LinkBack | Thread Tools |
#1 |
Resident badass
T56 or T6060
Any info on a 6 speed on a 3.8?
I've seen a 4.0 with a T6060. I don't know if I should rebuild my T5 (stronger of course) or go with and extra gear and it be a bit stronger. I want a bit my fuel economy. Really what I'm asking is, how can I get a 6 speed in my car.
![]() 271rwhp N/A V6 ![]() The Name is Danny. I'm a GM Technician. Suck it. |
| Sponsored Links | |||
Advertisement | |||
#2 |
Formerly 01silversixer
2001 V6
15.47@89.57
![]() ![]() ![]() iTrader: 1 reviews
I think someone on v6 power did a t56 but it was really expensive
#3 |
[8MINUS2]
Its not fun, and its really not worth it...
Other than saying "hey I have a t56/6060 in my v6"
![]() Hi, You can call me Kyle Random ESG fact: Had a prochamber on his v6 before it was popular. WTB: v6 BBK valve covers |
#4 |
2001 V6
15.47@89.57
can you build a t5 to handle any kind of decent power?
#5 |
04 Stang 1.0Gallon V6
14.45 @95.8
![]() ![]() iTrader: 2 reviews
you can use the same bellhousing that is used to hook up a t-56 to a 302w. search google and youll find it.
2004 Bolt on & Cammed 3.9L V6 |
#6 |
14.45 @95.8
any kind? no, but probably more than most v6 mustangs will ever be making
#7 |
Resident badass
Well I might be going turbo if kyle will ever get back to me. But I might built the T5 stronger. I got a quote for around $440 for a master OH kit, and billet keys. Apparently good for 350lb.
#8 |
1996 Mustang 3.8
What about the m5od? It came on the super coupe's so it should be able to handle some power. Similar engine to the Mustang's so it should be able to bolt up, right? But I'm just speculating, I've never tried it.
Ever see a lion limber up before it takes down a gazelle?
Mods: ProChamber & Mac Flowpaths 8.8 rear w/ 3.55 gears WTB Mac Tail Pipes PM ME |
#9 |
2001 V6
15.47@89.57
can you get a t5 built to handle like 500?
#10 |
Resident badass
I'm sure a TKO can. But what I'm building it to will be enough for what the engine should be putting out.
Anyone know of a good clutch that can hold up to about 350FWHP?
#11 |
1 Wheel Peel
2000 Mustang 393w
2001 Mustang GT Vert
![]() ![]() ![]() iTrader: 4 reviews
Locally we have seen t5s take 600 plus horsepower with bone stock components. Granted they are the world class t5s but same concept.
![]() 2000 393w Swapped Vert 2001 GT Vert 2002 Six Banger |
#12 |
Resident badass
Ours are world class too.
#13 |
MM's Barbarian
1996 V6
17.31@85
![]() ![]() iTrader: 0 reviews
What about this?
G-Force Transmissions and Long Shifters Or if you're pretty tech savvy (seeing that you're a GM Tech) G-Force T5 Transmission Gears And Mainshaft Upgrade Kits - JEGS
"I'm not going to sit here and take this defeatist attitude and listen to all this crap any more from all these people who have nothing but doomsday to predict." Carroll Shelby |
#14 |
Resident badass
Those are 5 speeds. I have a 5 speed. I want a 6 speed. I am rebuilding my T5 if I do not go with a six speed.
#15 | |
MM's Barbarian
1996 V6
17.31@85
I'll go look for a 6 speed now.
#16 |
Resident badass
I know where to get a 6 speed. I need to know how to make it work.
#17 |
2002 Ford Mustang
The TR6060 takes quite a bit of clearancing to fit, the T56 fits no problem. Easiest way to do it is find a wrecked 03-04 Cobra being parted out. Get the transmission, crossmember, shifter and driveshaft. Optionally you can get the trans. harness, clutch cable, etc. to make it a little easier. You'll have to use a SBF/T56 bellhousing of course, I know Quicktime makes a couple that would work, only differences being where the clutch fork is clocked. Wiring differences between the T5 and T56 are easily sorted out also. The only thing i'm not sure of is getting the clutch and flywheel correct. I've done alot of swaps, but never a 3.8/4.2 to a T56. You may try calling D&D Perf. and they may be able point you in the right direction.
#18 |
[8MINUS2]
I would just do a tko swap (oddly enough I have one in the garage)
Anyway Chris Torres (remember him?) he broke his gforce twice I think with his car lol... But then again he ran the piss out of that thing.
| Sponsored Links | |
Advertisement | |
