(-_(-_(-_-)_-)_-)
2004 Mustang Vsixx
Breaking the timer
Throttle Body Replacement
Just was wandering AM and saw Technical Notes. Not legal in emissions controlled states. on mostly all of the throttle bodies. why is it illegal? and should I consider buying one? is it worth it?
[8MINUS2]
Your money you should not waste.
(-_(-_(-_-)_-)_-)
2004 Mustang Vsixx
Breaking the timer
Hmm im perplexed
1999 Mustang Pony
Not even currently moving
![]() iTrader: 2 reviews
^ agreed....i went to a 65mm from a 96 gt for 15 bucks when i built my windstar swap...save your money
lt's,o/r h, flow 40's, egr delete,windstar w/65mm tb,UDP, sniper tuned
Need to install: 4.2 crank,.030 silvo's,268hr112 cam,RR's,comp 915's |
(-_(-_(-_-)_-)_-)
2004 Mustang Vsixx
Breaking the timer
oh alright then
2001 v6 premium
only upgrade intake components as they become the cause of your restriction.
The stock intake is perfectly fine, stock throttle body is perfectly fine, stock manifolds are fine, it's the heads that are your restriction. Once you open those up and start forcing more air in (cam or boost) you can start measuring CFM from your other parts and figure out where your restriction is. If you want any modifications to you TB, get an extra and half-shaft and port it.
![]() Screw it, coming to play with the big boys... 5.4L Vortech COMING SOON! |
The soul stealing Ginger
If you went windstar should you then upgrade TB?
2001 v6 premium
I think you have to because of the linkage placement.
i believe vapauto supplies a fix for that they do to the TB that comes with it.
Threads Similar to: Throttle Body Replacement
| Throttle Cable Replacement | dre.nyc | V6 Mustangs | 14 | August 17th, 2010 12:52 AM |
| BBK 78mm Throttle Intake vs Accufab 75mm Throttle Body/Plenum | andrewskaggs | 99-04 | 19 | June 11th, 2010 08:48 AM |
| Body Replacement parts for the 71-73 Mach 1 | Mach1Club | Classic Mustangs | 2 | November 22nd, 2009 10:26 AM |
| KB Throttle Body | carmanwelder | 2005 - 2010 | 5 | May 18th, 2009 01:37 PM |
