m112 install questions
Old December 12th, 2011, 12:59 PM   #1
02edge's Avatar
2000 m112'd 3.8
02edge will become famous soon enough
so i started my build the other day and so far its alot easier than id say a lt install just a little more in depth but my question is do I block off the iat port on the intake tube and extend the wires to the one one the adapter plate? and I relocated my iac but where is a good place to mount it and with the two barbs coming off it where do they go?
Old December 12th, 2011, 01:26 PM   #2
2001 v6 premium
xtreme 2 will become famous soon enough
Send a message via AIM to xtreme 2 Send a message via MSN to xtreme 2 Send a message via Yahoo to xtreme 2
Yes, block off the IAT in your intake tube and extend the wires to the plate adapter.
Most people just tuck the IAC off to the back of the supercharger inlet.
Screw it, coming to play with the big boys...
5.4L Vortech COMING SOON!
Old December 12th, 2011, 01:29 PM   #3
2001 v6 premium
BTW, any progress pics? What are your supporting mods?
Old December 12th, 2011, 01:38 PM   #4
02edge's Avatar
2000 m112'd 3.8
lts,catless h pipe, 39# injectors, svt focus pump, t lok with 373 mgw short throw shifter lightning maf sct sf3 buncha other little stuff ill post pics later but how do I plumb the lines from the iac
Old December 12th, 2011, 01:39 PM   #5
02edge's Avatar
2000 m112'd 3.8
also looking for a meth kit
Old December 12th, 2011, 01:40 PM   #6
2001 v6 premium
Have you purchased the adapter kit from mysteed? Otherwise you can make your own using some 1/4 plate and barbed fittings...
Old December 12th, 2011, 01:42 PM   #7
02edge's Avatar
2000 m112'd 3.8
no i bought a used kit off 3.7 and it came with the plate that bolts onto the iac and the adapter to mount it just not sure where to run the hose off the two barbs
Old December 12th, 2011, 01:45 PM   #8
2001 v6 premium
hoses should go from the plate on the inlet to the plate on the iac
Old December 12th, 2011, 01:46 PM   #9
02edge's Avatar
2000 m112'd 3.8
both of them?
Old December 12th, 2011, 01:50 PM   #10
2001 v6 premium
yes
Old December 13th, 2011, 06:07 PM   #11
02edge's Avatar
2000 m112'd 3.8
so vac lines are all ran intake os set up all I need to do is re bend the hard coolant line and find a pigtail for the iat but where can I find one?also is it possible to cut the hard line and run hose to the fire wall with a t to the thermo housing
Old December 13th, 2011, 08:14 PM   #12
02edge's Avatar
2000 m112'd 3.8
still confused just to clarify iac is blocked off on plenum iac is relocated to the firewall both barbs go to the cai?can I just put the two tubes to a y and put it on one barb on the intake?
Old December 13th, 2011, 09:05 PM   #13
02edge's Avatar
2000 m112'd 3.8
picking up the tr6's tomorrow what do I gap them to and somewhere I read to drive it to get tuned with the stock plugs and once im at the dyno swap in the new ones
Old December 13th, 2011, 11:15 PM   #14
2001 v6 premium
Yes. Most people will also not put the belt for the supercharger on until they get to the tuner. Keeps them out of trouble.
Can you post a pic of your IAC relocation? It's confusing the way you are describing it.
Old December 14th, 2011, 02:03 AM   #15
02edge's Avatar
2000 m112'd 3.8
ill post in the am any idea about rigging the hard coolant line
Old December 14th, 2011, 02:46 PM   #16
02edge's Avatar
2000 m112'd 3.8
temp zip tied up but thats what my kit came with as far as the plate
Old December 14th, 2011, 03:37 PM   #17
2001 v6 premium
can't view the pic at work but will look when I get home.
Old December 15th, 2011, 05:53 PM   #18
2001 v6 premium
Ok, finally got a chance to look at it.
What does the piece on your blower inlet look like? There should be hoses that connect the two... hence the relocation.
Old December 15th, 2011, 07:27 PM   #19
02edge's Avatar
2000 m112'd 3.8
thats what came on the plenum
Old December 15th, 2011, 07:28 PM   #20
02edge's Avatar
2000 m112'd 3.8
also by the ac lines coming out of the firewall on pass side theres a vacuum line coming out do I just cap it?and im running my boost gauge of the only barb on the bottom backside of the blower is that correct
Threads Similar to: m112 install questions
A few unrelated questions (M112, rear end, etc) SlowSix V6 Mustangs 8 October 29th, 2011 11:29 AM
question on eaton m112 install nukeman13 V6 Mustangs 20 June 27th, 2010 09:47 AM
what cam and install questions worrgp 99-04 24 May 16th, 2010 10:16 AM
M112 Questions Ticket-Me-Yellow V6 Mustangs 20 July 6th, 2009 02:33 AM
Questions about HID install mp4 player Visual 5 February 3rd, 2009 09:17 PM
