'02 V6 will not stay running. Help.
Old December 12th, 2011, 08:05 AM   #1
mattl2186 is on a distinguished road
Exclamation
Hi everyone, I am new to the site. I have a 2002 V6, automatic. A week ago the car would not start at all, so we cured that with putting a new battery in. The old one was shot, started up fine and drove for the past week. Now, the car starts BUT will not stay running if I don't keep the gas pedal pressed. As soon as I let off of the gas, it will shut off. I cannot detect what the problem could be. Thanks in advance to any help or suggestions.
Old December 12th, 2011, 09:41 AM   #2
The soul stealing Ginger
dgt_mustang's Avatar
2001 Mustang 3.8l
dgt_mustang is a jewel in the roughdgt_mustang is a jewel in the roughdgt_mustang is a jewel in the rough
Send a message via AIM to dgt_mustang Send a message via Skype™ to dgt_mustang
Does it sound like its going to die before it dies or does it just cut out like you turned it off?
Get another job, get 2 more jobs, get your own place, work, live, fuck, eat, life, happy.
Old December 12th, 2011, 10:00 AM   #3
It just will cut out like I turned it off. I've pretty much ruled PATS out of the picture because it's functioning like it should, no blinking, etc.
Old December 12th, 2011, 10:36 AM   #4
thomasdale2144's Avatar
96 GT with 97 cobra swap
13.65@101.3
thomasdale2144 is on a distinguished road
vacuum leak?
1999 V6 CAI, Tune (Sold)
1996 GT Vert 97 Cobra Engine Swap, Mods in Garage 248.8 RWHP, 353.3RWTQ
But having a 4V makes it a Cobra
Want to join the FOBRA club?
MM FOBRA CLUB FOUNDER
Old December 12th, 2011, 10:44 AM   #5
2001 Mustang 3.8l
IAC maybe
Old December 12th, 2011, 10:45 AM   #6
2001 v6 premium
xtreme 2 will become famous soon enough
Send a message via AIM to xtreme 2 Send a message via MSN to xtreme 2 Send a message via Yahoo to xtreme 2
does it do this immediately? Like if you just turn the key it will fire up then die back down?
Have you made any other changes since the battery?
Screw it, coming to play with the big boys...
5.4L Vortech COMING SOON!
Old December 12th, 2011, 12:56 PM   #7
Tang Stang's Avatar
Tang Stang is just really niceTang Stang is just really niceTang Stang is just really niceTang Stang is just really nice
Verify that the IAC is plugged in. Then clean and inspect the IAC and report back. No CEL, right?
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Old December 12th, 2011, 04:19 PM   #8
MustangV6Man? can only hope to improve
Sounds like vacuum leak, but you should definitely try cleaning the MAF/IAC.
Old December 12th, 2011, 05:18 PM   #9
eleanorGT's Avatar
2001 Mustang 3.8
eleanorGT will become famous soon enough
all above, plus checl the bolt on the throttle body.. if its broken, or screwed out all the way... it will stall the engine due to lack of air for idle.
Old December 13th, 2011, 02:25 AM   #10
StoneColdStang can only hope to improve
ALTERNATOR. Problem solved. Same thing happen to me
Old December 13th, 2011, 08:38 AM   #11
2001 Mustang 3.8l
Usually good to rule some things out before jumping straight to a conclusion.
Possible culprits:
Alternator
Vacuum leak
IAC
Fuel filter could be clogged enought that more throttle actions gives greater force to push through sludge.
Gremlins
maybe TPS?? <----someone else could chime in on this one.
Old December 13th, 2011, 03:44 PM   #12
iPoopke Regular
2004 Mustang
iPAPKE will become famous soon enoughiPAPKE will become famous soon enough
Sounds like an ignition problem to me, for sure. Wouldnt a vacuum leak give you more of a pretty rough\jerky idle.
Old December 15th, 2011, 01:29 AM   #13
Wing on, wing off...
MRKsD3's Avatar
JULY 2011 ROTM
MRKsD3 is a glorious beacon of lightMRKsD3 is a glorious beacon of lightMRKsD3 is a glorious beacon of lightMRKsD3 is a glorious beacon of lightMRKsD3 is a glorious beacon of light
ALTERNATOR.
SIG BY WABASHACOBRA99
Old December 15th, 2011, 01:31 AM   #14
MRKsD3's Avatar
JULY 2011 ROTM
Your car was just running on the new battery's power all those days... Alternator wasn't charging... Same prob I had today.
Threads Similar to: '02 V6 will not stay running. Help.
351w will not stay running?? Pwnm30rdi3 5.0 Mustangs 7 November 28th, 2011 10:46 AM
88 5.0 sometimes starts but won't stay running cylance 5.0 Mustangs 8 August 28th, 2011 05:59 PM
Got Her Running, But wont stay running...help? Speedstang302 5.0 Mustangs 10 August 28th, 2011 05:58 PM
Car wont stay running. Jhoward93 96-98 2 April 18th, 2011 10:21 AM
car would not stay running 00redgt 99-04 3 December 7th, 2009 11:09 PM
