#62 |
Wax on, Wax off
To far for me... Im in south MS. Plus the engine is at 119k miles. If I get a new engine, I want it under 100k.
![]() Black Bullitt Rims FT/FS Looking to Sell or Trade for Silver FR500s Looking to buy a lot of 99-04 Interior Pieces If you have any for sale, PM me |
#63 |
2001 v6 premium
yea I started second guessing it as soon as I posted it, but it was too late. I actually though it was a GT. Didn't even click it just linked, LOL.
![]() Screw it, coming to play with the big boys... 5.4L Vortech COMING SOON! |
#64 | |
14.37 @ 96
I dont believe this compression test is a big deal so far. Lets make 100% its going correctly before you pour oil in and stuff. Pictures please. You've talked about them but I see non, makes it harder to work w/ w/o seeing whats going on and hands on. Need more to work with here so see what you can do as far as pictures. Oil/Carbon build up in the runners is normal. I pulled my shit and the shit was caked in there @ 50k miles. Sticky nasty shit. Comes out well with a bit of scrubbing and B12 Cleans it right up.But anyways. Some stuff you might want to read about: 99-00 3.8L Mustang Driver's Side Valve Cover Fix I mean the general problem fuck the filter lol |
#65 |
Yes, it's pretty involved. At the very least you would hone the cylinders and replace the rings.
Some of the cheaper ones don't have the check valve.
Rod @ AzzKicker Cars 2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's. ![]() 1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC. ![]() 1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch |
#66 |
14.37 @ 96
And what started all this ?
You just pulled the plugs and seen oil and the world stopped turning or what ?car running fine before ? |
#67 |
14.37 @ 96
well fuck i forgot about this thread
Moving Car Back To DD Status... Few Issues. |
#68 |
14.37 @ 96
Ok so ive read around on your threads.
Where exactly are we now. You fixed the spark plug thread problem I see. You've taken the engine apart somehwhat ? intakes off or something ? Fill me in on where we are as of right now |
#70 |
Wax on, Wax off
Right now the car is all together and running. The only indications that there is an issue is the car seems to hesitate or stall sometimes while driving. It also idles unusally high, and the large amounts of oil in the plugs.
Like I said... I am simply going to take it to a shop when I get the funds, and have them check it all out and see what they suggest. My car is a 2003, so the artical about the filter does not really apply since I have the new baffle. However, I will look into adding that filter on the PCV just in case. As for cleaning the upper intake... what can I use for that? B12? What is that and where can I get it?
#71 |
2001 v6 premium
It's a vitamin... you get it at Wal-Mart. Just crunch it up and toss some in. Cures everything. Even takes weed out of your pee...
Lol, it's just chemtool. You can get it at any auto parts store. It comes either as a spray or as a gallon bucket. What I normally do is take a 2x4 and drill holes to match the throttle body opening. Attach the wood to the throttle body opening and tighten the bolts down. Seal it off with RTV and let it cure a little. Then pour in the b12 to the runners and let it soak. Then get one of those bottle cleaners (baby bottles) and start scrubbing.
#72 |
Wax on, Wax off
I Lol'd
#73 |
Wax on, Wax off
I put it all back together, and its running really rough now. Acts like it is either not getting fuel or air. I installed a new CAI also.
Gonna re-check all the plugs and make sure they are all installed good. They all tightened down however, so doubt thats it. I tried it without the new CAI, same thing. Added about 1/4 tank of fuel... same thing. I'm really getting tired of dealing with this.
#74 |
Check your plugs/wires, any electrical connections you unpluged, and for vacuum leaks.
#75 |
Wax on, Wax off
Ya... Just gonna take all the plugs out (like the 7th time) and reinstall them. Only things I disconnected was the coil plug and the fuel pump cut off thing in the trunk.
I checked my wires as well, all are hooked up in the right order.
Threads Similar to: Internal engine gaskets/ect.?
| First deep engine work. Head Gaskets. | PhoenixCMXIV | V6 Mustangs | 7 | March 10th, 2011 09:22 AM |
| what is the best internal engine part to upgrade? | stang340 | 96-98 | 5 | August 23rd, 2010 08:29 PM |
| internal engine info | clidefr0g | V6 Mustangs | 12 | August 8th, 2010 11:48 PM |
| Engine block forged internal build help | stevo306stang | 99-04 | 21 | July 14th, 2010 10:47 PM |
| 12.6 with no power adders or internal engine modifications | gx1856 | 2005 - 2010 | 5 | May 24th, 2007 11:47 AM |
