heating problem
Old December 19th, 2011, 09:20 AM   #1
6ixer's Avatar
2000 mustang v6
14.6@99.68
6ixer is on a distinguished road
heating problem
Well for a short while I had problem with my heating the temp gauge would show that there head and at time the temp gauge would show at norm heat where the needle would be half way....
So my dad said there might be an air pocket so we took na 15 mm wrench to the...idk what you call it.. the bleeder bolt or w/e at the top nof the engine. We twisted the bolt a little lose enough to here hissing as if there was air in the lines and in fact there was..for a good 1 2 minutes air came out with no coolant and once coolant came out we tighten the bolt and closed the hood and now I had heat..pretty nice and warm
Fast foward to last night...problem re occured and today on the way to work I had no heat and I drove fore 30 minutes so there's no way my car didn't build heat because the gauge was directly at half way between ccold and hot..
Then I open the hood and there's spray(of coolant) on the fan battery holder and ...practically a light spray on the acsory belt also
What the hell???
Ported heads, comp cams cam, AM CAI, posi'd rear with 3.73 gears, flowmaster exhaust
Fixed clutch!!!!!
"My mustang likes a good ol' fashion bowl of rice....especially fried"
Old December 19th, 2011, 09:27 AM   #2
2001 v6 premium
xtreme 2 will become famous soon enough
Send a message via AIM to xtreme 2 Send a message via MSN to xtreme 2 Send a message via Yahoo to xtreme 2
Sounds like your upper radiator hose blew. There is probably a hairline split somewhere.
This seems to be a common problem.
Screw it, coming to play with the big boys...
5.4L Vortech COMING SOON!
Old December 19th, 2011, 09:49 AM   #3
6ixer's Avatar
2000 mustang v6
14.6@99.68
Oh and another thing...last night after my car was runing and had full heat for about 30 minutes...I touched the upper raditor hose...it was nice and wamr...so I knew that was good....the lower one.....cold.....not a little bit wamr at all...fe??t my heater pipes that go from the the engine to heater core...both nice and warm
Fixed clutch!!!!!
Old December 19th, 2011, 10:59 AM   #4
mustang227's Avatar
mustang227 is on a distinguished road
clogged heater core?
UDP, Cai, MAC LT's, Divorced duals with original 40's, Predator performance tune
Old December 19th, 2011, 11:33 AM   #5
2001 v6 premium
Mine just had a really big air pocket. For me it would work fine under load, but as soon as I stopped and rpms went below 1500, the blew ice cold.
Just had to burp it, drive for 20 minutes, come back and burp it again, and did that for about an hour.
Now it's not doing it anymore.
Old December 19th, 2011, 11:42 AM   #6
6ixer's Avatar
2000 mustang v6
14.6@99.68
@ extreme oh yeah I know I had an air pocket...we bled it out or thought we did last wk and all of a sudden. It stopped with hot air and now if I do get heat is not very hot nor does it last
Fixed clutch!!!!!
Old December 19th, 2011, 12:13 PM   #7
2001 v6 premium
try bleeding the system again. I had to do it 3 or 4 times before I got it all out. Sometimes it's good to drive for a day then bleed again. It can be a very tedious task.
Old December 19th, 2011, 12:20 PM   #8
6ixer's Avatar
2000 mustang v6
14.6@99.68
About the other guy who said clogged heater core....I thought so too but when I felt the two tube that went to and from the core...both were nice and warm...so just bleed the shit out of it??
Fixed clutch!!!!!
Old December 19th, 2011, 01:48 PM   #9
2001 v6 premium
yup, just keep bleedin...
Old December 19th, 2011, 02:14 PM   #10
6ixer's Avatar
2000 mustang v6
14.6@99.68
Lol...also mechanic at my work said prolly a blown head gasket sence compression/pressure keeps getting in the lines...
Fixed clutch!!!!!
Old December 19th, 2011, 02:22 PM   #11
2001 v6 premium
how's your oil?
Old December 19th, 2011, 04:11 PM   #12
mustangmike!'s Avatar
2004,1994,1967
14.37 @ 96
mustangmike! is a jewel in the roughmustangmike! is a jewel in the roughmustangmike! is a jewel in the rough
sounds like my issue kinda
I took out the bleeder plug like you did, and took off the radiator cap. Then useda funnel to fill up the coolant from the bleeder hole, once it reached full at the cap, I replaced it, then kept filling until it overflowed at the bleeder hole. Then replaced the bolt. And worked like a charm for about a week, then couple night ago it did it again, refilled again today and worked like a charm again ...
227whp N/A V6
Now w/ 8th Mile 8s !
How To Jmod Your Late Model 4R70W
Old December 20th, 2011, 12:38 AM   #13
6ixer's Avatar
2000 mustang v6
14.6@99.68
Both oil and antifreeze are slowly leaking...but NOT mixing...every soo often I have to put a half qt in
Fixed clutch!!!!!
Old December 20th, 2011, 09:38 AM   #14
2001 v6 premium
is it going on the ground or somewhere else?
and what I did to fix my problem what I took off the bleeder valve, filled it up with a funnel, made sure the radiator was full, and then started the car. Just kept the radiator full and after about 30 seconds coolant started bubbling through the bleeder. Once it got where there were no more bubbles and just coolant, I capped it off.
Got a little messy, but it did the trick. Heater blows real hot now.
Old December 20th, 2011, 09:39 AM   #15
2001 v6 premium
When I did my IMRC swap I had forgotten to fill the bleeder and I guess it just kept getting worse and worse.
Old December 20th, 2011, 10:01 AM   #16
2004,1994,1967
14.37 @ 96
Oddly enough, I rebuilt my engine and finished that back in what may ? something like that, anyways, I just filled up the radiator. Went about my buisness, never had problems, used my heat several times, about 3 weeks ago I started having my first heater problems, did the coolant fill from the over flow tube and fixed it, drove about a week and it comes back. Did the same fix and its good so far lol
But it should fix it fairly quick, their is a bypass to get around the thermostat so it should fill things up even w/ thermo closed.
227whp N/A V6
Old December 20th, 2011, 11:26 AM   #17
2001 v6 premium
yea that's how mine was. I did my IMRC deleted last June (2010) and it didn't start having issues until this September.
Threads Similar to: heating problem
Electronics/ heating problem? ROWBOAT V6 Mustangs 0 November 14th, 2010 06:09 PM
Heating Problem 19stang88 5.0 Mustangs 12 November 9th, 2010 12:51 PM
over heating 5mustang0 5.0 Mustangs 36 May 16th, 2010 01:37 PM
Over Heating Problem? Fox2102 V6 Mustangs 11 November 9th, 2007 10:25 PM
95 Mustang Over Heating Problem lil_homie69 V6 Mustangs 2 October 27th, 2006 07:12 AM
