Wax on, Wax off
Moving Car Back To DD Status... Few Issues.
The Mustang is moving back to DD status for various reasons. Because of this I have been chasing down problems that have developed but I took my time fixing since I was not driving it much.
List of major issues right now:
What have I done so far?
Problem 1: Running Rough Out of all the things I have done, any other ideas to help this? I have not put the car back together yet after the plugs, iac, and maf cleaning yet. This new CAI won't be here till Tuesday also. Anything else you can think of me to check/fix mention it. Problem 2: Stripped spark plug hole This is the big one right now. I was suggested to get a kit from the stone called Helicoil Sav-a-Thread. It is made for spark plugs, and all the reviews online say it is good. Anyone have any experiance? It says the main thing to watch for is metal shavings getting into the chamber. They say this can be achived by spraying some lubricant on the tool. Problem 3: Oil in plugs I noticed in two of the 4 plugs I have taken out so far, there was a good bit of oil on the threads of the plug. Is this a concern that I need to address? If so, what could cause it and what steps can I take to fix/help the situation?
![]() Black Bullitt Rims FT/FS Looking to Sell or Trade for Silver FR500s Looking to buy a lot of 99-04 Interior Pieces If you have any for sale, PM me |
the heli-coil save a thread kits will do the job for fixing the stripped out one...as for the oil on the plugs...i'd run the new plugs for a few weeks then check the ones that had the oil on them...see if this is an on going issue..
other things that could cause it to idle rough... -wires -ignition coil -upstream o2's -exhaust or vaccum leak -various other little sensors just make sure to gap the plugs before install...also which ones did you go with? |
#3 | |
Wax on, Wax off
The wires should be good. I replaced them back in March 2008 with 8.5mm MSD wires. o2's could be an issue. They have never been replaced. Would throw a code though right? Exhaust leak is a high probaility. If none of these thing fix it, I plan to take it to a shop to check the exhaust. Another thing, The car when idling has had a kinda drone to it at times. Almost like it's idling a bit to high. Hard to explain. Also... I got a error code the other night. I looked it up and the cause is cyl head overheating. I had just flushed the coolant, and it ended up needing some more coolant (maybe 1/3 of a bottle). I suppose that could of been what threw the code. Gonna clear it after all this and see if it comes back.
not the plugs i'd go with but it's your choice...and no they are not pre-gapped...only the +4's come pregapped...
as for the wires...well not really helping your car with 8.5mm but i don't think it'll hurt it...could be wrong (you'd need to ask ESG)....basically your oe coilpack isn't throwing any extra power through those wires...i know it affects the spark but i don't remember how much as for the o2's...they normally throw a code but sometimes the code will pop up but not a light...if you have a handheld i'd check the memory and see if it's showing one..if not any autoparts store can do it for you since you're having no luck on the exhaust leak a shop may be your only option for that unless you can get a hold of a smoker... when it sounds like it's idling high is the actual RPMs showing over 700ish |
#5 | |
Wax on, Wax off
well good luck on the thread kit....i'd take one of your plugs with you..the kits are in assortment packs so you'll want to make sure you get one that will fit your plug...don't be afraid to open the kit and test fit
[8MINUS2]
> clean iac
> get rid of any spark plug that's bosch > coil pack could be bad? > cylinder head over heating?
lol i've already said i don't like the plugs he picked
[{4114 K-73}]
2000 Mustang V6 Manual
Bosch plugs suck in every way possible, total crap
Zatrekaz run some Motorcraft, Autolites, or some NGK coppers plugs instead
![]() BAMA-K&N-C&L-TI LLC-VAP Auto-Steeda-MAC-Thrush-Koni-H&R-Maximum Motorsports WTB MAC Flow Path mufflers or Bassani mufflers PM me if you have a pair |
#10 | |
Wax on, Wax off
Whats so bad about the bosch plugs? I had some on the car for almost 60k miles. Never noticed any issue.
[{4114 K-73}]
Reliability...google the plugs, a lot of people say to stay away from them
2000 Mustang 3.8
ehh w/e the mostly stock time is
my car hesitated a lot with them.
![]() Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK How to paint your rims: http://www.moddedmustangs.com/forums...ml#post3931042 |
14.37 @ 96
spark plug threads ... stripped ... explain this ? A simple tap might do the job, but honestly I would NOT do that shit w/ the head on the engine ...
Wax on, Wax off
I got the new threads done and the plug in. Was not very hard at all. I made sure to stop multiple times and crank the car. This blew the shards out of the hole.
The car is running MUCH smoother now, and I bet with the new CAI it will be even better. My next thing to watch for is the oil that is in the spark plugs. I imagine it is just some gaskets and stuff in the engine. May get them replaced later down the road.
Run ur car, not ur mouth.
2003 Sonic Blue 4.6L
make sure to reset your ecu ex. clear codes after changing the intake and cleaning maf etc, all that, because the ecu needs to reset its parameters iirc
Wax on, Wax off
I reset everything.
Drove the car about 60 miles today and its running good. I did notice about three times it would lurch while going about 70mph. Not sure why... was very random. Next task: Suspension. I just put in new lowering springs on the front... no iso's. I have Sportlines in the front and H&R in the back. I feel a lot of vibration from the front of the car right now. I imagine it's from the no iso's? I got an alignment, but something is still not right. The car pulls HARD to the right. Gonna take it back in and have them recheck the alignment and everything under there. Anything that would cause a hard pull to the right even if the alignment is good?
#17 | |
Wax on, Wax off
Will do...
Do you think I may have damaged something when I was on the slammed cut springs? I didn't see anything odd under there... but it just does not feel the same as when I had the H&Rs. Granted, these are different springs and no iso' s so that may be the cause.
Wax on, Wax off
I think in Feb I am going to buy a Bumpsteer kit and the X2 Balljoints. That should help out with the quality a great deal.
This is what all I plan to do... in order:
Wax on, Wax off
Took the car back to the tire shop today. They guy said there was not a lot he could do to fix the pull to the right. Seems odd to me since it was not doing this before.
He said he would do what he could... will see what he comes up with. Guess I just have to deal with it until I can get the upgrades I mentioned.
Threads Similar to: Moving Car Back To DD Status... Few Issues.
| Moving battery to back and track legal q | cedsks | 99-04 | 17 | March 24th, 2011 11:38 PM |
| Guess Who's BACK!?!? Bar Exam Status: Complete | Nameless | The Clubhouse | 14 | February 25th, 2011 06:50 PM |
| Moving my seat back? | Mattd76 | 99-04 | 16 | January 15th, 2011 09:21 PM |
| Moving The Seat Back | 707Stang | All Other Vehicles | 3 | May 13th, 2008 11:10 AM |
| Moving Back Home...Registering Car Questions... | ChrisJ | The Clubhouse | 7 | December 28th, 2007 10:01 PM |
