pinging in the engine?
Old December 11th, 2011, 02:34 PM   #1
Army Strong
Xzavier247's Avatar
It's a standard ^_^
Xzavier247 is on a distinguished road
There's a slight ticking noise coming from the engine it gets faster when the rev is up. Any suggestions?
To the windowssss(/-_-)/ To the wallllll \(-_-\)
Check this thread out!
http://www.moddedmustangs.com/forums...pics-here.html
Old December 11th, 2011, 02:41 PM   #2
Modded V6
Stang6899 is on a distinguished road
Crack in the exhaust manifold.
1999 e46 328i BMW - Daily Driver
2001 SVT Cobra - Project
1995 v6 vert - SOLD
1996 v6 vert - SOLD
1995 v6 vert #2 - SOLD
1995 GT - SOLD
1997 v6 coupe - Parting
Old December 11th, 2011, 07:06 PM   #3
MM's Official Lucifer
goren813's Avatar
'00 3.8L & '05 4.6L
+1 get your mid pipe then manifolds off and inspect them. Most likely passenger side, but check both.
Old December 11th, 2011, 08:54 PM   #4
Army Strong
Xzavier247's Avatar
It's a standard ^_^
Thanks guys I knew it had something to deal with that, During the ice storm couldn't get over the speed bump then when I did WHAM I hit it it hard plus my car is lowerd
Old December 11th, 2011, 09:01 PM   #5
Army Strong
Xzavier247's Avatar
It's a standard ^_^
Also would it cause any problems to the engine is it safe?
Old December 11th, 2011, 09:32 PM   #6
MustangV6Man? can only hope to improve
Maybe it's coming from a pulley and you think it's the engine? I'd try some 91 octane and run that through, see if it helps. Sounds like a timing issue.
Old December 11th, 2011, 09:48 PM   #7
Green_6er's Avatar
2000 Mustang 3.8
ehh w/e the mostly stock time is
Green_6er has a spectacular aura aboutGreen_6er has a spectacular aura aboutGreen_6er has a spectacular aura about
it is safe for now. but if you let it get worse it can start to throw wrong codes to the computer and cause your car to run like trash
Originally Posted by 6ER THEN I 8ER! View Post
If you don't scrape you did it wrong
Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK
How to paint your rims:
http://www.moddedmustangs.com/forums...ml#post3931042
Old December 12th, 2011, 01:10 PM   #8
goren813's Avatar
'00 3.8L & '05 4.6L
Do not do this.
Old December 12th, 2011, 01:12 PM   #9
goren813's Avatar
'00 3.8L & '05 4.6L
You'll be losing a bit of back pressure, probably not enough to cause damage to anything else. You'll be losing fuel mileage, which only hurts your wallet. Over time the crack will grow, so these symptoms will only be getting worse, until one day "BOOM" and it will completely separate and sound like a tractor.
Not hard to get the exhaust stuff off. Machine or exhaust shop will weld it back up for $25-$40.
Old December 12th, 2011, 01:29 PM   #10
2001 v6 premium
xtreme 2 will become famous soon enough
Send a message via AIM to xtreme 2 Send a message via MSN to xtreme 2 Send a message via Yahoo to xtreme 2
Haha, mine did this over the summer, kept thinking it was a lifter then one day BOOM! worst 15 mile drive home from work ever, lol.
Only thing it will do is over time the crack will grow and it can throw off your o2 sensors causing you to run rich.
Let us know how it ends up....
Screw it, coming to play with the big boys...
5.4L Vortech COMING SOON!
Old December 12th, 2011, 06:10 PM   #11
Army Strong
Xzavier247's Avatar
It's a standard ^_^
Well I was thinking about buying new headers like shorties, are bbk shorties good?
Old December 12th, 2011, 06:13 PM   #12
Whats wrong with 91 octane? It knocked pinging issues on both my cars. Running one tank of it shouldn't hurt anything. I didn't mean through the pulleys lol I meant just a tank of 91 gas to see if it clears up any pinging.
Old December 12th, 2011, 06:22 PM   #13
Army Strong
Xzavier247's Avatar
It's a standard ^_^
Used 91 one time didnt do anything my car isn't tuned for that, also never had ping with 83 oct. Running a hight octane will not help me, I knew the exhaust manifold would be the culprit because I smack the shit out of my exhaust and it so happend to have all the symptoms right after that.
Old December 12th, 2011, 06:24 PM   #14
Army Strong
Xzavier247's Avatar
It's a standard ^_^
Also if it was a true knock or ping 91 octane would be a band aid wouldnt help anything
Old December 12th, 2011, 06:27 PM   #15
Well your mustang is a slightly newer model, I've seen alot of older cars relieved of pinging from 91 though.
Old December 12th, 2011, 06:49 PM   #16
Army Strong
Xzavier247's Avatar
It's a standard ^_^
Evem though that still would be a band aid.
Detonation Knocking Pinging - What is it - YouTube
Old December 12th, 2011, 06:55 PM   #17
goren813's Avatar
'00 3.8L & '05 4.6L
v6man, I know what you were trying to suggest, however, this issue is 99% a cracked manifold, so the 91 octane would only be wasting $ on the additional gas price. Now, if he checked the exhaust and it was all fine, then maybe that would be a suggestion to determine if it was indeed inside the motor. Start cheap is my idea, always.
OP, shorties are a waste on these cars. The stock manifolds are pretty close to shorties as far as flow, so really you're adding a shiney paperweight. Either go for Long Tube headers and matching midpipe/new mufflers, or simply get your factory manifolds welded. I wouldn't spend the money on getting OEM replacements, just have it/them welded, much cheaper and the same result.
If deadset (or wanting more info) on aftermarket exhaust, do a search, there's a ton of threads out there on that topic.
Old December 12th, 2011, 07:01 PM   #18
Army Strong
Xzavier247's Avatar
It's a standard ^_^
Yeah Im thining just getting it weld. thanks for your input.
Threads Similar to: pinging in the engine?
Pinging? Digsj7 5.0 Mustangs 5 September 29th, 2010 08:34 PM
pinging... 02gtmustang 99-04 27 September 24th, 2009 01:35 AM
Pinging Odin 2005 - 2010 24 July 13th, 2008 09:40 PM
My car is pinging BLK01SS 99-04 18 July 2nd, 2008 08:36 AM
pinging in 3.8L V6 engine stephen V6 Mustangs 0 February 27th, 2007 05:11 PM
