check engine
my check engine light is on. the code reads : bank 1 rich, bank 2 rich (P0172, P0175). I replaced my spark plugs and my plug wires, but it still continues to come on. I am due for inspection in a month, and I'd like to know what else this could be.
MM's Resident Ricer
2006 Scion tC
13.001@113
your running rich you done any timeing or a/f changes or changed any engine components?
my car was completely stock when the light came on. I've been turning it off with my tuner, but it's annoying. It usually only comes on when I reset my battery. my list of aftermarket things is below.
Id say something within the exhaust triggered your sensors to go haywire. Just like mine. Now the light is going to stay on until the thing gets fixed. When the light comes on, your fuel/air ratio gets taken off its default setting and the car starts to take up alot of fuel all at once. Which is now why youre getting alot of rich codes. And itll contunue to stay this way until the problem is solved. Start troubleshooting...
¡ʇsnq ɹo uʍop ǝpısdn
how many miles and have you ever messed with you O2 sensors? sounds like you have one that is going out...
i would know... mine finally went this morning ... on my way to the shop... they tried to clean them a bit and cleand the MAF and IAT for 35 bucks... not a bad use of money.... now my car doesn't bog in the lower RPM's so have that looked at and give your sensors a good cleanin
2002 Ford Focus
slow as fuck
![]() iTrader: 4 reviews
try fixing the problem the right way or go the cheap way and buy mil eliminators. that way the engine thinks the air is fine all the time
99 V6 Mustang-sold 02 Ford Focus-sold 98 Camaro Z/28-lid, catback |
#7 | |
Then again, driving around with a computer that "thinks" everything is fine isnt really a smart way to go about it either, IMHO. Its just bound to mess up sooner or later. Id rather A. find the problem and spend the money to fix it and get rid of the problem all together, or B. buy a tuner and just disable it completely.
extensions up front
mils out back... thats how it goes and also ... just sell the car if it doesn't work... ha jk... OBS you can't get yours to work? you have long tubes catless mid and true's right? did you ever get your build up done? i remember you were makin a vid... sorry off topic your problem might be something else then if its not fixed... what was your code ?
This was a long time ago, havent touched my car for about a year now. Im still kinda 5000 miles away from it. And no, the engine hasnt been bought yet. Its been, hm, postponed due to me being stupid with money. Again.
Its coming though.. Im not rushing it. But anyway, back on topic. I really dont care about where the MILs and extensions go, the tuner was bought so Im gonna use that sucka to take off the damn light.
my car? 35k and I turned off my o2 sensors with the tuner.
and is it fixed now? or does it still wig out?
uhh if it still wigs out... turn them back on and look into MIL elims
it gave me the code, but, only after I unplug and replug my battery, then I erase the codes with my tuner, and they don't come back until I have to screw with the battery. the car runs fine with or without the sensors.
yea... i know but it runs better with the sensors... well it technically should run better unless you have a set tuned a.f ratio... then in that case... you don't technically need them
a.f?
n/p i just dont understand why the light comes on ONLY after i do something with my battery, and not after i rease the codes. I only have to erase them once per resetting of the computer.
cuz the tuner has told the computer to fuckin forget the code and don't bother me with it ever again... but when you reset your comp it throughs out the command that it was given
I always thought that it just reset the computer for a while, and after so long the code came back. that's what I never understood.
MM's Resident Ricer
2006 Scion tC
13.001@113
u got a flash tuner? tune the a/f ratio a bit leaner
Threads Similar to: check engine
| check engine | lwhitetrash88l | V6 Mustangs | 25 | September 13th, 2007 06:12 PM |
| check engine | steeda gully | 99-04 | 4 | July 20th, 2007 01:23 AM |
| Check Engine Light | brose1388 | 2005 - 2010 | 4 | April 28th, 2007 04:26 PM |
| Check Engine Light | xxrals22xx | V6 Mustangs | 30 | January 20th, 2007 05:42 PM |
| check engine | cali 5.0 | 5.0 Mustangs | 2 | August 12th, 2006 12:13 AM |
