1999 Mustang
V6 Engine Help
I have a 99 mustang 35th anniversary with 3.8 v6 engine. I had to replace the engine with an 01 3.8 v6 it was the only one that was in my area. To my under standing the only difference was the intake. I took the intake from the 99 engine an put on the 01 engine, other wise the engine harness would have been different from the coil pack, and injectors I think. I'm wondering if my mistake was not using the injectors from the 01 an also the coil pack? I'm getting a back fire, also can't get past 55 without bogging down. Any help/info would be greatly appreciated! Thank you for your time.
99 V6 BASE
NEVER RACED THIS ONE
Check plug wires for correct firing order
14.37 @ 96
What all did you replace ? Be specific.
14.37 @ 96
Long block swap should give you 0 problems if you did it right.
Unless the balancing is different that is |
2000 mustang v6
14.6@99.68
Why did u chhanged intakes....arnt all stock intake plenums the same for all 99-04 sixers?
Ported heads, comp cams cam, AM CAI, posi'd rear with 3.73 gears, flowmaster exhaust Fixed clutch!!!!! "My mustang likes a good ol' fashion bowl of rice....especially fried" |
[8MINUS2]
did you replace the lower intake? Or what?
2000 Mustang 3.8
ehh w/e the mostly stock time is
make sure you don't have plug wires 5 and 6 mixed up.
![]() Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK How to paint your rims: http://www.moddedmustangs.com/forums...ml#post3931042 |
14.37 @ 96
Have you ever done that ? lol
IF not, even if your half ass stupid, as soon as that thing fires over once you'll kill it as fast as possible. And it'll be the only time you ever forget to double check your wires. |
iPoopke Regular
2004 Mustang
Check plugs and wires.
99 V6 BASE
had same problem when I switched to windstar. Plug wires were wrong 5/6 .
Make sure you didn't mount coil upside down
1998 mustang GT
Oh man when I had my old sixer I crossed 5/6 wire in the parts store parking lot so it was dark. Man never again I had no idea what was going on for about 5 secs.
Sent from my Autoguide iPhone app |
#12 | |
14.37 @ 96
Lol but thats what im saying, if you hear that thing missfire just once w/ a crossed wire and let it keep running ... Ill get banned talking about how stupid you are
#13 | |
The problem you are having is probably in the ignition. I would suggest a new Motorcraft coil pack. It will have the plug wire locations marked so you can be sure the wires are not interchanged. |
14.37 @ 96
this. you may use atleast the short block, and if sensors are the same or can be reused in the same spot, the long block. |
Modded V6
So I'm in the same boat as the op. I swapped over the coil pack, wires, and upper intake from the 99 motor that was bad. So could using a 99 coil pack/wires cause the engine to shake a little and misfire?
![]() 1999 e46 328i BMW - Daily Driver 2001 SVT Cobra - Project 1995 v6 vert - SOLD 1996 v6 vert - SOLD 1995 v6 vert #2 - SOLD 1995 GT - SOLD 1997 v6 coupe - Parting |
Threads Similar to: V6 Engine Help
| 03 crown victoria engine vs. 2003 mustang gt engine?? Which tko 500? | 98 Stanga Banga | 99-04 | 8 | September 20th, 2010 08:25 PM |
| 2005 V6 engine swap to 2002 saleen engine | MCLARK | V6 Mustangs | 7 | May 14th, 2010 06:02 PM |
| 2005 V6 engine swap to 2002 saleen engine help? | MCLARK | 2005 - 2010 | 7 | January 11th, 2010 09:27 AM |
| Engine install: Life engine up, or drop engine? | trill gear head | 2005 - 2010 | 14 | October 26th, 2009 01:17 AM |
| Will a 2002 Gt Engine Directly Replace a 2000GT engine? | Bigb2000GT | 99-04 | 7 | April 22nd, 2007 05:09 PM |
