Which is the best suspension? - Page 2
Old February 1st, 2012, 06:29 PM   #21
mangogirl205's Avatar
2001 V6 Mustang Vert.
mangogirl205 is an unknown quantity at this point
Sorry forgot to ask. Will I need to replace the ball joints , spring isolators or caster camber plates?
I am doing the Tokico blues front/rear with the eibach pro kit. 1.1" drop all around.
Thank you in advance.
BBK CAI,K&N FILTER,MAGNAFLOW TRUE DUAL EXHAUST,CUSTOM MID PIPES,TB SPACER,MSD IGNITION,MSD 9MM WIRES,17x10 TSW RIMS,FALKEN TIRES 245/FRONT/255 REAR,MAC HEADERS,3.73 GEARS & T-LOK(need to install)
10000K HIDS,CF SPOILER & VISUAL GOODIES
Old February 2nd, 2012, 09:00 AM   #22
2001 v6 premium
xtreme 2 will become famous soon enough
Send a message via AIM to xtreme 2 Send a message via MSN to xtreme 2 Send a message via Yahoo to xtreme 2
Despite what that guy said, you DON'T need CC Plates unless you plan to alter the vehicles geometry FOR RACING. If you don't plan to race, don't spend the $175 on them. Just go to Eibach and get the Camber Bolts ($35). This is all you need.
Spring Isolators are debatable. If yours are worn out (at 120k they probably are), you can get either factory replacements from ford, or get Poly from BBK.
Ball joints are only needed if yours are worn out. Remove the front wheels and look where the spindle meets the control arm. There is a little joint that is there. If the boot is ripped, you need to replace them.
Screw it, coming to play with the big boys...
5.4L Vortech COMING SOON!
Old February 2nd, 2012, 12:57 PM   #23
2003 v6
03stanggg will become famous soon enough
Without the CC plates I wouldn't be able to get the correct geometry and my tires would wear out super fast. So its not necessarily for racing...
I'm dropped a little lower then he is so he might not need them but I did... just posting my past experience, I wasn't saying he needs them...
http://i723.photobucket.com/albums/ww234/wendell1988/sss.jpg
Old February 2nd, 2012, 03:04 PM   #24
MM's king of Neon's
WickedSnake00's Avatar
404 - car not found
17.81@87
WickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud of
CC plates depends on how far you drop. If you only go down an inch or so, your stock ones have sufficient adjustment. Mine is down about 2", and my stock CC plates are maxed out at -2deg camber. That's a bit agressive for my tastes, but not unreasonable. I think factory spec is about -1.5deg, so it's not a big deal.
I would not advocate camber bolts. They achieve camber adjustment due to their eccentric shaped center, which greatly reduces the strength of the bolt. CC plates may be a bit more expensive, but they're more robust and they're the correct way. They also allow for caster adjustment which is also needed for extensive lowering.
I'll also throw in my 2 cents on shocks. I'm running the stock Bilsteins that came on Cobras in back, unknown setup in front. The Bilsteins are a very nice unit.
Official Secondhand Snake Build Thread Here
Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra.
For Sale: P71 Interceptor motor
Old February 2nd, 2012, 05:14 PM   #25
WhiteShadow's Avatar
2001 Mustang V6
WhiteShadow will become famous soon enoughWhiteShadow will become famous soon enough
Send a message via AIM to WhiteShadow
good to know. i plan on getting the bilstein set from AM on all four with springs this summer. will i need CC plates if im dropping 1.5 inches?
Whiteshadow build Thread
Updated 4/10/2012
Divorced Dual Borla Stinger Exhaust Catback Video
Old February 3rd, 2012, 08:15 AM   #26
MM's king of Neon's
404 - car not found
17.81@87
I don't think you'll need them per se, but you'll be close to maxed out on the stockers.
Old February 3rd, 2012, 10:09 AM   #27
The soul stealing Ginger
dgt_mustang's Avatar
2001 Mustang 3.8l
dgt_mustang is a jewel in the roughdgt_mustang is a jewel in the roughdgt_mustang is a jewel in the rough
Send a message via AIM to dgt_mustang Send a message via Skype™ to dgt_mustang
If lowering to 1.5..i would get them.
Get another job, get 2 more jobs, get your own place, work, live, fuck, eat, life, happy.
Old February 3rd, 2012, 10:48 AM   #28
2001 Mustang V6
yeah i was thinking i would just because i dont like the idea of my stock ones being "maxed out" i guess ill add that to the total. haha
Updated 4/10/2012
Old February 3rd, 2012, 11:09 AM   #29
2001 v6 premium
Just saying, all my friends with 800 hp GT500s are running camber bolts with no issues. I've had them on my car over a year with no issues...
Old February 3rd, 2012, 02:21 PM   #30
Formerly 01silversixer
SlowSix's Avatar
2001 V6
15.47@89.57
SlowSix has a spectacular aura aboutSlowSix has a spectacular aura aboutSlowSix has a spectacular aura about
I'm lowered close to 1.5 inches and don't have CC plates or camber bolts and my alignment is fine. *shrug*
Build Thread
Old February 3rd, 2012, 02:33 PM   #31
2001 Mustang V6
i guess ill just have to see how it goes then. i can always return them or order them if needed.
Updated 4/10/2012
Old February 3rd, 2012, 03:04 PM   #32
Well on American Muscle it says the Eibach pro kit will lower 1.1" all around for the vert.
I do not plan on racing, this is my DD.
Is their anyone else on here that lowered their car just slightly and did not get the cc plates or bolts?
Because I am thinking I wont need them.But want to be sure.
Threads Similar to: Which is the best suspension?
new suspension b-on-b 5.0 5.0 Mustangs 2 July 18th, 2010 03:27 AM
Steeda Suspension- Suspension Questions MustangJon255 2005 - 2010 22 June 2nd, 2010 05:43 PM
suspension help badacestang 2005 - 2010 7 March 28th, 2010 08:52 PM
Suspension for 99 ArmyChargedGT 99-04 18 March 20th, 2008 11:14 PM
Suspension usafimj 2005 - 2010 8 March 1st, 2008 07:29 PM
