Exhaust Design and Build Update! (with videos)
Old January 1st, 2012, 07:28 PM   #1
2000 Mustang v6
winnie51189 will become famous soon enoughwinnie51189 will become famous soon enough
Send a message via AIM to winnie51189
This is my exhaust design thread where I will be posting videos and updating you all as to how I've designed and fabricated my exhaust.
My designs are mostly based off of David Vizard's work.
First I took a video of the car running only stock manifolds which sounded pretty damn good but was extremely loud inside and outside the car.
Then I installed a set of Pacesetter longtube headers which I then connected a 24" secondary to (numbers based on at target rpm of 3000 using my design equations.)
I just finished designing, fabricating, and installing my first prototype of a Pressure Wave Termination Box. The basic idea of the design is easy to come to but size constraints can make it considerably more difficult to make tweaks to enable it to fit in smaller spaces. Given that our cars are naturally low to the ground, it was a major PITA to get something of proper size in such limited space so this will be 1 of multiple prototypes. I can design them for any vehicle, but getting it to fit in smaller spaces will make it significantly more difficult
While it's a prototype it was slightly rushed since it's getting cold outside.
This exhuast in the next video is the same as the previous except I added the pressure wave temrination box (yes it's completely cattless)
My current mods to this engine are CIA, Winstar swap, SF3 SCT tuner.
Old January 1st, 2012, 07:37 PM   #2
Green_6er's Avatar
2000 Mustang 3.8
ehh w/e the mostly stock time is
Green_6er has a spectacular aura aboutGreen_6er has a spectacular aura aboutGreen_6er has a spectacular aura about
vids no working.
Originally Posted by 6ER THEN I 8ER! View Post
If you don't scrape you did it wrong
Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK
How to paint your rims:
http://www.moddedmustangs.com/forums...ml#post3931042
Old January 1st, 2012, 07:42 PM   #3
2000 Mustang v6
Originally Posted by Green_6er View Post
vids no working.
yea I was having issues. lol
fixed it though
Old January 1st, 2012, 07:49 PM   #4
Formerly 01silversixer
SlowSix's Avatar
2001 V6
15.47@89.57
SlowSix has a spectacular aura aboutSlowSix has a spectacular aura aboutSlowSix has a spectacular aura about
so wait...what is the box supposed to do?
is it like a prochamber I'm guessing?
Build Thread
Old January 1st, 2012, 07:59 PM   #5
2000 Mustang v6
The prochamber is like a tiny version of a pressure wave termination box, making it essentially worthless with respect to what a properly designed termination box does.
Essentially the termination box is a substantial increase in cross sectional area cause the exhaust gasses to see it as open atmosphere. basically where ever the termination box is place it makes the exhaust think it's an open pipe at that point. The length of the secondary effects the target rpm range, which is based off of tuning pressure waves and boosts the engines ability to scavenge the exhaust gasses from the cylinder. Also anything placed after the termination box assuming it flows enough, will not have any affect on the performance of the exhaust, essentially making it invisible to the system.
The box is designed to give you a lossless exhaust system (less than or equal to 1%).
Old January 1st, 2012, 08:32 PM   #6
Green_6er's Avatar
2000 Mustang 3.8
i kinda like the sound. would like to hear it on better camera though.
Old January 1st, 2012, 09:44 PM   #7
i still heart my prochamber
Old January 2nd, 2012, 12:05 AM   #8
[{4114 K-73}]
Reaper_88's Avatar
2000 Mustang V6 Manual
Reaper_88 will become famous soon enoughReaper_88 will become famous soon enough
Agreed, sounds awesome but the camera quality is killing it
BAMA-K&N-C&L-TI LLC-VAP Auto-Steeda-MAC-Thrush-Koni-H&R-Maximum Motorsports
WTB MAC Flow Path mufflers or Bassani mufflers PM me if you have a pair
Old January 2nd, 2012, 12:13 AM   #9
2000 Mustang v6
Working on getting a video of it with a better camera.
Old January 2nd, 2012, 02:30 PM   #10
2000 Mustang v6
Hope the video quality of this camera is a bit better as it's all I could get a hold of on such short notice, and it's freezing outside now.
Old January 2nd, 2012, 02:57 PM   #11
Green_6er's Avatar
2000 Mustang 3.8
much better. also, are you going to build these to sell after you finish them up?
