How long till battery drain while lisitng to radio car off? Jump car battery dead
So while working on my interior I was listening to my car radio (car off) and I had my iphone charging up plug in.
After about 1 - 1 1/2 hours my battery died. Is this normal? How long does it usually takes for battery to die while listing to the radio with the car off? Also whats crazy is I jump start it this morning and let my car run maybe for like 3-5 min or so. I turned it off and restarted the car and it started fine. Did this 2 times. Now 3 hours later I go back out to my car and it wont start (clicking ) battery is dead again.So did I need to let it run a little longer to fully charge the battery, maybe drive it around the block or so? Also wouldnt the car not restart if the battery was charged after jumping it |
'99 GT 35th Anniversary
14.266 @ 103.41
Well, if you have the stock stereo I don't know how long it can run, but when aftermarket amplifiers are in the mix, the time goes down significantly. I can't run my stereo on accessory for more than 30 minutes or so or I have a dead battery.
SMR #2043 |
#3 | |
Just checked. I have a duralast gold battery and it has a 8 year warranty. I know its about 7 years old so i will probably go and exchange it |
14.266 @ 103.41
I have a 50x4 watt RMS four channel and a 800 watt RMS mono for subs. A lot of power needed in my system. After a battery dies, either put it on trickle charge overnight or take it for a good spin around town to charge it back up.
SMR #2043 |
Zip wants me
2005 Mustang GT, 1967 GT
Only thing aftermarket on my mustang is the headunit. I had it play for like 3 hours, uninterrupted, and it cranked right up. No problems
The day I finish paying for my mustang will be a great day. Although I'm more likely to die before it happens. Don't be stupid like me! Zip loves my penis. |
1999 V6 Mustang
I drove my Mustang around for a day with the alternator unhooked and then a day later ran a compression test and even after all that cranking it still turned over nice and fast like it was fully charged, BTW I have a Diehard battery from Sears.
Possible, because the car does not use the battery after it starts
1999 V6 Mustang
It does when the alternator isn't hooked up, something has to run the fuel pump and the rest of my electric goodies. I'm just saying that I was able to drive around for a few hours and crank my car 8 times without draining the battery even though I had no alternator. The voltage regulator went out on mine and I wasn't going to leave it hooked up so it could create voltage spikes and take out my ECU.
iPoopke Regular
2004 Mustang
Probably need a new battery
Threads Similar to: How long till battery drain while lisitng to radio car off? Jump car battery dead
| Key Off Battery Drain | ajzride | Classic Mustangs | 14 | October 17th, 2011 09:59 PM |
| Battery drain | velasco98 | 5.0 Mustangs | 13 | January 28th, 2011 12:03 AM |
| Battery Drain | sukibusa | 99-04 | 6 | August 24th, 2009 11:48 PM |
| Battery drain | 93Notch | Audio/Video | 3 | February 16th, 2007 01:16 AM |
| Battery Drain | 5.0mustang9509 | 5.0 Mustangs | 1 | November 7th, 2006 07:15 PM |
