What weight oil do you use/mileage and will 10w30 be safe to use??
Old December 16th, 2011, 10:05 PM   #1
StoneColdStang can only hope to improve
I just put in 5w-20 and my car has 150k miles. I was thinking if I should use a higher weight such as 10w-30.
But I heard the engine might not to able to flow to all parts of the engine, the oil feed holes may be clogged or not big enough to probably oil with the higher weight oil
Thanks
Old December 16th, 2011, 10:27 PM   #2
MM's Official Lucifer
goren813's Avatar
'00 3.8L & '05 4.6L
99-00 Ford calls for 5w-30. 01-04 calls for 5w-20.
I have a 2000 and run Mobil 1 full synthetic high mileage 5w30. 152k.
Old December 18th, 2011, 10:44 PM   #3
Humm I have heard 10w-30 is good to use as well in the summer because both weights of the oil are the same at normal operating temperatures
Old December 18th, 2011, 11:38 PM   #4
walt1120's Avatar
04 Stang 1.0Gallon V6
14.45 @95.8
walt1120 has a spectacular aura aboutwalt1120 has a spectacular aura about
I would always run 5w-30 mobil 1 in any 3.8. 5w-20 is too thin for my liking. And I would not run 10w-30 because its too thick for winter.
2004 Bolt on & Cammed 3.9L V6
Old December 18th, 2011, 11:59 PM   #5
[{4114 K-73}]
Reaper_88's Avatar
2000 Mustang V6 Manual
Reaper_88 will become famous soon enoughReaper_88 will become famous soon enough
Just stick to your recommended weight
Old December 19th, 2011, 12:45 AM   #6
iPoopke Regular
2004 Mustang
iPAPKE will become famous soon enoughiPAPKE will become famous soon enough
This. No need to go with anything else if you're not racing, or have a specific reason. If it isnt hurting anything, leave it be.
Old December 19th, 2011, 03:47 AM   #7
walt1120's Avatar
14.45 @95.8
Go with 5w-30 if you want full protection or just go with the 5w-20 that ford "recommends" on all 2001+ vehicles.
a 2000 mustang will say 5w-30, while a 2001 will say 5w-20 even though nothing has changed.
Ford did it because youll get 0.1 better mpg with 5w-20 so they could meet CAFE standards. Is it worth running the bare minimum protection just to follow what the manufacture says? imo, no.
5w-30 is all my 3.8 will see because its what the engine was designed to run
Threads Similar to: What weight oil do you use/mileage and will 10w30 be safe to use??
Oil weight. 05roush0090 2005 - 2010 37 April 21st, 2010 10:30 AM
Weight Codeman V6 Mustangs 19 October 28th, 2009 03:42 PM
Weight ia07gt 2005 - 2010 14 August 3rd, 2009 02:00 AM
weight Bush18 99-04 9 August 2nd, 2009 06:53 PM
weight JStang14 96-98 15 March 19th, 2008 07:54 AM
