LinkBack (3) | Thread Tools |
#1
2004 Mustang V6
![]() iTrader: 1 reviews
04 V6 lowered
Was wanting to lower my mustang, anyone have an idea as to how much it would be to properly lower it about 2-3 inches?
for that type of drop you'll either need coil overs...or a top end shock/strut setup...lowering springs...bumpsteer kit...x2 balljoints...c&c plates...etc etc
why so low??? |
2004 Mustang V6
hmmmmmm, your right
what about just 1.75"? |
i reccomend 1.5"....it's what most run and you won't need to have all of that other stuff to achieve that goal...
for that you can get away with either cutting your oe springs or buy lowering springs...both do the job well to that you can add the other things like shock/struts and the such to make the ride quality that much better... |
here's an example
before ![]() after cut springs (roughly a 1.5" drop)
2004 Mustang V6
Say I bought these:
H&R Super Sport Mustang Springs (96-04 GT/V6) 51652-77 - Free Shipping! what else would i need to buy? |
MM's Barbarian
1996 V6
17.31@85
Try this.
H&R Super Sport Mustang Springs (96-04 GT/V6) 51652-77 - Free Shipping! Or Ford Racing Mustang C-Springs (79-04) M-5300-C - Free Shipping! You don't get as much as a drop with these but it's cheaper and if you really want you can leave out the iso's and wrap the bottom of the spring with Black electrical tape for another 1/4" at the MOST. And new Shocks/Struts will be in Order. Strange Engineering S6004LM - Strange Externally Adjustable Mustang Shocks - Overview - SummitRacing.com Strange Engineering S6005LM - Strange Externally Adjustable Mustang Struts - Overview - SummitRacing.com These are most commonly used in drag-racing applications, but I know a guy who uses them on his DD and another who uses them for his Auto-X and DD car. The ride on both of them is comfortable as stock, yet more responsive and firm. And while your at it, think about these for the future. 1979-2004 Mustang Full Length Subframe Connectors w/ Crossbraces & Torque Box Adapters - 1994-2004 - Chassis Bracing - Chassis & Drivetrain - Home for your Ford Mustang Maximum Motorsports Mustang Caster/Camber Plates (94-04) MMCC9994 - Free Shipping! Steeda Bumpsteer Kit (94-04 Mustang) 555-8104 - Free Shipping!
"I'm not going to sit here and take this defeatist attitude and listen to all this crap any more from all these people who have nothing but doomsday to predict." Carroll Shelby |
2004 Mustang V6
Would i have to get the car aligned after installing the springs and bump steer kit?
2000 Mustang 3.8
ehh w/e the mostly stock time is
yes. and btw, i would save up another 200 for misc. BS that you will run into. I ended up having to buy new front brake calipers while i'm doing mine because my front ones locked up after i attempted to put new front pads on it.
![]() Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK How to paint your rims: http://www.moddedmustangs.com/forums...ml#post3931042 |
yeah i always go the cheap route lol....i do cut springs (the correct way)...then upgrade the things around it...to me there's just no point in paying for lowering springs when my cut springs ride the same as all of my friends aftermarket ones lol...
IMO I would not go lower then 1.5 in drop. Like others have stated you will need CC plates for alignment since the stock plates will max out at 1 degree of neg camber etc. You will also need bumpsteer kit to correct the angle because your changing the ride height and will increase bumpsteer. You also need a good quality strut and shock since the OEM will not hold up to long a lower ride height. These can get pricey depending on your budget for shocks.
If you go to low you will run into ground clearance issues with your mid-pipe and cats etc on your exhaust.
![]() Sig by Tricep |
#12 | |
Not Banned
Best advice i can give you is to do everything right the first time and all at once
dont just do springs Go with MM CC plates if nessesary a nice set of eibach's or h&r's or some other good quality spring you should be fine with some tockio blues for shocks and struts steeda bumpsteer |
#14 | |
mine lasted for over 2 years without issue on a 1.5" drop...and i was rough with my car...
Not Banned
well mine were dead before i lowered, which is the main reason why i replaced mine
anyways it saves you alignment fees to do it all at once |
#17 | |
#18 | |
![]() Then got a killer deal on Koni SA and never looked back.
Not Banned
wow, cheapest i found in town was $150
MIne ran about $85 for alignment. I have had mine down about 4 times.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/v6-mustangs/243740-04-v6-lowered.html
| Thread LOWERED 99-04 V6 vert pix? | Forums at Modded Mustangs | BoardReader | This thread | Refback | February 21st, 2012 03:39 AM | |
| strange struts - Page 2 | BoardReader | This thread | Refback | December 27th, 2011 01:04 PM | |
| strange engineering | BoardReader | This thread | Refback | December 27th, 2011 09:38 AM | |
Threads Similar to: 04 V6 lowered
| Everyone that's lowered get in here! | 02trueblueGT | 99-04 | 77 | March 4th, 2011 12:43 AM |
| Has my car actually already been lowered? 4x4 | newsatng | 99-04 | 13 | February 17th, 2011 10:00 PM |
| 17s lowered. | stangpride04 | 99-04 | 8 | February 1st, 2011 10:01 PM |
| Lowered GT | GT4E | 2005 - 2010 | 18 | December 8th, 2008 05:02 PM |
| got the car lowered | 00redgt | General Tech | 2 | November 29th, 2007 06:40 PM |
