Army Strong
It's a standard ^_^
Clutch feels crunchy
Went to drive my car today and now my clutch feels crunchy when I go to push it down. Any Ideas? The clutch grabs fine everything works just the feeling is killing me it isnt smooth anymore
![]() To the windowssss(/-_-)/ To the wallllll \(-_-\) Check this thread out! http://www.moddedmustangs.com/forums...pics-here.html
MM's Official Lucifer
Little more definitive on 'cruncy'. What else is happening? You say it works fine, any noises or any other signs to help describe this?
Dancing Naked In The Rain
I would have a look around the clutch cable and see if there's dirt built up around the area that the cable goes through the firewall or something. "Crunchy" is not a good sign if it's happening somewhere within the clutch disc/pressure plate area.
Skar Gone
1998 Mustang V6
17.27@76.66
Speaking of Clutches and Problems..
My clutch Cable no longer "self Adjusts" itself. Their is a LOUD squeek. I Crawled up under the car while it was running, And when it was not. I can grab the part the Cable is attached to and move it and it makes the squeek. WTF is causing that? Its SUPER loud while Driving. Almost like a bad Bearing. But its not since i can make it squeek by moving it.. D: Also, If I Move the pedal at all, Even with my Pinky finger, It stops the squeak when the car is running. its almost like its just a hair bit off.. I have a lot of play in the Clutch pedal, Which means I probably need a new cable right?
![]() 1998 5 Speed, CAI, Exhaust, Rear Seat Delete. |
#5 | |
Look on the bright side: If you're reading this, you're alive. And that's fucking awesome. ![]() |
Skargon...see if you can order a cable quadrant combo from Advance or Autozone...i know we carry cables for 3650s in stock with metal quadrants...dunno about if they have in the store the one you need for your trans....wouldn't hurt to call and ask...the brand is usually a Zoom Performance product
@OP...pull the dust cover off the trans and look at where the clutch cable connects to the trans...see if anything is binding in there or cable quality |
Yeah Skargon seems to be a new cable will do the trick. But as said I'd go for a new quadrant as well, the stock pieces are plastic and tend to flex over time.
OP I'd suggest dust mask and protective eyewear when opening the clutch dust cover, do NOT want that stuff in your oriphices.
#8 | |
Army Strong
It's a standard ^_^
1999 V6 Mustang
Could be the front bearing retainer causing the TOB to stick. I'm not sure if our cars came stock with steel bearing retainers or aluminum ones. Mine has the better steel one but it could have been put on by a previous owner. Anyone know what the stock ones are?
Skar Gone
1998 Mustang V6
17.27@76.66
ALSO.. my Dust Shield is gone. Nothing Thurr.
I can see my Clutch Assembly and everything inside the Transmission. Planning on trying to find one at the Junkyard soon. Everything inside that hole is a solid sheet of Rust..
Yeah def. get another one on there ASAP.
Threads Similar to: Clutch feels crunchy
| Clutch feels like it's grinding when I push it... | BuiltToughCobra | 99-04 | 0 | December 23rd, 2011 03:20 PM |
| Clutch feels tight | franchised1 | 99-04 | 7 | June 20th, 2011 02:13 AM |
| New clutch feels slower than last. | PhillyGT | 5.0 Mustangs | 13 | July 2nd, 2010 10:01 PM |
| Gt feels like geo help! | Tr1gger | 2005 - 2010 | 27 | June 12th, 2010 05:10 PM |
| Clutch Feels Weird | Stan27 | General Tech | 10 | April 25th, 2006 12:55 AM |
