2001 Mustang Oil leak help!!!
Old December 27th, 2011, 08:00 PM   #1
Mustang_owner_67 is on a distinguished road
so a couple of day ago i started seeing big oil leaks in my drive way so i went under my car and found what looks like a hole near the oil pan. i changed out my valve cover gaskets and i have no leaks on the oil pan. i think the is something missing because there is motor oil dripping out...I'm hoping someone could shine some light on this thanks
Old December 27th, 2011, 08:53 PM   #2
stephen has a spectacular aura aboutstephen has a spectacular aura about
The hole is in the transmission bell housing and is used to access the drain plug in the torque convertor. There should be a rubber plug in that hole. If motor oil is leaking out it is likely coming from the crankshaft rear seal. If it's only a small amount of oil it is likely
normal.
Old December 28th, 2011, 08:43 AM   #3
2001 v6 premium
xtreme 2 will become famous soon enough
Send a message via AIM to xtreme 2 Send a message via MSN to xtreme 2 Send a message via Yahoo to xtreme 2
can you get a picture? I am like Stephen, I think it's probably the rear main seal. It's a $2 seal, but costs about $500 for a dealer to replace because of dropping the transmission.
Screw it, coming to play with the big boys...
5.4L Vortech COMING SOON!
Old December 28th, 2011, 07:11 PM   #4
95 v6 mustang loud sounds can only hope to improve
My 95 mustang has the same problem leaks very slow...minez is the main rear seal..i kno someone that will replace it in los angeles for 250 bucks cheepeast out there
mine looks and leaks juss like your i say rear main seal same as minez
Old December 28th, 2011, 10:57 PM   #5
2001 v6 premium
mine has a grommet there, but yea, it leaks too. both my main seals leak right now. I am doing the front when I do the cam (it's part of the timing gasket kit) and the rear I will do down the road, it's no where near as bad as the front.
Old December 29th, 2011, 01:30 PM   #6
how constantly do you put oil? i put oil every 2 or 3 weeks cause it goes down half a quart
Old December 29th, 2011, 01:35 PM   #7
plus i only use it for work and back which is about 20 blocks.
Old December 29th, 2011, 02:06 PM   #8
2001 v6 premium
Mine only leaks about 1/2 a quart in between changes. Nothing crazy but I still want to fix it while everything is apart.
Old December 29th, 2011, 09:54 PM   #9
Macunicorn's Avatar
Macunicorn will become famous soon enough
MIne doenst drip oil rather it is around the bottom of the bell housing.
Sig by Tricep
Threads Similar to: 2001 Mustang Oil leak help!!!
can a 2001 procharger kit be put on an 2001 mustang gt?!? punisherstang General Tech 1 July 20th, 2011 01:46 AM
2001 stang fuel leak? Masterkenny23 V6 Mustangs 3 December 16th, 2010 09:29 PM
2001 GT firewall coolant leak MD5150 99-04 3 September 6th, 2009 10:05 PM
2001 mustang 5 speed vs. 2005 mustang auto. DannyStu Drag 20 October 6th, 2007 10:55 AM
