Internal engine gaskets/ect.?
Old January 9th, 2012, 02:28 AM   #1
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
Zatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud of
iTrader: 15 reviews
When changing plugs, I noticed a good bit of oil on 4 of them. I imagine my gaskets and such inside the engine are wearing and getting old. Now, I don't know enough about the internals to do that myself. I am considering taking it to a shop down the road and asking them to do this for me.
My questions:
  • Is this a good idea? Worth it?
  • If I was to buy the gaskets myself, what would I need for a decent tune-up?
  • Do you think a shop would charge a arm and a leg for this?
Black Bullitt Rims FT/FS
Looking to Sell or Trade for Silver FR500s
Looking to buy a lot of 99-04 Interior Pieces
If you have any for sale, PM me
Old January 9th, 2012, 09:00 AM   #2
Tang Stang's Avatar
Tang Stang is just really niceTang Stang is just really niceTang Stang is just really niceTang Stang is just really nice
Oil in the combustion chamber is more than likely due to either leaking valve stem seals or worn rings. How many miles are on the engine? Just how bad were the plugs? Have you done a compression or leak-down test?
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Old January 9th, 2012, 09:36 AM   #3
mustangmike!'s Avatar
2004,1994,1967
14.37 @ 96
mustangmike! is a jewel in the roughmustangmike! is a jewel in the roughmustangmike! is a jewel in the rough
+1 ^
227whp N/A V6
Now w/ 8th Mile 8s !
How To Jmod Your Late Model 4R70W
Old January 9th, 2012, 01:26 PM   #4
2001 v6 premium
xtreme 2 will become famous soon enough
Send a message via AIM to xtreme 2 Send a message via MSN to xtreme 2 Send a message via Yahoo to xtreme 2
yup, was gonna say valve seals or piston rings... valve seals you can do when you put on ported heads and install a cam. If you are gonna pull it apart might as well upgrade.
Screw it, coming to play with the big boys...
5.4L Vortech COMING SOON!
Old January 9th, 2012, 02:29 PM   #5
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
iTrader: 15 reviews
They were not horrible, but there was oil on the electrodes and half way up the threads. How do I perform a compression or leak-down test?
I want to install ported heads and a cam, but...
1. I don't have the funds right now for that (unemployed, have just enough money for essentials)
2. I wouldn't have a clue as to how to install heads or a cam Lol.
Old January 9th, 2012, 02:48 PM   #6
Tang Stang's Avatar
Compression test:
1. Rent/buy a compression test tool set.
2. Run engine until it has reached operating temp.
3. Disable fuel and spark.
4. Remove all spark plugs.
5. Install correct adapter into spark plug hole on cylinder #1.
6. Install gauge/hose onto adapter.
7. Run starter for ~10 seconds to achieve reading on gauge.
8. Record reading.
9. Repeat steps #5-8 on all other cylinders.
Leak-down test:
1. Rent/buy a leak down test tool set.
3. Remove spark plug on cylinder #1 and bring the piston up to TDC.
4. Install correct adapter into spark plug hole on cylinder #1.
5. Install tool/hose onto adapter and hook your air compressor up to the tool.
6. Add air to the cylinder.
7. Rock piston around TDC to ensure rings are seated.
8. Record leakdown percentage.
9. Repeat steps #3-8 on all other cylinders.
Old January 9th, 2012, 02:52 PM   #7
Tang Stang's Avatar
Either of those tests will give an indication of the condition of the rings. If the results indicate that the rings aren't the culprit, then I'd definitely suspect the valve stem seals.
Old January 9th, 2012, 04:03 PM   #8
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
iTrader: 15 reviews
I might just take it to a shop and have them check it out. Would be cheaper than buying the tools for a one time thing, ya know?
Gonna take one of the spark plugs by the shop and have them take a look at it at least and see what they can tell me.
I really appreciate the advice Tang Stang, reps givin.
Old January 9th, 2012, 04:10 PM   #9
1999 V6 Mustang
SALEEN961 will become famous soon enough
A compression tester kit only costs $20-$50 depending on how complete the kit is, you'd be hard pressed to get a shop to come anywhere near that price, plus AutoZone will loan you a gauge if you put down a $40 deposit on it.
Old January 9th, 2012, 04:21 PM   #10
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
iTrader: 15 reviews
Well then, based on that:
Compression test:
3. Disable fuel and spark. How do I do that? Spark I could disconnect the coil pack... but fuel?
7. Run starter for ~10 seconds to achieve reading on gauge. How do I run just the starter? Crank it with the spark and fuel off?
