94-98 V6 Budget Brake Upgrade
Old December 27th, 2011, 03:28 AM   #1
MM's Barbarian
The Cheeks McDuke's Avatar
1996 V6
17.31@85
The Cheeks McDuke has a spectacular aura aboutThe Cheeks McDuke has a spectacular aura about
Credit goes to GTRaptor @http://www.allfordmustangs.com/Detailed/2009.shtml
Being able to slow your car down at the track or the street is very important, more so if you have increased the power output of your Mustang. At the 1/4 mile it is probably not as important, but if you ever go Road Racing you will notice how fast the stock brakes on your 94-98 Mustang fade as if you didn't had brakes at all.
94-98 Mustangs are factory equipped with single piston calipers and 10.8 Rotors. The units are cast iron which are not only heavy but also don't dissipate heat fast enough which will boil your brake fluid.
Details
PBR Caliper specs:
weight: 10.4 lbs (loaded)
piston diameter: 45x45mm dual piston.
Assembly Diagram:
http://www.allfordmustangs.com/techa...9brakediag.jpg
In this article we are installing a PBR dual piston caliper brake kit. Originally found on the 99+ models it gives a better than stock feel. The PBR units can be found at a junker or from some specialty shops. This is a "low budget" project which most people will be able to afford and perform with home tools.
These PBR units are an almost bolt-on deal for 94-98 Mustangs, with minor grinding required for the spindle. Fox body mustangs will have to use the 94-98 spindle which will increase ackerman, but we wont cover the Fox swap in this article.
94-98 SN95s can retain their stock 10.8 discs, but it would be a good idea to swap them in favor of some Drilled or Slotted rotors. They are also lighter (8 lbs) than the '94-98 cast calipers which will reduce unsprung weight, and you get the benefit of the dual piston calipers!
Our PBR calipers and discs came from a 2002 Mustang GT with low miles so we are keeping the discs and just have them resurfaced. Prior to installation we cleaned and polished the calipers to improve the looks. The polishing is no easy task, took us around 2 days but the calipers look like aftermarket units with a distinct chrome look. We also painted the vents on the rotors and center section.
Most take-off units come loaded with pads and brake lines. The '94+ Mustang brake lines are side specific, so you cannot switch sides with them. The '99+ Mustang lines are a direct bolt in for the 94-98 cars. The 94-95 spindles will have to be cleareanced for the dual piston 99+ calipers to work.
To mount the PBR calipers on the older '94-98 spindles, you need to shave about 5mm off each "ear" of the caliper mounting bolt hole. This can be done with a grinder very easily. It will take about 20 minutes to complete both spindles.
Removal and Installation
Remove one caliper at a time. The caliper is held onto the spindle via a bracket. Two bolts may be accessed from behind the bracket. Support the caliper/bracket assembly. Dont disconnect the hose yet.
Remove the factory caliper mounts.
Remove the rotors, if they have never been removed theres probably a locking spider washer in a couple of the bolts. Remove them and discard. Give a few blows with a rubber mallet to the rotors from behind. Rotate the rotors as you do this.
Grind around 5mm from each spindle as shown here. Test-fit the PBR caliper mount.
Install the PBR caliper mounts.
Remove the stock calipers, their factory flex hose and hose mount from the fender skirt mount. A plug or other temporary item should be used to prevent the fluid from draining. If equipped with ABS, allowing the system to run dry will require a factory type brake bleed procedure to ensure no air has entered the system.
Re-Install the rotors.
Install the PBR flex hose, caliper and pads.
Repeat for the other side.
Once complete, you can put the short length of tubing over the bleed screw and open the bleed screw. Pour brake fluid into the master cylinder reservoir so that it stays full enough to prevent air from entering the lines. Watch the hose for fluid flow as gravity pulls the fluid into the caliper and forces out the air. Close the bleed screw when fluid begins to appear. Bleed the brakes as normal. One easy way is to use a handheld vacuum pump setup at the caliper to draw out the fluid which in turn clears air from the system.
It is time to take your ride for a spin, if you installed new pads follow the manufacturer recommendations for break-in. If the brakes feel spongy bleed them again.
Other upgrades to your brake setup will be to install braided lines, as this will improve the braking ability further.
And while you have everything apart, you may as well do this.
http://www.mikefordmustang.com/write...t-calipers.php
For everything else that is Brakes look here
Upgrade brakes ~ Speeding up slowing down
"I'm not going to sit here and take this defeatist attitude and listen to all this crap any more from all these people who have nothing but doomsday to predict." Carroll Shelby
Last edited by The Cheeks McDuke; December 27th, 2011 at 04:12 AM. Reason: Addin Moar Shtufff
Old December 27th, 2011, 03:31 AM   #2
MM's Barbarian
1996 V6
17.31@85
I'll also be doing a follow on write up with a metric shit-ton of pics when I do this to my car. Stay tuned.
Front SS brake Lines http://www.blueovalindustries.com/br...04/br2200.html
Left Rotor http://www.summitracing.com/parts/SUM-BR-61041L/
Right Rotor http://www.summitracing.com/parts/SUM-BR-61041R/
Right Caliper http://www.summitracing.com/parts/AAZ-18B4722/
Left Caliper http://www.summitracing.com/parts/AAZ-18B4723/
Pads http://www.summitracing.com/parts/SUM-16-804/
Old December 27th, 2011, 09:18 AM   #3
2001 v6 premium
xtreme 2 will become famous soon enough
Send a message via AIM to xtreme 2 Send a message via MSN to xtreme 2 Send a message via Yahoo to xtreme 2
good write-up, but does me no good... I didn't see the 94-98 when I clicked on it, lol...
Screw it, coming to play with the big boys...
5.4L Vortech COMING SOON!
Old December 27th, 2011, 11:33 AM   #4
MM's Barbarian
1996 V6
17.31@85
LoL thanks but I really can't take the credit. All I did was enlarge the pics.
Old December 27th, 2011, 01:01 PM   #5
yeah for 99-04 brake write ups jazzer the cat already has 99% of things covered on our tech section...and i've done a SS hose upgrade write up for it as well.
Old December 27th, 2011, 02:00 PM   #6
MM's Barbarian
1996 V6
17.31@85
You 99-04 guys are lucky all you gotta do is 5.1 fluid, good pads, SS lines, and drilled or slotted rotors and you've got a decent brake setup. Us 94-98 fellas got f-f-f-fucked. Thanks Ford.
I spent like an hour searching for a cheaper option than the Cobra Brake upgrade when i stumbled across this. I don't realy want/need the extra weight.
Old December 27th, 2011, 02:40 PM   #7
if i was to ever upgrade my calipers or anything i would just find a bullit being parted out and then get them. other then that i'm more then content with the upgrades i've already done
Threads Similar to: 94-98 V6 Budget Brake Upgrade
upgrade engine on a budget tw807b 94-95 12 March 29th, 2011 09:43 PM
Baer brake upgrade -- parking brake not working spoulson 5.0 Mustangs 0 September 30th, 2009 02:01 PM
Best brake upgrade on a budget fastford3388 5.0 Mustangs 8 June 17th, 2009 01:44 AM
Budget upgrade advice. INSTALLER020 5.0 Mustangs 12 July 20th, 2008 01:56 PM
Cobra brake or bullit brake upgrade 97gtstang 96-98 5 May 14th, 2007 02:15 AM
