Exhaust leak in coolant system, possible hg failure or worse ? - Page 2
Old December 30th, 2011, 12:14 AM   #21
mustangmike!'s Avatar
2004,1994,1967
14.37 @ 96
mustangmike! is a jewel in the roughmustangmike! is a jewel in the roughmustangmike! is a jewel in the rough
wtf -_-
Lol well read away and tell me what you think
227whp N/A V6
Now w/ 8th Mile 8s !
How To Jmod Your Late Model 4R70W
Old December 30th, 2011, 12:48 PM   #22
MM's Official Lucifer
goren813's Avatar
'00 3.8L & '05 4.6L
Originally Posted by stephen View Post
I just went through the same problem. I replaced the head gaskets and used ARP head studs. The following shows the details including the ARP part numbers. I would have the heads surfaced and use Victor gaskets. Victor uses a viton coating that is a fluorocarbon and slippery to allow the gasket to move. Felpro uses a sticky coating which failed in my case (completely came apart). Don't put anything on the head gaskets. The gasket surfaces have to be free of all old gasket material, have the correct surface finish, and be absolutely clean and dry. I cleaned mine with lacquer thinner.
Mustang repairs 2011
Right, all about the prep work! Similar to painting in that sense. I used Acetone (similar product) to remove all traces of old gasket after I scraped it all down. Had the heads tested and machined. I second having nothing else on the gaskets themselves. There are a few spots where you want to apply silicone gasket maker as well, Haynes and I'm sure Chilton's manuals will tell you where (if not we can).
I'm pretty sure it was a felpro gasket kit I used (whatever Advance Auto sells) and haven't run into any problems. Got a couple thousand miles on her after rebuilding the top end.
Old December 30th, 2011, 06:14 PM   #23
2004,1994,1967
14.37 @ 96
I dont remember anything on chiltons about it.
227whp N/A V6
Old December 30th, 2011, 07:42 PM   #24
qwiksilvermustang's Avatar
1999 Mustang Pony
Not even currently moving
qwiksilvermustang will become famous soon enough
^just on the edges of the lower intake gaskets where they meet the china rails and i prefer to put alittle around the water jackets as well jsut for good measure.is he talking about putting silicon on the headgaskets or lower intake gaskets?
lt's,o/r h, flow 40's, egr delete,windstar w/65mm tb,UDP, sniper tuned
Need to install: 4.2 crank,.030 silvo's,268hr112 cam,RR's,comp 915's
Threads Similar to: Exhaust leak in coolant system, possible hg failure or worse ?
Coolant Leak on top of exhaust?? stang4life99 99-04 8 July 26th, 2010 09:19 PM
Coolant Leak on '06 sephstrom 2005 - 2010 V6 2 March 27th, 2010 05:24 PM
Coolant leak? shan 96-98 12 April 26th, 2007 08:52 AM
Evaporative Emission System Leak Detected (very small leak) Juggalo_X V6 Mustangs 11 April 25th, 2007 04:46 PM
Coolant Leak Help garyvang 5.0 Mustangs 13 May 11th, 2006 10:55 PM
