My mustang wont start i need help installind solenoid nd starter
Old December 28th, 2011, 07:06 PM   #1
95 v6 mustang loud sounds can only hope to improve
My 95 v6 wont start i hear clicks but it wont start..the first thing that happened was my alarm stop working then my car wouldnt start nothin would turn on nd it was a new battery i changed the things that you put on the battery cuzz they were old car started up no problem for some weeks now it wont start lights and radio still comes on i took it to autozone they said it was starter then next thing you kno it started with no problem for some days then recently it wont start lights still come on i believe its the relay or alarm or soleniod can some help to wat i can do to start it or how to install soleniod or starter or alarm i need pictures if you have any
and how can i tell if its the starter or solenoid..? or something else
and when it finally does wanna start it starts up slow like it wont but then it does and wen it doesnt wanna start it juss clicks
Last edited by 95 v6 mustang loud sounds; December 28th, 2011 at 11:27 PM. Reason: can someone PLease help me
Old December 29th, 2011, 12:33 PM   #2
stephen has a spectacular aura aboutstephen has a spectacular aura about
The starter has the solenoid attached to it.
It certainly sounds like the starter. It is held in by two bolts one of which has a ground wire attached to it. First disconnect the battery ground (very important!). Then remove the two bolts and ground wire and lower the starter down with the other two wires attached to it. Disconnect the wires and take the starter to an auto parts store to be tested. Replacement is the reverse. The starter bolts appear to require a 1/2" wrench though a 13 mm will work.
In the unlikely event it isn't the starter check for voltage to the smaller wire that goes to the starter solenoid. It should have 12V when the key is in the start position.
Old December 29th, 2011, 05:56 PM   #3
thanks am gonna try that now will get back to you
Threads Similar to: My mustang wont start i need help installind solenoid nd starter
Car wont start, one click, new starter. ZsMach1 99-04 16 May 29th, 2011 02:25 PM
starter solenoid 1987 5.0 5.0 Mustangs 2 October 11th, 2010 10:39 PM
Starter solenoid clicks at the starter but wont start the car?? 95StangSVT 94-95 13 March 11th, 2010 10:22 PM
How can u tell if its the starter or the solenoid? noyz25 5.0 Mustangs 11 October 28th, 2007 09:48 AM
Starter solenoid? 8A_Honda 5.0 Mustangs 9 March 13th, 2007 12:23 AM
