Wire help
hey guys, so im finally going to install my ready remote do it yourself remote start kit on friday and i have a pretty good grasp on how to install it. I am having custom tunes made to bypass pats so that will be all set. The question i have is, can i use suitcase connectors to tap into the running wires in the ignition harness and the other harnesses? also what gauge wire are they to i get the right size connectors? thank you!
Dancing Naked In The Rain
"Suitcase connectors" are the ones that clamp shut, correct? I don't see any problem using them. As for wire gauge, I believe 90% of the wiring your car should be roughly 18g. And if you have a manual, don't forget a neutral safety.
what is a neutral safety?
1999 V6 Mustang
I wouldn't use scotchlocks (suitcase connectors), they can create high resistance in the wire and expose it to corrosion. A solder joint with heat shrink tubing is the correct way to tap into the wires if you want a low resistance trouble free connection.
ok, im weighing my options on how to go about it now. I might pick up some suitcase connectors just to have on hand just in case also. So i need 18g connectors? i think they are in ranges like 14-18 and 18-22
ive been reading on a few sits with other cars that the ignition wire harness is generally in the 12-14 gauge as opposed to 18g, can anyone confirm this for mustangs? i just want to make sure i get teh right size suitcase connectors to insure a good connection
ok thanks, ill pick up a few of each, now im just not sure on the gauge size of the ignition harness and the rest of the wires i have to tap into, not sure if they are all going to work with the 18-22
Threads Similar to: Wire help
| which wire | JD mustang | 99-04 | 0 | May 11th, 2011 07:57 PM |
| Ground Wire Gauge.. Same Size as Power Wire or No? | warrior86 | Audio/Video | 4 | January 30th, 2010 06:41 PM |
| what wire is the signal wire? | 1988gtpony | 5.0 Mustangs | 4 | December 6th, 2009 12:01 PM |
| wire spacers and wire lube | v6must742 | V6 Mustangs | 0 | November 18th, 2009 09:23 PM |
| which wire is the dimming wire? | jdy2kgt | 99-04 | 3 | July 12th, 2008 01:22 AM |
