Engine swap? Can you swap a 99v6 for a 98 GT engine?
LinkBack (1) Thread Tools
Old December 28th, 2011, 07:11 PM   1 links from elsewhere to this Post. Click to view. #1
Bobby00000's Avatar
1999 Mustang 35th edition
Bobby00000 is on a distinguished road
So heres the situation i need another rear end and im wanting to put the 8.8 in, and i found a guy with a 98 mustang gt thats been totaled. I can probably get it for a couple hundred more than just buying the rear end and im tempted to do this because my engine has 235000 miles and sometimes makes a small rattling noise ive been told its a valve rattling?? Well anyways can this be done? What all would need to be done to put the V8 from the 98 into my 99 V6? Thanks guys really learning alot on here.
Old December 28th, 2011, 09:55 PM   #2
qwiksilvermustang's Avatar
1999 Mustang Pony
Not even currently moving
qwiksilvermustang will become famous soon enough
Let me get to my laptop in a bit...I'm going tip have to do a good bit of typing to answer this one.... The answer is yes but its going to take some work, I'll explain it all later.
lt's,o/r h, flow 40's, egr delete,windstar w/65mm tb,UDP, sniper tuned
Need to install: 4.2 crank,.030 silvo's,268hr112 cam,RR's,comp 915's
Old December 28th, 2011, 10:25 PM   #3
1999 Mustang Pony
R u auto or 5 speed
Old December 28th, 2011, 10:42 PM   #4
6ixer's Avatar
2000 mustang v6
14.6@99.68
6ixer is on a distinguished road
Oh if it ticking and rattling. Its a bad head gasket....ask me how I know...dare you lol
Ported heads, comp cams cam, AM CAI, posi'd rear with 3.73 gears, flowmaster exhaust
Fixed clutch!!!!!
"My mustang likes a good ol' fashion bowl of rice....especially fried"
Old December 28th, 2011, 10:51 PM   #5
2001 v6 premium
xtreme 2 will become famous soon enough
Send a message via AIM to xtreme 2 Send a message via MSN to xtreme 2 Send a message via Yahoo to xtreme 2
well, the rear end will be too short to start. Unless you get some wheel spacers your tires are gonna look sucked in.
the engine swap is possible as long as you have the full car on hand. Lots of stuff to swap over. Basically swap the motor, wiring harness, ECU, gauge cluster, PATS box, ignition switch, transmission (if a manual since the GT will be T-45 while you are a T-5)
Screw it, coming to play with the big boys...
5.4L Vortech COMING SOON!
Old December 29th, 2011, 01:20 AM   #6
1999 Mustang Pony
^yeah all that, plus radiator, fan and coolant overflow...alot of work, you'll also be swapping over the ps reservoir and ps lines...
Old December 29th, 2011, 03:30 AM   #7
Bobby00000's Avatar
Please tell me your joking, i shure hope its not, but you dared me so i gotta ask how do you know hahah. But yea i guess a ticking rattling wold be the best description, it doesnt give me any problems when say im on the hw going 70 but if im on a street going a few mles an hour and acelerating i can hear it, but its very minor right now. How long do you think it will last like that? and what woulda caused it?
Old December 29th, 2011, 03:51 AM   #8
1 Wheel Peel
GreenMustang00's Avatar
2000 Mustang 393w
2001 Mustang GT Vert
GreenMustang00 has a spectacular aura aboutGreenMustang00 has a spectacular aura aboutGreenMustang00 has a spectacular aura about
You probably just have a lifter tick. Its hard to diagnose with the limited info and not having a good quality video of it. Hint hint.
Honestly swapping to a 1998 motor will be a waste of time. I would just swap in another 3.8 or 4.2 if your on a tight budget. Agian that is my opinion.
2000 393w Swapped Vert
2001 GT Vert
2002 Six Banger
Old December 29th, 2011, 03:52 AM   #9
Bobby00000's Avatar
Originally Posted by qwiksilvermustang View Post
R u auto or 5 speed
You still at fort Bragg bud? and both are Automatic, so would i have to change the transmission too? Do you guys think it would be worth it? is it easier if its a 99-04 gt?
Old December 29th, 2011, 03:56 AM   #10
1 Wheel Peel
2000 Mustang 393w
A 99-04 GT will net more horsepower as well. Either swap you will be swapping a lot. If you want to swap a v8 in then toss in a mark viii motor. Wont involve any more work than the Mustang motors and it is DOHC. They go cheap at the scrapyards as well
2001 GT Vert
2002 Six Banger
Old December 29th, 2011, 05:07 AM   #11
Bobby00000's Avatar
"If you want to swap a v8 in then toss in a mark viii motor" If you dont mind me asking because i really dont know what is that? What vehicle did they come in? And are there anyother vehicles thats motors will go into my 99 mustang body? Thanks again
Old December 29th, 2011, 05:08 AM   #12
Bobby00000's Avatar
How much have you seen them for at scrapyards?
Old December 29th, 2011, 09:14 AM   #13
2001 v6 premium
It came out of a Mark VIII, LOL. It's a Lincoln. Basically has a detuned Cobra motor, with an aluminum Teksid block. With a good set of cams this motor can turn some heads.
