Two issues...
Old December 21st, 2011, 11:01 PM   #1
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
Zatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud of
iTrader: 15 reviews
Two issues...
Today I decided to do a few things on the car:
  • Change passenger manifold gasket
  • Install new Sportline Spinrgs
Everything went smoothly. Well... as smoothly as they could, Lol. After I got everything back together I have two issues:
  • When driving, tires make a high pitch squeel when turning. Also, tires make a low noise when spinning... knida like (as the wheel turns) wooohm... wooohm... woohm
  • The car is running rough. After cranking, it idles fine for about two mins. Then, the rpms drop and the car tries to die. It stutters alot during this time. The car also has a drone to it.
Any ideas? I am thinking of simply taking it to the shop tomorrow and saying "fix it" Lol. Been working on it for two days and I need it running Friday.
Black Bullitt Rims FT/FS
Looking to Sell or Trade for Silver FR500s
Looking to buy a lot of 99-04 Interior Pieces
If you have any for sale, PM me
Old December 21st, 2011, 11:54 PM   #2
StoneColdStang can only hope to improve
idle problem means you have a leak somewhere or didnt connect a tube or connector or something of that nature. You need to rework your steps and double check everything, same thing the "shop" will do..lol
The noise..check the power steering fluid and check the serpentine belt and tensioner. Did you mess with your brakes or calipers?
Old December 22nd, 2011, 12:14 AM   #3
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
iTrader: 15 reviews
Ya, had to take the caliper loose to change the springs.
The sound is coming from the wheels, and its a metal grinding/rotating sound.
Old December 22nd, 2011, 12:56 AM   #4
mustangmike!'s Avatar
2004,1994,1967
14.37 @ 96
mustangmike! is a jewel in the roughmustangmike! is a jewel in the roughmustangmike! is a jewel in the rough
alignment ? Are your wheels rubbing against anything ? Put your pads back in wrong ? Double check everything, if it was not there before, chances are you made it happen.
227whp N/A V6
Now w/ 8th Mile 8s !
How To Jmod Your Late Model 4R70W
Old December 22nd, 2011, 01:04 AM   #5
Your calipers is loose and or the caliper bolt feel out. Mines did the same thing awhile back. Recheck reseat it and tighten it
Old December 22nd, 2011, 01:09 AM   #6
for the power issue...something is loose or leaking...i'm guessing the gasket you replaced because that issue is still what happened to my GT when that gasket leaked on mine. as for the noise...just double check it all..
Old December 22nd, 2011, 01:17 AM   #7
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
iTrader: 15 reviews
That one gasket would cause the engine to almost die? Why would it start a few mins AFTER the car has been running? I am 99% sure everything is back together the way it was. I will triple check it again.
As for the noise. I heard this same sound before and it was the lug nuts. However, they are on tight as can be. I will check everything around the wheel area again.
Old December 22nd, 2011, 01:59 AM   #8
yeah it sounds crazy....if you look far enough into my history i had a thread on it...it happened a few times like when i would be leaving work and stopped...and the big time it happened the gasket went completely and i had to nurse my car home by hitting wot just to get the car to go over 20 mph to make it the last few miles home ....i know i replaced that one gasket 4 times before i sold that car
Old December 22nd, 2011, 02:34 AM   #9
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
iTrader: 15 reviews
I honestly think I might just take the car in and have the shop check it out. Its been having a few odd issues, and I rather them all be found. Its been doing some odd idling stuff before. Its also had this drone to it for awhile now.
Plus, I have to spend the day with the lady friend tomorrow and I need the car running good by Friday, so no time to work on it.
Its probally nothing big. A vacuum hose or something. As for the noise on the wheels, probally nothing big either. Just don't have the time to take it all apart again tomorrow.
Old December 22nd, 2011, 08:30 AM   #10
Tang Stang's Avatar
Tang Stang is just really niceTang Stang is just really niceTang Stang is just really niceTang Stang is just really nice
Alignment is off due to the new springs/installation, which is accentuating the fact that it's likely time for new wheel bearings.
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Old December 22nd, 2011, 09:40 AM   #11
2001 v6 premium
xtreme 2 will become famous soon enough
Send a message via AIM to xtreme 2 Send a message via MSN to xtreme 2 Send a message via Yahoo to xtreme 2
you would probably be good for a new alignment.
Another thing to check, is the dust shield touching the rotors? This will cause a metal scraping noise.
Screw it, coming to play with the big boys...
5.4L Vortech COMING SOON!
Old December 22nd, 2011, 09:42 AM   #12
Silver35th's Avatar
'99 GT 35th Anniversary
14.266 @ 103.41
Silver35th is on a distinguished road
+1 on checking your wheel bearings. They make the grinding noise as you mentioned when their time has come.
SMR #2043
Old December 22nd, 2011, 10:02 AM   #13
1999 V6 Mustang
SALEEN961 will become famous soon enough
It starts a few minutes after your start your car because until your car warms up the ECU is in open loop, runs off of base maps, and ignores O2 sensor inputs. Once your car warms up the ECU goes into closed loop and uses O2 inputs to make changes to fuel delivery, so if you have an exhaust leak that throws off your O2 readings it will only present itself once the car warms up and enters closed loop operation.
Old December 22nd, 2011, 10:10 AM   #14
2001 v6 premium
^^ this
Threads Similar to: Two issues...
331 issues 88Saleen 5.0 Mustangs 13 May 26th, 2011 08:35 PM
Still having issues rdspins89 2005 - 2010 7 November 16th, 2010 02:52 AM
issues cdmannifield 2005 - 2010 56 March 31st, 2010 12:17 AM
t-5 issues cburns 5.0 Mustangs 6 October 24th, 2008 01:44 PM
New guy with issues. 01GT 99-04 9 May 25th, 2007 02:59 AM