8. Record reading.
Leak-down test:
3. Remove spark plug on cylinder #1 and bring the piston up to TDC. What is TDC and how do I achive it?
7. Rock piston around TDC to ensure rings are seated. Again, how is this done?
Old January 9th, 2012, 04:26 PM   #11
1999 V6 Mustang
The parts stores near me don't rent leak down testers but they all have compression testers.
Just unplug the coil and hold the gas pedal down all the way while cranking to turn the fuel injectors off.
Yep, just crank the car with the coil unplugged and gas pedal all the way down.
Old January 9th, 2012, 04:43 PM   #12
Tang Stang's Avatar
Exactly. You can rent the kit(s) from Autozone or pick them up from a cheap tool place like Harbor Freight and save yourself some money.
There are multiple ways to disable fuel and spark. Pull the fuel pump and EEC fuses, unplug the coil, unplug the inertia switch, hold the throttle to the floor, etc.
Run the starter via the ignition switch. Just like if you were trying to start the engine.
TDC = Top dead center. For cylinder #1, you can use the marks on the harmonic balancer. TDC for each successive cylinder in firing order will be 90* apart.
By using a breaker bar and socket on the harmonic balancer bolt.
Old January 9th, 2012, 10:52 PM   #13
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
iTrader: 15 reviews
Would it hurt to just replace both of the seals/gaskets? I kinda want to just to cover all the basis. If I was, what would I need to buy and how much money am I lookin at. Also... is this something I can do with a few days and a Craftsman tool set?
Old January 9th, 2012, 11:59 PM   #14
Green_6er's Avatar
2000 Mustang 3.8
ehh w/e the mostly stock time is
Green_6er has a spectacular aura aboutGreen_6er has a spectacular aura aboutGreen_6er has a spectacular aura about
Simple test that may give away if it is the rings or not:
Smell the oil to see if it smells like it has any gas in it.
Originally Posted by 6ER THEN I 8ER! View Post
If you don't scrape you did it wrong
Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK
How to paint your rims:
http://www.moddedmustangs.com/forums...ml#post3931042
Old January 10th, 2012, 12:18 AM   #15
iPoopke Regular
2004 Mustang
iPAPKE will become famous soon enoughiPAPKE will become famous soon enough
My dads friends oil in his 03 cobra had a smell of gasoline to it- ended up being the alternator
Old January 10th, 2012, 03:09 AM   #16
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
iTrader: 15 reviews
I'd like to know how something that does not touch gas or oil caused that
I noticed today that my lower intake is leaking oil. I also saw that the upper and lower intake seem to have a good bit of oil in them. I wonder if that may have something to do with the oil in the cly?
Old January 10th, 2012, 08:28 AM   #17
Tang Stang's Avatar
Replacing the rings requires tearing the engine down. You'll need more than a simple Craftsman tool set. If the results of the test(s) show that the ring seal is good in all cylinders, then I'd consider replacing the valve stem seals, which require far less tear down to R&R. Still you'll need an air compressor, an adapter to attach an air line to the spark plug hole, and a valvespring compressor in addition to your average tool set.
Where is the lower intake leaking? The intakes likely do have a good deal of oil in them. Blowby is introduced to the intake manifold via the PCV system.
Old January 10th, 2012, 09:19 AM   #18
2001 v6 premium
sounds like you need to save up and get ported heads and a cam...
replace all gaskets in the process, and you should be good to go unless it's piston rings...
Old January 10th, 2012, 10:59 AM   #19
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
iTrader: 15 reviews
I am thinking more and more that this is a shop thing. I can see the test bein easy, but beyond that I am getting into areas that I know nothing about. Since this car is my DD again, I can't afford to mess something up and it be down for weeks.
The lower intake is leaking on the driver side front corner near the alternator. It's quite a bit of oil. I think when I get all this checked/fixed I will get that gasket replaced. Gonna replace the PCV valve as well for good measure.
Old January 10th, 2012, 11:17 AM   #20
Tang Stang's Avatar
That lends even more evidence toward excessive blowby or a clogged PCV valve. However, if the PCV valve was clogged, you wouldn't see so much oil inside the intake manifold runners. I'd at least do a compression test, as that will narrow down what is actually going on.
Threads Similar to: Internal engine gaskets/ect.?
First deep engine work. Head Gaskets. PhoenixCMXIV V6 Mustangs 7 March 10th, 2011 09:22 AM
what is the best internal engine part to upgrade? stang340 96-98 5 August 23rd, 2010 08:29 PM
internal engine info clidefr0g V6 Mustangs 12 August 8th, 2010 11:48 PM
Engine block forged internal build help stevo306stang 99-04 21 July 14th, 2010 10:47 PM
12.6 with no power adders or internal engine modifications gx1856 2005 - 2010 5 May 24th, 2007 11:47 AM