Old January 2nd, 2012, 03:18 PM   #12
kevinski72's Avatar
1996 Mustang 3.8
kevinski72 is on a distinguished road
I know its ur prototype so you prolly don't wanna give too much away, butI'm curious to know what it looks like. Anything like this?
http://i104.photobucket.com/albums/m...20Pics/Box.jpg
Ever see a lion limber up before it takes down a gazelle?
Mods: ProChamber & Mac Flowpaths
8.8 rear w/ 3.55 gears
WTB Mac Tail Pipes PM ME
Old January 2nd, 2012, 07:28 PM   #13
2000 Mustang v6
I'm sure that was created using very similar concepts I the same ones as I'm using. I read through David Vizard's work and simply put what he said into equation in an excel chart so It's more organized and I can get the numbers for a box on any engine desired. Just need engine specs like compression ratio, etc...
I actually don't mind giving any information away, since the more ppl try it the better we can understand the topic.by prototype, I simply meant that I will be making more so I can get a better fitment on the car, not that I am trying to keep anything from anyone.
I might sell them but my welding skills aren't the best as I'm just learning but whenever I am happier with my welding I will certainly help the community out any way I can
Old January 2nd, 2012, 07:53 PM   #14
[{4114 K-73}]
Reaper_88's Avatar
Well man I sure do hope so, I'd love to get my hands one of these do keep us posted
Also just a quick question, the prototype ur designing is basically a midpipe similar to the pro chamber correct?
Old January 2nd, 2012, 08:51 PM   #15
99 BLUE V6's Avatar
99 V6 BASE
NEVER RACED THIS ONE
99 BLUE V6 has a spectacular aura about99 BLUE V6 has a spectacular aura about
Any pictures installed?
Old January 2nd, 2012, 09:39 PM   #16
kevinski72's Avatar
1996 Mustang 3.8
I'm interested in what it looks like as well. Also, it seems like the theory is more performance based than it is about the sound. Supposed to make the engine as efficient as it would be without headers at all, right? Did you get onto a dyno yet?
Old January 2nd, 2012, 11:15 PM   #17
SlowSix's Avatar
2001 V6
15.47@89.57
I'm curious as to what that would sound like with flow 40s.
Build Thread
Old January 2nd, 2012, 11:24 PM   #18
2000 Mustang v6
Being that it's the first prototype I kept it as simple as possible to get an idea of exactly how limited I was going to be under the car. So it basically looks like your standard chambered muffler with dual unlets and outlets. It does however have dowels welded inside connecting the flatter sides to reduce reverberations in hopes to prevent any eccess problems with droning. When I get access to my laptop again I'll get some numbers on here regarding my specs. My current box is larger than necessary for my car b/c I made it in mind of my future 4.2L going in. As I didn't want to have to make another more of these for my car than necessary since a larger box would be harder to fit and could end up causing me to have to make an entirely different shaped box.
The box is supposed to make the car run as if it's running on open headers, since ideally the headers would be designed per application.
I don't have pics of the current box or atleast not ones I'm willing to show b/c the welds look awful and it's too damn cold for me to go get any pics worth posting anyways. But as my welding improves I'll definitely post some pictures of further designs.
Also I haven't gotten on a dyno, b/c there are none in the area (or at least not any reputable ones that I know of)
Old January 3rd, 2012, 08:52 AM   #19
The soul stealing Ginger
dgt_mustang's Avatar
2001 Mustang 3.8l
dgt_mustang is a jewel in the roughdgt_mustang is a jewel in the roughdgt_mustang is a jewel in the rough
Send a message via AIM to dgt_mustang Send a message via Skype™ to dgt_mustang
subscribed.
Get another job, get 2 more jobs, get your own place, work, live, fuck, eat, life, happy.
Old January 3rd, 2012, 09:47 PM   #20
mustangmike!'s Avatar
2004,1994,1967
14.37 @ 96
mustangmike! is a jewel in the roughmustangmike! is a jewel in the roughmustangmike! is a jewel in the rough
Im interested in what you have going here, more detail
227whp N/A V6
Now w/ 8th Mile 8s !
How To Jmod Your Late Model 4R70W
Threads Similar to: Exhaust Design and Build Update! (with videos)
Update on my V6 build... One Bad Sixxx V6 Mustangs 53 October 7th, 2010 02:03 AM
Build update videos inside Doc8224 4V / SVT 27 April 1st, 2009 07:40 PM
Exhaust Design. Dansby V6 Mustangs 23 December 15th, 2008 08:02 PM
