Weird fuel starvation issue on cold start.
Old December 15th, 2011, 01:39 PM   #1
2001 v6 premium
xtreme 2 will become famous soon enough
Send a message via AIM to xtreme 2 Send a message via MSN to xtreme 2 Send a message via Yahoo to xtreme 2
Hoping someone knows what could be causing this.
So When I cold start the car (in the mornings and after work), the car will fire up fire, idle fine, no issues. But if I put in in gear and let the torque move the car, the car bogs and acts weird until I push the gas. If I revv slightly while in neutral, the car will bog for a second then drive fine.
After this initial bog, the car runs great. No CELs or anything.
When I first noticed the issue I datalogged and my Short Term Fuel Trims were all over the place on Bank 1. At the request of my tuner, I swapped O2 sensors and the problem jumped to Bank 2. Bank 1 ran perfect. So I ordered a new O2 sensor and swapped it out. Now both look great.
But the problem persists.
I changed out my fuel filter a few weeks ago. It was a little nasty looking but still had flow. Problem got better for a few days, then started happening again.
Replaced me steering wheel last weekend, and had the battery disconnected for a few hours during this. Put it back together, car drove great with the Keep Alive Memory cleared, but then after a day it started giving this issue again.
It's almost like the computer in open loop cannot tell the sytem to send enough fuel at idle under load. Once I hit the gas it's like it clears the restriction and operates fine.
My fuel pressure is high, like 60 psi for some reason. If I clear the KAM, it will go back to the 35 normal, but if I drive around for a while then come back, it's around 60 again. This should not be.
I found my vac/boost gauge a few nights ago, and need to get some vacuum line to hook it up and see my idle vacuum to see if I have a leak, but visually I cannot find anything. No Exhuaust leaks.
Any ideas?
going to pull my plugs tomorrow and replace if needed. They have about 20k miles on them, so hopefully they are fine. Can't even remember what they are actually...
Screw it, coming to play with the big boys...
5.4L Vortech COMING SOON!
Old December 15th, 2011, 01:56 PM   #2
The soul stealing Ginger
dgt_mustang's Avatar
2001 Mustang 3.8l
dgt_mustang is a jewel in the roughdgt_mustang is a jewel in the roughdgt_mustang is a jewel in the rough
Send a message via AIM to dgt_mustang Send a message via Skype™ to dgt_mustang
I have the same exact problem, same exact symptoms. I have no clue what it is, I was thinking something fuel related by the way it sounds to me but have not confirmed with my tuner, i have the diablo tuner, so i will do a datalog as well, maybe we can compare numbers and see if the same problem is going on here.
Get another job, get 2 more jobs, get your own place, work, live, fuck, eat, life, happy.
Old December 15th, 2011, 03:41 PM   #3
Loki's Avatar
1996 V6
Loki will become famous soon enough
Same problem here .. I just thought it was due to a faulty o2 I've had for a while, but dont want to replace. Lol, haven't actually tried to diagnose it..
1996 3.8L.. Split Port Swap, CAI, True Dual Exhaust, the car accident mod.
Need cheap parts? CLICK MEEEEEEEEE!! =]
Old December 15th, 2011, 04:08 PM   #4
Army Strong
Xzavier247's Avatar
It's a standard ^_^
Xzavier247 is on a distinguished road
Yep have the same problem too. Does it feel jerky? When your going roughly 5 mph?
To the windowssss(/-_-)/ To the wallllll \(-_-\)
Check this thread out!
http://www.moddedmustangs.com/forums...pics-here.html
Old December 15th, 2011, 04:18 PM   #5
2001 v6 premium
only at start-up. After I hit the gas the first time, I never feel it again.
I had found an exhaust leak when I swapped my mufflers and swapped my o2 sensors. Before that, if I went WOT from a stop, the car would bog for a second and then pick up and go. Glad that's gone.
Old December 15th, 2011, 04:27 PM   #6
Matt.'s Avatar
2002 Nitrous Injected V6
12's?
Matt. is a jewel in the roughMatt. is a jewel in the roughMatt. is a jewel in the roughMatt. is a jewel in the rough
Try looking at your fuel filter , fuel pump , vac lines, Iac
Project Red Magic
-Full Intake, Full Exhuast,Geared, Tune, Sprayed, Dropped-
-18 Inch Hypercoated Saleens wrapped in Nittos-
Old December 15th, 2011, 04:46 PM   #7
Army Strong
Xzavier247's Avatar
It's a standard ^_^
I used Seafoam before and it cleared that problem up ,after that it felt like kinda instant throttle response for me, but in the long run it not fucking worth it. Carbo gets built up and etc.
Old December 15th, 2011, 05:48 PM   #8
2001 v6 premium
yea I have a bottle here. Haven't run it in a while. Poured some in the fuel tank the other day, haven't done the rest yet.
Fuel filter was changed last weekend, IAC cleaned a few weeks ago just routine maintenance, can't really look at the fuel pump, but I have a Supercar pump here that I have been thinking of tossing in just so I don't have to later...
Old December 15th, 2011, 06:02 PM   #9
iPoopke Regular
2004 Mustang
iPAPKE will become famous soon enoughiPAPKE will become famous soon enough
How are your plugs?
Old December 15th, 2011, 06:55 PM   #10
Army Strong
Xzavier247's Avatar
It's a standard ^_^
Originally Posted by iPAPKE View Post
How are your plugs?
You would really feel them misfiring.
And see if the seafom works when used through the vac line?
Old December 16th, 2011, 08:36 AM   #11
2001 v6 premium
Yea I am gonna Seafoam and pull the plugs tomorrow.
Old December 16th, 2011, 02:47 PM   #12
Matt.'s Avatar
12's?
check your fuel pressure, you can get a gauge that you plug into your fuel line at like auto zone. Just give them like 100 bucks as collateral.
Could also be a loose ground, my car would shutter and bog for a little, and I found it to just be a ground that was loose.
Project Red Magic
Old December 16th, 2011, 03:09 PM   #13
2001 v6 premium
I did fine a few days ago the power wire to my amp had completely loose and was grounding out on the floor board. Glad I didn't start a fire!
Got it tightened back up, and the last couple of days I actually haven't noticed the stumbling issue.
I don't really need a FP gauge, the Diablosport tells me the fuel pressure at the fuel rail. Like I said, last time it was reading really high. Haven't checked it since I swapped the O2s out and reset the computer.
Threads Similar to: Weird fuel starvation issue on cold start.
Cold Start: Engine dies immediately after start up 91Stang5.0 5.0 Mustangs 1 December 10th, 2011 12:05 AM
Gt has weird hissing new when cold. cristian.e.pelaez 2005 - 2010 1 November 30th, 2011 02:55 AM
Weird noise when accelerating on cold start? ufc94champ 2005 - 2010 11 April 19th, 2011 08:20 PM
Cold Start Problem Sovled...weird.. Traidmarx 5.0 Mustangs 5 November 20th, 2008 02:55 PM
fuel starvation at road race track 07gt23 Racer's Corner 1 July 2nd, 2008 09:49 PM
