96 3.8
1996 mustang 3.8
96 3.8 Mustang No Power Full Throttle
I have a 96 3.8 mustang i have a major issue. when i first start it up she runs ok for about a mile or so. also it takes longer to start but at times she cranks right up. but after the first mile is starts to miss and it will not pull at full throttle. it will bog down but wont stall out. it is annoying. i can run on the hight way around 2000- 2400 rpm and she runs ok pulls but as soon as i press the pedal down she boggs down. it also miss fires #2 cylinder. i have Full exhaust no cats flows. so i know its not a cat.
i have changed the Cam sensor, crank sensor, plugs, coil, fuel pump. cleaned mass air sensor, IAC sensor, and throttle body. i need help please advise.. |
14.37 @ 96
Well its a single port 150hp V6. w/ 2.73s this = no power at any throttle
It needs 2 more cyls, atleast another 100hp min, and lower gearing 3.5 min. Other then that my comments on the other forum still stand
96 3.8
1996 mustang 3.8
Did you post on the allfordmustang forums if so that site is down it wont let me check the post.
lol yeah i know i would rather have a V8. I had a 92 Lx 5.0 built. totaled it one rainy night. So i got the sixer for the gas millage. I will have another 5.0 soon enough. |
14.37 @ 96
uhhmmm
Well see what happens was I hacked the shit |
96 3.8
1996 mustang 3.8
lol well you did a good job of it because it want let me see my post or read certain post. so any ideas on what up with my POS. its driving me insane.
14.37 @ 96
log into your email, may have it there
anyways though, double check all wiring and vacuum hoses. Also your new fuel pump aint shit if your filter is clogged :p or if injectors are clogged up also. have you tried new plug wires ? Dads focus was the same way, plugs slightly helped but It needed new wires also. Did that and booda baada bang boing done ! < that was homo anyways |
clogged fuel filter is my guess..
96 3.8
1996 mustang 3.8
i am doing wires and fuel filter this weekend. i hope that is it someone mention check the air charge sensor in the intake boot.
96 3.8
1996 mustang 3.8
yeah i thought so the air charge sensor wouldlnt cause that much of a issue wtih accelaration. a clogged filter or bad wires would though. the weird issue is when i made a hard turn under accelration it will bogg down and at time cut if. i have had it cut off while running 55mph the other day.
96 3.8
1996 mustang 3.8
6er then i 8er what all engine mods do you have done.
get it tested at any autoparts store...if you're not showing a CEL one might be there anyway...
2001 v6 premium
^^ weak sauce... LOL
My guess is fuel filter as well.
![]() Screw it, coming to play with the big boys... 5.4L Vortech COMING SOON! |
96 3.8
1996 mustang 3.8
i have a OTC scanner and only code it shows is a O2 code. But that wouldlnt cause it to run like its running the code was there before it ran like it does.
96 3.8
1996 mustang 3.8
i had a 92 5.0 built. it was a fun car but the gas it ate killed me. i enjoy my v6 decent gas mileage and fun to drive if i can ever get it back to running good. i have some friends with some strong v6 stangs and still came out cheaper than a v8.
14.37 @ 96
dont you have like some O/R H or some shit ?
If mods dont work w/ ecu w/o tune then you could be fucked analy |
2001 v6 premium
oh you never said you were popping an O2 sensor... that's your problem... LOL.
What is the exact code?
2001 v6 premium
if you have no O2s and aren't tuned open loop then your computer is probably dumping mad fuel when you stomp it. you are drowning out the plugs.
I bet if you pulled a plug it would be pretty wet.
Threads Similar to: 96 3.8 Mustang No Power Full Throttle
| Sputter at full throttle | OptionalStang | 96-98 | 2 | July 18th, 2011 10:17 PM |
| Throttle popping off at full throttle | jonrhy05 | 5.0 Mustangs | 3 | July 6th, 2011 03:34 PM |
| Full Throttle - 99-04 throttle cable adjustment/fix | MustangGeek | V6 Mustangs | 4 | June 16th, 2011 12:01 AM |
| 5.0 bogging down at full throttle | sharkattack91 | 5.0 Mustangs | 9 | April 24th, 2011 10:40 PM |
| Question about car hesitation when full throttle | 08MustangGT4Me | 2005 - 2010 | 55 | April 20th, 2009 12:25 AM |
