1999 Mustang 35th edition
What rear ends will work on the 99-04 Mustang? Explorer?
Hey guys im looking to replace the rearend on my 99 V6 mustang and i was wanting to upgrade to the 8.8 rearend, I know the 94-98 Gts are going to be about a inch shorter so ill Have to add a spacer but i saw a ford Explorer with a 3.73 will that work? will any other vehicle rearends work?? Thanks again guys?
2000 Mustang Gt
no clue
Do you mean the whole rear axle? Ive heard the explorers rears are off center but someone will prolly chime in with more knowledge than me
Just because your cars loud doesnt mean its fast |
1999 Mustang Pony
Not even currently moving
![]() iTrader: 2 reviews
yeah grab a 99 up gt preferably with gears already installed and your set
lt's,o/r h, flow 40's, egr delete,windstar w/65mm tb,UDP, sniper tuned
Need to install: 4.2 crank,.030 silvo's,268hr112 cam,RR's,comp 915's |
Thats what im wanting to do but im having alot of trouble finding a good 99 and up Gt rear end for a decent price, i can however find a 98 and below gt rear but there are a couple of differences. how long does it usually take to swap out a rear end and what would be a good price to get someone to help me for??
ohh and i found this out as well which kinda had me worried as well
"99-04 lower control arms! THAT IS IMPORTANT! 96-98 control arms are the same on the side that bolts to the axle but the side that bolts to the car is smaller. You need a 14mm not a 12mm. If you put 96-98 Lower control arms in it, it will have to much play and be catostphic! All upper control arms are interchange 79-04 so anyones will work" |
2001 v6 premium
just depends on the manufacturer. If they have a 96-98 and 99-04 option, get the ones for your car.
If they list 79-04, you are fine with them. If in doubt, swap out the bushings for some from a 99-04. You can get them through Prothane. And IIRC, the Explorer uses leaf springs, not shocks in the back...
![]() Screw it, coming to play with the big boys... 5.4L Vortech COMING SOON! |
well i guess that solves that my only options are a 94 - 98 but ill have to add a spacer or another 99-04 rear
2001 v6 premium
you can find the spacers for cheap. It's really not that bad...
1999 Mustang Pony
you mean leaf springs instead of control arms....lol
Threads Similar to: What rear ends will work on the 99-04 Mustang? Explorer?
| rear ends in 87 gt | janitorsteve08 | 5.0 Mustangs | 4 | November 6th, 2011 11:33 PM |
| Do All 87 Mustang Lx's Come With 8.8 Rear Ends? | SCREAMPUFF87GT | 5.0 Mustangs | 6 | July 9th, 2010 07:54 AM |
| rear ends... | 1989Gt. | 5.0 Mustangs | 0 | January 15th, 2010 03:49 PM |
| Swapping Out Rear Ends. . .will This Work | 01sta1k3r | 4V / SVT | 14 | May 9th, 2008 05:58 PM |
| How much do you know about rear ends? | Project_Stang | 5.0 Mustangs | 2 | October 1st, 2007 10:33 AM |
