Throwing multiple codes on a 98 stang' base - Page 2
Old January 11th, 2012, 11:57 AM   #21
2001 v6 premium
xtreme 2 will become famous soon enough
Send a message via AIM to xtreme 2 Send a message via MSN to xtreme 2 Send a message via Yahoo to xtreme 2
no muffler has no effect on the operation of the system.
Screw it, coming to play with the big boys...
5.4L Vortech COMING SOON!
Old January 14th, 2012, 01:57 AM   #22
Very homosexually
str8chillng's Avatar
1998 Mustang BASE
17.3
str8chillng is on a distinguished road
Send a message via AIM to str8chillng
Then I'm stumped, looks like I might need a new cat on that side then... or unless theres something causing it to make the sensor throw a P0420 code.
Old January 14th, 2012, 02:10 AM   #23
fastpony's Avatar
1998 ford mustang gtclone
fastpony is on a distinguished road
Send a message via AIM to fastpony
The screaming demon is the worst thing. it might feel ok for the first couple of miles but it accutally sucked! took it to the track and i lost almost a good .5 second on my time compared to the stock one. I would check your syncronizer ( basically the distibutor under the coil pack) it not sending enough spark and not burning enough gas may cause the issue on the mil code. it wouldnt hurt to replace it with an oem replacement coilpack and have the synchro looked at. i had mine replaced been better ever since. i have a 98 sixer as well.
what type of plugs did you get
Old January 14th, 2012, 02:17 AM   #24
fastpony's Avatar
hmmm dis regard, last comment. but the aftermarket o2's go bad... its a hit or miss to get a good one.
Old January 17th, 2012, 02:15 AM   #25
Very homosexually
1998 Mustang BASE
17.3
Just came back from a roadtrip from Lacrosse. I purchased the stock motorcraft plugs for my car, aswell as other motorcraft things. I'm going to stay sorta shy of some aftermarket things. But I'd would want to do a cold air intake and maybe a dual exhaust soon, but really I have no time for that stuff. I love my mustang alot, I cruise more then I race anyhow which is why I got the sixer. But now I'm due for some new tires and an alignment soon and have to replace the right brake rotor aswell as pads.
But I haven't seen a MIL light since I had driven it a little bit, then it went away.... so it seems everything is alright. Someone had mentioned the cam synchronizer at some point, I've heard some weird squeel before but that went away long ago, so it can mean that part is going but I haven't had a code for it since I did my tuneup.
Threads Similar to: Throwing multiple codes on a 98 stang' base
Car is throwing codes. whyxitx V6 Mustangs 20 September 21st, 2011 07:02 PM
Throwing codes, need help!!! mustang_09 99-04 1 August 21st, 2011 08:19 PM
throwing codes. tell me what needs to be done to fix. dalton96gt 96-98 14 June 18th, 2010 01:52 PM
my car throwing new codes SEANMD81 2005 - 2010 2 March 1st, 2009 02:18 AM
Dead Pony - Multiple Codes... DAILYV8 5.0 Mustangs 15 February 29th, 2008 03:02 PM
