciated
Whiteshadow build Thread
Updated 4/10/2012
Divorced Dual Borla Stinger Exhaust Catback Video
Old December 10th, 2011, 04:15 PM   #2
mustangmike!'s Avatar
2004,1994,1967
14.37 @ 96
mustangmike! is a jewel in the roughmustangmike! is a jewel in the roughmustangmike! is a jewel in the rough
could be tranny or diff
227whp N/A V6
Now w/ 8th Mile 8s !
How To Jmod Your Late Model 4R70W
Old December 10th, 2011, 06:20 PM   #3
2001 Mustang V6
yeah forgot to mention, it felt as though when i would turn it, it would be stopped by the rear diff. but like it would tick either way i rotated it. so idk if its something with the tranny or diff. i was hoping someone would know if i could tell somehow.
Updated 4/10/2012
Old December 10th, 2011, 06:46 PM   #4
Macunicorn's Avatar
Macunicorn will become famous soon enough
It is from the tailshaft from the tranny is prolly a wore out tailshaft bushing.
Sig by Tricep
Old December 10th, 2011, 07:17 PM   #5
2001 Mustang V6
just looked up some info on this and this could be right. if im leaking a little out of the tailshaft seal does that mean a mad bushing? i noticed right before the driveshaft and the furthest tail end it drips onto my driveway, and the fluid is red, just like my tranny fluid. so does this confirm a bad tailshaft bushing ?
Updated 4/10/2012
Old December 11th, 2011, 04:34 PM   #6
2001 Mustang V6
anyone ?
Updated 4/10/2012
Old December 13th, 2011, 04:05 AM   #7
StoneColdStang can only hope to improve
I get a clunk to coming from the back when i shift into reverse and sometimes drive.
If I keep the brakes applied until it fully shifts then I wont hear the clunk.
What is it?
Old December 13th, 2011, 11:36 AM   #8
2001 Mustang V6
What is it?
if its coming from the back, and braking helps it, your gears could just be worn in the back and need replacing. whats your mileage and do you have an auto?
it could possibly be a u joint issue as well, but since braking helps, im leaning towards the differential.
Updated 4/10/2012
Old December 13th, 2011, 11:47 AM   #9
The soul stealing Ginger
dgt_mustang's Avatar
2001 Mustang 3.8l
dgt_mustang is a jewel in the roughdgt_mustang is a jewel in the roughdgt_mustang is a jewel in the rough
Send a message via AIM to dgt_mustang Send a message via Skype™ to dgt_mustang
when you said you get a clunk, i was reminded of a buddy of mine who was missing teeth in his rear end. might want to check that, if nothing else it could provide a good time for fluid change.
Get another job, get 2 more jobs, get your own place, work, live, fuck, eat, life, happy.
Old December 13th, 2011, 11:51 AM   #10
automatic 153k miles its kind of random the clunk noise from the back, I thought it was the u joint as well.
Anyway to do a quick check?
Old December 14th, 2011, 12:00 AM   #11
2001 Mustang V6
throw your car up on some jackstands and go under there and see if the driveshaft has play at all and visually inspect the u joints. (front and back of shaft) and look at the placement and rubber bushings. if the driveshaft has any play, it could be the u joints.
the really quick and honestly only way to check the diff is to have the car jacked up on stands again and drain the diff fluid, remove the cover, block the front wheels, and inspect the pinion and gears, as well as release the hand break and inspect the inner gears as well.
if all that sounds too complex. just pay a shop to take a look.
Updated 4/10/2012
Old December 14th, 2011, 08:16 AM   #12
eleanorGT's Avatar
2001 Mustang 3.8
eleanorGT will become famous soon enough
What is it?
Depending on your "clunk" that is normal, because it takes alot of force to engage and disengage the reverse gear, the way the spring is positioned inside the transmission.. the reverse gear is a small gear with about 10 heavey thick teeth, so there hard to chip.
Old December 16th, 2011, 09:18 PM   #13
My handheld emergency brake does not work. i can still drive with it engaged but then again I dont see why I would need to use it.. My car is automatic
Old December 17th, 2011, 03:11 AM   #14
2001 Mustang V6
1. check your brake fluid
2. check your pads
other than that im not a huge brake expert haha. i've never had problems with any of my brakes since all i use is the gas pedal
Updated 4/10/2012
Old December 17th, 2011, 08:26 AM   #15
6ixer's Avatar
2000 mustang v6
14.6@99.68
6ixer is on a distinguished road
The the brake cable too lol my autos cable was rusty and worn/loose lol...giggity
Ported heads, comp cams cam, AM CAI, posi'd rear with 3.73 gears, flowmaster exhaust
Fixed clutch!!!!!
"My mustang likes a good ol' fashion bowl of rice....especially fried"
Threads Similar to: Drive shaft has some play, what is this?
ProCharger P1SC Shaft Play? DiZzyBonne General Tech 2 October 27th, 2009 07:38 AM
crank shaft end play superbeef1000 99-04 1 January 11th, 2008 09:01 PM
drive shaft shop one piece steel shaft ok for automatic tran mustang fanatic 2005 - 2010 8 September 24th, 2007 01:21 AM
drive shaft GT33 2005 - 2010 9 September 8th, 2007 02:35 AM
drive shaft ? Drgnracin72 99-04 2 April 13th, 2007 10:26 PM