Old December 29th, 2011, 09:15 AM   #14
2001 v6 premium
I see them around here between $300-$500 depending on mileage.
Old December 29th, 2011, 11:12 AM   #15
Loki's Avatar
1996 V6
Loki will become famous soon enough
Even if he went the Mark VIII route, he'd STILL need everything from the GT.
Honestly, I say go for the GT swap for now & if u want more power later, THEN look into the Mark. But so far as this goes, it depends on whether you're doin the work yourself or not =\ If you are, then great! It'll cost you the price of a wrecked GT. If not, any shop is gonna charge you a couple grand. Even me, doing it in my driveway would charge somebody at least 1200 for this job. On the other hand, if youre doing it yourself, I support you 100%. I wish I could find a complete wrecked GT when i needed it. Lol
1996 3.8L.. Split Port Swap, CAI, True Dual Exhaust, the car accident mod.
Need cheap parts? CLICK MEEEEEEEEE!! =]
Old December 29th, 2011, 11:21 AM   #16
Jaa1456's Avatar
2000 GT
Jaa1456 is on a distinguished road
There is a wrecked 97gt near me with a cobra swap. They want 350 for the motor.
Old December 29th, 2011, 12:52 PM   #17
Green_6er's Avatar
2000 Mustang 3.8
ehh w/e the mostly stock time is
Green_6er has a spectacular aura aboutGreen_6er has a spectacular aura aboutGreen_6er has a spectacular aura about
what part of NC are you in? you will more than likely not be able to do it. In NC you can't swap motors unless they came in the car from the factory. Hours of research on this topic has led me to the conclusion that you can only swap in a motor from a 1999 mustang gt.
Originally Posted by 6ER THEN I 8ER! View Post
If you don't scrape you did it wrong
Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK
How to paint your rims:
http://www.moddedmustangs.com/forums...ml#post3931042
Old December 29th, 2011, 02:08 PM   #18
Bobby00000's Avatar
Ahh shit :/ seems like i probably wont do this now i wish i knew more about automotives and could do all this myself. And i kinda move around my mom lives near Hickory Nc i went to bandys if your familiar with that area. And im in the national guard and usually stay near my unit and go to college at Pembroke but right now im in Nashville Tn at my dads
Old December 29th, 2011, 02:09 PM   #19
2001 v6 premium
how would they know?
Old December 29th, 2011, 02:53 PM   #20
6ixer's Avatar
2000 mustang v6
14.6@99.68
no dude i wish i was for both of us lol
i had a pinging rattleing noise fromt eh right side of my engine. heres the key difference to your porblem and mine. under normal crusing speed as in when i kept my throttle constant and at idle there was nothing no noise but...BUT when under accleeration or under load (like low rpms and you put the pedal to the floor) its pinged...well mainly made a rattle sound...which i would discribe as a valve rattle
well fast foward to a month later to chris mas eve i started my car up...no problem drove to the store....came out started the car my girlfriend dodnt close the door right away so when i started it i heard and felt the cars idle...its was loping to the extreme and the right side exhuast sounded....not right.
day later i did a compression test cly 1 AND 2 had abs NO psi but cly 3 4 5 and 6 had 90psi
HEAD GASKET
so now the last 2 days well 95% of yesturday i spent tearing down my engine to the bare block...well everything above the block came off
all wires came unpluged upper lower intake egr heater bracket...ect everything from the deck up came off just for a head gasket
i just sent my heads out today ill be getting the gasket kit from autozone thats like 184.00
and asume my heads are fine thats it if not i need a brand new head....lol
the only worry is about my head is sence both cly had no compression and the gasket cracked/frayed on the part were it lays on top of the cly wall of 1 and 2 that when the intakegas and fuel went to ignite that it opused it between the clys and ignited inbetween the cly and possibly burnt up stomhing.......the valve on cly one looks extremly black
again it could be a simple rocker arm sticking or w/e but i had a simple ping/tick under the hood and ik it was a gasket but i was hoping it could hold oput longer.....and three days ago she finally let go and its was no obvious what happened
Fixed clutch!!!!!
LinkBack to this Thread: http://www.moddedmustangs.com/forums/v6-mustangs/243931-engine-swap-can-you-swap-99v6-98-gt-engine.html
Thread Freelander engine swap | Land Rover Forums | BoardReader This thread Refback January 4th, 2012 09:38 PM
Threads Similar to: Engine swap? Can you swap a 99v6 for a 98 GT engine?
98 V6 engine to 98 Cobra engine swap 98SN-95 V6 Mustangs 0 August 3rd, 2010 03:12 AM
2005 V6 engine swap to 2002 saleen engine MCLARK V6 Mustangs 7 May 14th, 2010 06:02 PM
Which one is easier??a rear end swap or engine swap? Bies08 V6 Mustangs 42 May 11th, 2010 04:33 PM
2005 V6 engine swap to 2002 saleen engine help? MCLARK 2005 - 2010 7 January 11th, 2010 09:27 AM
Can't decide, engine swap or PI swap? A few questions... k3vin 96-98 24 September 5th, 2007 06:48 PM
