is a torque wrench a MUST for installing spark plugs?
simple question, and would love a quick answer, i've been told you can hand tighten them with like a peice of rubber tubing on the spark plug and then use a ratchet to to a 1/16 to 1/8 of a turn and they should be good.
i just dont want to have to run to autozone and do a 100 dollar collateral for renting a torque wrench. would love a quick answer so i can install these NOW! haha
no...just tighten them down till they fill snug and then give it another 1/4 turn.
btw you can buy torque wrenches at advance for $39 |
#3 | |
thanks for confirming though. gonna go start the install!. hahaha
2000 Mustang 3.8
ehh w/e the mostly stock time is
just tighten until they are snug. once you do enough of them you will know how tight to make them purely on feel.
![]() Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK How to paint your rims: http://www.moddedmustangs.com/forums...ml#post3931042 |
14.37 @ 96
dont break one off in there
hahaha ill try not to
idk how long its been since they have been changed. hopefully they are not too bad.
btw. i bought some motor craft sp 486's and is the gap for them already done?
nvm just looked at the box and i need to do it. standard stock gap is .054 right?
The soul stealing Ginger
yes.
MM's Official Lucifer
Yes, but always check, you never know. Normally when I buy those plugs (pre-gapped) 1 or 2 are still a bit off. Just buy the $1.00 circle to gap them, and replace maybe every other change out so you know it's still on point.
+1 on not needing a torque wrench. Have NEVER used one for plugs.
1999 V6 Mustang
On our cars I wouldn't worry about using a torque wrench, but on cars that are known to strip out the threads or blow the plugs out a good torque wrench is mandatory. BTW don't rent torque wrenches that have been abused or cheap out on torque wrenches either. I have a Craftsman micrometer click-type that was meticulously cared for and after one year of tightening lug nuts on my cars it was torquing things 38% low. A cheap click-type is just as bad as no torque wrench, so either get a good one or don't bother getting one.
The flex beams have a more stable calibration and are more accurate then cheap click-types so I'd get one of those if you don't want to spend much money on one, personally I'm getting a Precision Instruments split-beam since it's the best design and these are the guys who invented it and supplied Snap-on with torque wrenches from 1938-2002 until the two split up and Precision Instruments starting selling directly to the public. |
installed them a while ago, worked great. not really any problems installing. works great. thanks for all the help guys.
I Poop Entirely Way Too Much
Blown 03 GT
If you tighten then til they are snug with a 3/8" wrench they will be over tightened.
Threads Similar to: is a torque wrench a MUST for installing spark plugs?
| Torque Wrench | Huck | General Tech | 4 | November 20th, 2011 01:13 PM |
| torque wrench?? | warrior86 | General Tech | 9 | August 14th, 2011 10:04 PM |
| torque wrench | Mickey | 2005 - 2010 | 70 | December 28th, 2008 02:33 PM |
| Where? (Torque Wrench) | MustangMatt96GT | The Clubhouse | 14 | November 22nd, 2007 10:03 PM |
